path: root/configs/tinker-s-rk3288_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-03-26rockchip: Change keyboard input from CrOS EC keyboard to a USB keyboardPeter Robinson
These boards aren't ChromeOS devices so won't have a cros-ec-keyb input as it's the keyboard available via the ChromeOS Embedded Controller. Update them to use a USB keyboard which would actually be available. Also enable the usb keyboard option for those devices that don't have it enabled already. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-30rockchip: rk3399: Enable DISPLAY_CPUINFOJagan Teki
RK3288, RK3399 are now support cpu-info, so enable DISPLAY_CPUINFO by default. Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-11-23Merge tag 'u-boot-rockchip-20191124' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Clean vid/pid in Kconfig and add fastboot for rk3399 - add 'u-boot, spl-fifo-mode' for mmc - Use FIT generator for rk3229 optee and rk3368 ATF - fan53555: add support for Silergy SYR82X and SYR83X
2019-11-23fastboot: rockchip: Select FASTBOOT_FLASH[_MMC_DEV]Jagan Teki
Select CONFIG_FASTBOOT_FLASH, CONFIG_FASTBOOT_FLASH_MMC_DEV for rockchip SoC plaforms in fastboot Kconfig file instead of defined it in board defconfig. This eventually drop the explicit configs defined in supporting board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: rockchip: USB_GADGET_PRODUCT_NUMJagan Teki
Rockchip support differnet or common gadget product number between Rockchip SoCs like, 0x310a - rk3036 0x320a - rk3229, rk3288 0x330a - rk3328 So, select them on Kconfig based on platform specific config defined.     This eventually drop the explicit configs defined in supporting board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: Select USB_GADGET_VENDOR_NUM for rockchipJagan Teki
Gadget vendor number, 0x2207 is common across all platfroms supported in Rockchip SoC. So, select the same number globally, if ARCH_ROCKCHIP. This eventually drop the explicit configs defined in supported board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: Select USB_GADGET_MANUFACTURER for rockchipJagan Teki
Select the gadget manufacturer as 'Rockchip' for all rockchip platform SoC's. This eventually drop the explicit defined added on supported board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-21configs: Resync with savedefconfigTom Rini
2019-11-17rockchip: dts: tinker: Add tinker-s board supportMichael Trimarchi
Support tinker-s board. The board is equivalent of tinker board except of emmc. TODO: - support of usb current burst when the board is powered from pc Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
