path: root/configs/uniphier_ld4_sld8_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-26configs: Resync with savedefconfigTom Rini
2020-05-22ARM: uniphier: select DM_ETHMasahiro Yamada
drivers/net/smc911x.c has been converted to DM. select DM_ETH to enable it for all the UniPhier platform boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-22preboot: Introduce CONFIG_USE_PREBOOT and migrate CONFIG_PREBOOTMasahiro Yamada
This is the same migration path as commit b6251db8c3f0 ("Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND"). I also moved the description in README to the Kconfig help. I ripped off the sentence about 'LWMON' since it is gone already. I only let my boards migrate, leaving the rest to platform maintainers. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-29ARM: uniphier: allow to source boot script before distro-bootMasahiro Yamada
Some users might need additional setups before booting the kernel. If there is found a file 'boot.scr', run it before invoking the distro boot command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: do not modify bootcmd environment variable at run-timeMasahiro Yamada
Some users might want to modify 'bootcmd' at compile-time by editing include/configs/uniphier.h, but overwriting it at run-time makes it impossible. Instead, set 'bootdev' at run-time, which contains the boot device the system is booting from, then indirectly reference it from 'bootcmd'. It is up to users whether to override 'bootcmd'. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-11ARM: uniphier: enable CONFIG_CMD_UBIMasahiro Yamada
Now that CONFIG_SYS_MONITOR_LEN increased, we have room for enabling more options again. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-25ARM: uniphier: enable MTD partition and UBIMasahiro Yamada
Enable "mtdparts" and "ubi" commands for uniphier_v8_defconfig to use UBI on NAND devices. Enable only "mtdparts" for uniphier_{v7,ld4_sld8}_defconfig because enabling UBI would increase 170KB, which would be memory footprint problem. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-29ARM: uniphier: set CONFIG_LOGLEVEL to 6Masahiro Yamada
Print out KERN_NOTICE or higher level log messages. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-21uniphier_ld4_sld8: Re-add SMC911X_BASE addressTom Rini
This was dropped by accident in the Kconfig conversion. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-30ARM: uniphier: move CONFIG_NAND to defconfigMasahiro Yamada
This imply was added when the option was moved by the moveconfig tool, but the intention is not clear. Move it to defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-30ARM: uniphier: enable CONFIG_NAND_DENALI_DTMasahiro Yamada
Migrate to the DT-based NAND init entry. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-26ARM: uniphier: enable CONFIG_CMD_FS_GENERICMasahiro Yamada
Enable file system commands such as load, ls. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: enable CONFIG_CMD_CONFIGMasahiro Yamada
This command is useful to see which config options are enabled on the running U-Boot image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: enable CONFIG_CMD_GPTMasahiro Yamada
Enable CONFIG_CMD_GPT, keeping CONFIG_SPL_EFI_PARTITION because the SPL for UniPhier platform does not recognize any partitions. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: disable CONFIG_SPL_DOS_PARTITIONMasahiro Yamada
The SPL for UniPhier platform does not recognize any partitions. Do not compile unneeded features. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: disable CONFIG_MTD_NOR_FLASHMasahiro Yamada
This feature is seldom used these days on UniPhier boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-22ARM: uniphier: make SPL optional for ARVv8 SoCsMasahiro Yamada
We may want to run different firmware before running U-Boot. For example, ARM Trusted Firmware runs before U-Boot, making U-Boot a non-secure world boot loader. In this case, the SoC might be initialized there, which enables us to skip SPL entirely. This commit removes "select SPL" to make it configurable. This also enables the Multi SoC support for the UniPhier ARMv8 SoCs. (CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and Device Tree, the U-Boot proper part is now written in a generic way. The board/SoC parameters reside in DT. The Multi SoC support increases the memory footprint a bit, but the U-Boot proper does not have strict memory constraint. This will mitigate the per-SoC (sometimes per-board) defconfig burden. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
