path: root/configs/vexpress_aemv8a_dram_defconfig
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-11-21vexpress64: store env in flashRyan Harkin
Add support for storing the environment in CFI NOR flash on Juno and FVP models. I also removed some config values that are not used by CFI flash parts. Juno has 1 flash part with 259 sectors. The first 255 sectors are 0x40000 (256kb) and are followed by 4 sectors of 0x10000 (64KB). FVP models simulate a 64MB NOR flash part at base address 0x0FFC0000. This part has 256 x 256kb sectors. We use the last sector to store the environment. To save the NOR flash to a file, the following parameters should be passed to the model: -C bp.flashloader1.fname=${FILENAME} -C bp.flashloader1.fnameWrite=${FILENAME} Foundation models don't simulate the NOR flash, but having NOR support in the u-boot binary does not harm: attempting to write to the NOR will fail gracefully. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-10-11vexpress64: fvp dram: add DRAM configurationRyan Harkin
Create an additional FVP configuration to boot images pre-loaded into DRAM. Sometimes it's preferential to boot the model by loading the files directly into DRAM via model parameters, rather than using SemiHosting. An example of model parmaters that are used to pre-load the files into DRAM: --data cluster0.cpu0=Image@0x80080000 \ --data cluster0.cpu0=fvp-base-gicv2-psci.dtb@0x83000000 \ --data cluster0.cpu0=uInitrd@0x84000000 Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> [trini: Update board/armltd/vexpress64/Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
