Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
This commit converts the following items to Kconfig:
CONFIG_ATMEL_NAND_HWECC
CONFIG_ATMEL_NAND_HW_PMECC
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER
[PMECC References]
https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure
https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap
[Mailing List Thread]
https://lists.denx.de/pipermail/u-boot/2018-December/350666.html
Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment")
[trini: Make the migration be size neutral and possibly not fix the
above in all cases]
Reported-by: Daniel Evans <photonthunder@gmail.com>
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_ATMEL
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration after also including CMD_MEMTEST]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
This board is based on the Atmel sama5d3 eval boards.
Supporting the following features:
- Boot from NAND Flash
- Ethernet
- FIT
- SPL
Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com>
Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
