path: root/configs/xilinx_versal_mini_emmc0_defconfig
2020-06-04Convert CONFIG_BZIP2 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BZIP2 CONFIG_GZIP CONFIG_LZO CONFIG_ZLIB CONFIG_LZMA CONFIG_LZO Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-04serial: Convert ARM_DCC to KconfigTom Rini
The symbol "CONFIG_ARM_DCC" is used to control building drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this. Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Tom McLeod <tom.mcleod@opalkelly.com> Cc: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-10-08arm64: versal: Remove unneeded configs for mini configurationsSiva Durga Prasad Paladugu
The PSCI_RESET and EXPERT are not needed for mini configurations so remove them to save space. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-08arm64: versal: mini_emmc: Enable fatwrite supportSiva Durga Prasad Paladugu
This patch enable fatwrite support for mini emmc configurations. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
2019-10-08arm64: versal: Define board_late_init for versalSiva Durga Prasad Paladugu
Define board_late_init which performs bootmode detection and prepares corresponding distro boot commaand sequence. Also disable it for mini platforms because simply there is no need to have it enabled. But also disable it for virtual platform because Qemu is not modelling this register space that's why travis testing would fail. This configuration should be reverted when mainline Qemu is updated. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-02-14arm64: versal: Disable showing information about consoleMichal Simek
There is no need to see this info. It is just wasting of space/time. It saves 308Bytes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-02-14arm64: versal: Add mini eMMC configurationSiva Durga Prasad Paladugu
This patch adds mini eMMC configuration which has only emmc0 and emmc1 functionalities and can run from small amount of memory. This is required for memory constraint devices. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
