path: root/configs/xilinx_zynqmp_mini_emmc0_defconfig
2020-06-04Convert CONFIG_BZIP2 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BZIP2 CONFIG_GZIP CONFIG_LZO CONFIG_ZLIB CONFIG_LZMA CONFIG_LZO Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-04serial: Convert ARM_DCC to KconfigTom Rini
The symbol "CONFIG_ARM_DCC" is used to control building drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this. Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Michal Simek <monstr@monstr.eu> Cc: Tom McLeod <tom.mcleod@opalkelly.com> Cc: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-01-14arm64: zynqmp: Move PANIC to KconfigMichal Simek
Convert another option Kconfig. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-10-08arm64: zynqmp: Define default SYS_PROMPTMichal Simek
All boards are using the same prompt that's why add it as default value to Kconfig to simplify defconfigs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-10-08arm64: zynqmp: Define default SPL_TEXT_BASE address in KconfigMichal Simek
Define default address via Kconfig. There is no need to change this address for most of the boards but it is also possible. This one line save a lot of lines in defconfigs that's why make sense to do it. The similar change has been done by commit 9340d8fe8beb ("sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to Kconfig") Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-01-24arm64: zynqmp: Setup DM_ETH/MMC if NET/MMC is enabledMichal Simek
Setup proper ETH/MMC dependency for the whole platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Wire mini-emmc0 configuration with zcu100Michal Simek
For testing purpose use zcu100 which has SD at controller 0 and this can be used for testing this mini configuration. U-Boot 2018.11-00281-gc5d48466e76e (Nov 30 2018 - 10:41:05 +0100) Model: ZynqMP MINI EMMC0 Board: Xilinx ZynqMP DRAM: 512 MiB EL Level: EL3 MMC: sdhci@ff160000: 0 In: dcc Out: dcc Err: dcc ZynqMP> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Use minimal size for environment variablesMichal Simek
There is no reason to have huge space for variables because none is using that. But there are some which are setup automatically. baudrate=115200 fdtcontroladdr=ffffa0d0 stderr=dcc stdin=dcc stdout=dcc Environment size: 72/124 bytes Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-30arm64: zynqmp: Do not save variables about boardMichal Simek
No reason to save this data to environment. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-29arm64: zynqmp: Disable autoboot feature for miniMichal Simek
There is no reason to have autoboot enabled because it should never start anything automatically. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-26arm64: zynqmp: Disable bootelf and fdt commands for mini configurationsMichal Simek
There is no reason to enable these commands for mini configurations. It saves some space: aarch64: (for 2/2 boards) all -19076.0 bss -1048.0 data -1720.0 rodata -3840.0 text -12468.0 xilinx_zynqmp_mini_emmc1: all -19076 bss -1048 data -1720 rodata -3840 text -12468 xilinx_zynqmp_mini_emmc0: all -19076 bss -1048 data -1720 rodata -3840 text -12468 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm64: zynqmp: Enable MP by default via KconfigMichal Simek
Simplify defconfig for ZynqMP but keep option not to enable it for mini targets. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-26arm64: zynqmp: Handle CONFIG_BOARD_LATE_INIT via KconfigMichal Simek
Disable BOARD_LATE_INIT via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19arm64: zynqmp: Setup ENV_SIZE via Kconfig for mini targetsMichal Simek
Mini targets are using different ENV_SIZE then standard one that's why defconfigs should be updated to simplify config files. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-15arm64: zynqmp: Split emmc configuration into emmc0 and emmc1Siva Durga Prasad Paladugu
This patch splits the current mini emmc configuration into emmc0 and emmc1 configurations because emmc is probed at boot time and on systems which have only one interface mini configuration is failing on unused interface. This patch also adds required clock node in dts and enables CONFIG_MMC_SDHCI_ZYNQ through defconfig. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
