path: root/configs
2016-10-28Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-10-28board: sama5d2_xplained: Enable an early debug UARTWenyou Yang
Enable an early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28board: sama5d2_xplained: Move config options to defconfigsWenyou Yang
Move the config options from the include/configs/sama5d2_xplained.h to configs/sama5d2_xplained_*_defconfig. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-26imx6: icorem6: Add NAND supportJagan Teki
Add NAND support for Engicam i.CoreM6 qdl board. Boot Log: -------- U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43) Trying to boot from NAND NAND : 512 MiB U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 55C Reset cause: WDOG Model: Engicam i.CoreM6 DualLite/Solo Starter Kit DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> Cc: Scott Wood <oss@buserror.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26engicam: icorem6: Add DM_GPIO, DM_MMC supportJagan Teki
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL. Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx6q: icorem6: Enable pinctrl driverJagan Teki
Enable imx6 pinctrl driver support for i.CoreM6. Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26arm: imx6q: Add devicetree support for Engicam i.CoreM6 DualLite/SoloJagan Teki
i.CoreM6 DualLite/Solo modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DL, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx6: icorem6: Add ENET supportJagan Teki
Add enet support for engicam icorem6 qdl starter kit. - Add pinmux settings - Add board_eth_init TFTP log: -------- Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb Using FEC device TFTP from server 192.168.2.96; our IP address is 192.168.2.75 Filename 'imx6dl-icore.dtb'. Load address: 0x0 Loading: ###### 1.3 MiB/s done Bytes transferred = 28976 (7130 hex) CACHE: Misaligned operation at range [00000000, 00007130] icorem6qdl> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-26arm: imx: Add Engicam i.CoreM6 QDL Starter Kit initial supportJagan Teki
Boot Log for i.CoreM6 DualLite/Solo Starter Kit: ----------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 31C Reset cause: POR DRAM: 256 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device switch to partitions #0, OK mmc0 is current device reading boot.scr ** Unable to read file boot.scr ** reading zImage 6741808 bytes read in 341 ms (18.9 MiB/s) Booting from mmc ... reading imx6dl-icore.dtb 30600 bytes read in 19 ms (1.5 MiB/s) Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800a787 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 Boot Log for i.CoreM6 Quad/Dual Starter Kit: -------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6Q rev1.2 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 28C Reset cause: POR DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 icorem6qdl> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx: mx6ull_14x14_evk: add plugin defconfigPeng Fan
Add defconfig file to use plugin code. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_EXTRA_INFO to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_EXTRA_INFO Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_SYS_CONSOLE_BG_COL et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_FG_COL Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_CT69000 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_CT69000 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CFB_CONSOLE_ANSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-15spl: move SYS_OS_BASE to KconfigHeiko Schocher
Move SYS_OS_BASE to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Also migrate a4m2k] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-12Merge git://git.denx.de/u-boot-dmTom Rini
2016-10-12Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-10-12Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-10-12Merge git://www.denx.de/git/u-boot-marvellTom Rini
2016-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1021aqds.h include/configs/ls1021atwr.h
2016-10-12x86: coreboot: Convert to use DM coreboot video driverBin Meng
This converts coreboot to use DM framebuffer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11configs: am57xx_evm_defconfig: Enable CMD_REG optionKeerthy
Enable CMD_REG option. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11configs: am57xx_evm_defconfig: Enable PALMAS optionsKeerthy
Enable palmas PMIC config options. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11configs: dra7xx_evm_defconfig: Enable PALMAS optionsKeerthy
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
