path: root/configs
2017-03-30colibri_imx6_defconfig: silence console output in splMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30apalis_imx6_defconfig: silence console output in splMax Krummenacher
2017-03-30ARM: vf610: add auxiliary core boot supportStefan Agner
Use i.MX bootaux support introduced for i.MX 6SoloX/i.MX 7 for Vybrid too. Starting the Cortex-M4 core on Vybrid works a bit differently, namely it uses a GPR register to define the initial PC. There is no way to define the initial stack (the stack is set up in a boot ROM). This is not a problem for most firmwares since the firmwares startup code reinitialize the stack as part of the firmware startup code anyway. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30colibri_imx7: use device-tree for MTD partitionsStefan Agner
Use device-tree fixup to communicate the MTD partitions to the kernel. Remove mtdparts from the kernel command line. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-18apalis/colibri_imx6: enable SDP in SPL by defaultApalis_iMX6_ToradexEasyInstaller_V0.5Stefan Agner
Enable Serial Download Protocol (SDP) in SPL. This is useful to make use of imx_usb to download the complete U-Boot (u-boot.img) after SPL has been downloaded. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis-tk1: disable EFI loaderStefan Agner
The EFI loader is for most use cases not necessary so disable it by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit df9aa4068201394a9b2d7c30fbf34a815467c2d2)
2017-01-11colibri_imx7: enable boot commandStefan Agner
Enable default boot command. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11toradex boards: enable FIT image supportStefan Agner
FIT image support is used by the upcoming Toradex Easy Installer and also can be useful for more advanced boot scenarios. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis_t30: enable display driverMarcel Ziswiler
Enable the display driver on Apalis T30. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. (cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
2017-01-11colibri_t30: enable display driverMarcel Ziswiler
On popular request enable the display driver on Colibri T30. A few notes about some things encountered during porting: While analogue VGA (e.g. via the on-carrier RAMDAC) worked just fine from the beginning the EDT display flickered like crazy which turned out to be a pin muxing issue. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. Enjoy. (cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
2017-01-11colibri_t20: migrateMarcel Ziswiler
Migrate Colibri T20 to U-Boot 2016.11. (cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
2017-01-11apalis/colibri: add device tree overlay support for all modulesStefan Agner
Device tree overlays might prove useful in the future, enable it by default on all our modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_t30: migrateMarcel Ziswiler
Migrate Apalis/Colibri T30 to U-Boot 2016.11. (cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
2017-01-11colibri_imx7: use default dtb configurationStefan Agner
Use default CONFIG_OF_SEPARATE configuration which appends the device tree at the end of the U-Boot binary. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_imx7/vf: disable EFI loaderStefan Agner
The EFI loader is for most use cases not necessary so disable it by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11video: dcu: fix framebuffer to the end of memoryStefan Agner
Fix the framebuffer location to the very end of the available memory. This allows to remove the area from available memory for the kernel, which in turn allows to display the splash screen through the while Linux kernel boot process. Ideas has been taken from the sunxi display driver, e.g. 20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory") Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11colibri_imx7: boot in secure mode by defaultStefan Agner
The CAAM driver of the downstream i.MX 7 Linux kernel seems not to work well when booting in non-secure: caam 30900000.caam: Entropy delay = 3200 caam 30900000.caam: failed to acquire DECO 0 caam 30900000.caam: Entropy delay = 3600 caam 30900000.caam: failed to acquire DECO 0 ... caam: probe of 30900000.caam failed with error -11 Unable to handle kernel NULL pointer dereference at virtual address 00000004 Default booting in secure mode. If non-secure is preferred (e.g. required for virtualization on a mainline kernel) one can use setenv bootm_boot_mode nonsec Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11spl: add USB Gadget config optionStefan Agner
Introduce USB Gadget config option. This allows to combine Makefile entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Ravi Babu <ravibabu@ti.com> (cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
2017-01-11toradex apalis/colibri: use common USB product id fallbackStefan Agner
All modules use the common g_dnl_bind_fixup implementaton which calculates the PID according to product id (read from the config block) plus offset of 0x4000. In case there is no config block support (e.g. SPL) or in case the config block is not readable, fall back to a generic product id (product id 0, which can be interpreted as "Unknown Module"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_imx7: enable u-boot-nand.imx targetMax Krummenacher
2017-01-11apalis-tk1: disable external clock loopback on SDMMC3Marcel Ziswiler
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11mmc: tegra: move CONFIG_TEGRA_MMC from headers to defconfigsMarcel Ziswiler
Basically running the following script: tools/moveconfig.py CONFIG_TEGRA_MMC Note that I left the SPL specific handling in include/configs/tegra-common-post.h unchanged. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11arm: tegra: initial support for apalis tk1Marcel Ziswiler
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards. The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot, environment storage and Toradex factory config block - Gigabit Ethernet - MMC/SD cards (both MMC1 as well as SD1 slot) - USB client/host (dual role OTG port as client e.g. for DFU/UMS or host, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11arm: imx: initial support for colibri imx6Max Krummenacher
This adds board support for the Toradex module family Colibri iMX6. The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both with a version for commercial and industrial temperature range. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
2017-01-11arm: imx: initial support for apalis imx6Max Krummenacher
This adds board support for the Toradex module family Apalis iMX6. The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with commercial and industrial temperature range. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
2017-01-11colibri_pxa270: transition to driver model for serialMarcel Ziswiler
Add serial platform data to board file. Enable driver model for PXA serial driver. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
2017-01-11colibri_pxa270: drop edit, elf, fpga, hush, regex et al. for space reasonMarcel Ziswiler
With em humble DM and Kconfig migraters U-Boot binary size keeps increasing. Drop a bunch of less needed stuff to save another precious 20+ KB. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
2017-01-11serial: pxa: use kconfig for serial configurationMarcel Ziswiler
Migrate the PXA serial driver to be configured via Kconfig. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Marek Vasut <marex@denx.de> (cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
2017-01-11apalis/colibri_imx7/pxa270/t20/t30/vf: integrate config block handlingMarcel Ziswiler
With our common code in place actually make use of it across all our modules. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
2017-01-11apalis/colibri_t20/t30: deactivate displaying board infoMarcel Ziswiler
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit b05d6806cd6a95d46c22036a684a09501fdb2264)
2016-11-13igep00x0: consolidate defconfigsLadislav Michl
Defconfigs should remain the same except CONFIG_SYS_EXTRA_OPTIONS. Drop NAND specific defconfig as flash type is runtime detected. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Reviewed-by: Javier Martinez Canillas <javier@samsung.com>
2016-11-13igep00x0: disable CONFIG_DISPLAY_BOARDINFOLadislav Michl
As a single U-Boot binary can now run on various board modifications, drop CONFIG_DISPLAY_BOARDINFO as it prints flash memory information too early to give us chance to easily detect it. Also saves few bytes as a bonus. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Reviewed-by: Javier Martinez Canillas <javier@samsung.com> Tested-by: Javier Martinez Canillas <javier@samsung.com>
2016-11-07ARM: tegra: enable Ethernet on p2771-0000Stephen Warren
Enable the Ethernet device in DT, provide board-specific configuration, and enable the driver in Kconfig. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-30rk3288: config change for enable dram capacity auto-detect.Kever Yang
Enable ROCKCHIP_SPL_BACK_TO_BROM and disable CONFIG_SPL_MMC_SUPPORT to save memory in order to enable add source code for dram capacity auto-detect. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-30sunxi: Add support for Cubieboard4Chen-Yu Tsai
The Cubieboard4 is an A80 SoC based development board from Cubietech. This board has a UART port, 4 USB host ports, a USB 3.0 OTG connector, HDMI and VGA outputs, a micro SD slot, 8G eMMC flash, 2G DRAM, a WiFi/BT combo chip, headphone and microphone jacks, IR receiver, and GPIO headers. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: Enable SPL support for A80 Optimus boardChen-Yu Tsai
The A80 Optimus Board was launched with the Allwinner A80 SoC. It was jointly developed by Allwinner and Merrii. This board has a UART port, a JTAG connector, 2 USB host ports, a USB 3.0 OTG connector, an HDMI output, a micro SD slot, 16G eMMC flash, 2G DRAM, a camera sensor interface, a WiFi/BT combo chip, a headphone jack, IR receiver, and additional GPIO headers. Signed-off-by: Chen-Yu Tsai <wens@csie.org> [hdegoede@redhat.com: update existing Merrii_A80_Optimus_defconfig instead of adding a new defconfig] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: A64: enable USB supportAmit Singh Tomar
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support for the the HCI0 USB host controller on the A64. Fix up some minor 64-bit hiccups on the way. Add the bare minimum DT bits to the A64 .dtsi and enable the controllers and the PHY on the Pine64. This is limited to the first USB controller at the moment, which is connected to the lower USB socket on the Pine64 board. [Andre: remove unneeded defines, enable OHCI, add commit message] Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-30sunxi: Update DRAM clock for Olimex A20 boardsStefan Mavrodiev
Originally dram clock was set to 480MHz, but this behaves unstable. To improve stability the clock is reduced to 384MHz Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-29configs/chromebox_panther_defconfig: Re-enable CONFIG_DM_PCITom Rini
This was turned off by accident, re-enble. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-28Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-10-28board: sama5d2_xplained: Enable an early debug UARTWenyou Yang
Enable an early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28board: sama5d2_xplained: Move config options to defconfigsWenyou Yang
Move the config options from the include/configs/sama5d2_xplained.h to configs/sama5d2_xplained_*_defconfig. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-26imx6: icorem6: Add NAND supportJagan Teki
Add NAND support for Engicam i.CoreM6 qdl board. Boot Log: -------- U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43) Trying to boot from NAND NAND : 512 MiB U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 55C Reset cause: WDOG Model: Engicam i.CoreM6 DualLite/Solo Starter Kit DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> Cc: Scott Wood <oss@buserror.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26engicam: icorem6: Add DM_GPIO, DM_MMC supportJagan Teki
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL. Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx6q: icorem6: Enable pinctrl driverJagan Teki
Enable imx6 pinctrl driver support for i.CoreM6. Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26arm: imx6q: Add devicetree support for Engicam i.CoreM6 DualLite/SoloJagan Teki
i.CoreM6 DualLite/Solo modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DL, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
