Cleaned up cpu/mpc85xx/Makefile to use CONFIG_* for those obvious cases
we have like PCI, CPM2, QE. Also reworked it to use one line per file
for everything and sorted in alphabetical order.
In the future the offsets to various blocks may not be in same location.
Move to using CFG_MPC85xx_CPM_ADDR as the base of the CPM registers
instead of getting it via &immap->im_cpm.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Simplify TQM85xx Makefile handling.
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
PM520 boards.
Fix PHY address for canmb board.
- fix clock rates
- remove debug messages
- fix flash sector protection
* Patch by Steven Scholz, 07 Apr 2005:
Fix warning in cpu/arm920t/at91rm9200/i2c.c
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
