path: root/disk/part.c
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-04partitions: increase MAX_SEARCH_PARTITIONS and move to part.hAlison Chaiken
Move MAX_SEARCH_PARTITIONS to part.h so that functions in cmd directory can find it. At the same time, increase the value to 64 since some operating systems use many, and the resources consumed by a larger value are minimal. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-05-11disk: Return the partition number in part_get_info_by_name()Alex Deymo
Similar to what blk_get_device_part_str() does, this patch makes part_get_info_by_name() return the partition number in case of a match. This is useful when the partition number is needed and not just the descriptor. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-12-27disk: Fixed capacity messageJean-Jacques Hiblot
With capacities getting bigger, we can see see messages with negative numbers like "Capacity: 1907729.0 MB = 1863.0 GB (-387938128 x 512)". Here the printed LBA is -387938128 when it should have been 3907029168. To fix this, use the right format when displaying the unsigned integers. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reported-by: Yan Liu <yan-liu@ti.com>
2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
2016-05-17dm: blk: Use the correct error code for blk_get_device_by_str()Simon Glass
Return -EINVAL instead of -1 in this function, to provide a more meaningful error. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: part: Drop the block_drvr tableSimon Glass
This is not needed since we can use the functions provided by the legacy block device support. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: part: Use the legacy block driver for hardware partition supportSimon Glass
Drop use of the table in part.c for this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Drop the host_get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: systemace: Drop the get_dev() functionSimon Glass
2016-05-17dm: sata: Drop the get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. We cannot yet make sata_dev_desc[] private to common/sata.c as it is used by the SATA drivers. This will require the SATA interface to be reworked. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: scsi: Drop the get_dev() functionSimon Glass
2016-05-17dm: mmc: Drop the get_dev() functionSimon Glass
2016-05-17dm: ide: Drop the get_dev() functionSimon Glass
2016-05-17dm: usb: Drop the get_dev() functionSimon Glass
2016-05-17dm: disk: Use legacy block driver info for block device accessSimon Glass
Instead of calling xx_get_dev() functions for each interface type, use the new legacy block driver which can provide the device through its interface. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-14dm: part: fix missing driver name in debug printNishanth Menon
Fixes the following warning with PART_DEBUG enabled: disk/part.c: In function ‘get_partition_info’: disk/part.c:372:3: warning: format ‘%s’ expects a matching ‘char *’ argument [-Wformat] Signed-off-by: Nishanth Menon <nm@ti.com>
2016-04-01drivers: block: add block device cacheEric Nelson
Add a block device cache to speed up repeated reads of block devices by various filesystems. This small amount of cache can dramatically speed up filesystem operations by skipping repeated reads of common areas of a block device (typically directory structures). This has shown to have some benefit on FAT filesystem operations of loading a kernel and RAM disk, but more dramatic benefits on ext4 filesystems when the kernel and/or RAM disk are spread across multiple extent header structures as described in commit fc0fc50. The cache is implemented through a minimal list (block_cache) maintained in most-recently-used order and count of the current number of entries (cache_count). It uses a maximum block count setting to prevent copies of large block reads and an upper bound on the number of cached areas. The maximum number of entries in the cache defaults to 32 and the maximum number of blocks per cache entry has a default of 2, which has shown to produce the best results on testing of ext4 and FAT filesystems. The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows changing these values and can be used to tune for a particular filesystem layout. Signed-off-by: Eric Nelson <eric@nelint.com>
2016-03-15disk/part.c: Expose list of available block driversAlexander Graf
We have a pretty nice and generic interface to ask for a specific block device. However, that one is still based around the magic notion that we know the driver name. In order to be able to write fully generic disk access code, expose the currently internal list to other source files so that they can scan through all available block drivers. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Convert partition API use to linker listsSimon Glass
We can use linker lists instead of explicitly declaring each function. This makes the code shorter by avoiding switch() statements and lots of header file declarations. While this does clean up the code it introduces a few code issues with SPL. SPL never needs to print partition information since this all happens from commands. SPL mostly doesn't need to obtain information about a partition either, except in a few cases. Add these cases so that the code will be dropped from each partition driver when not needed. This avoids code bloat. I think this is still a win, since it is not a bad thing to be explicit about which features are used in SPL. But others may like to weigh in. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device_and_partition()Simon Glass
Rename this function to blk_get_device_part_str(). This is a better name because it makes it clear that the function returns a block device and parses a string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device() to blk_get_device_by_str()Simon Glass
The current name is too generic. The function returns a block device based on a provided string. Rename it to aid searching and make its purpose clearer. Also add a few comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_dev() to blk_get_dev()Simon Glass
The current name is too generic. Add a 'blk_' prefix to aid searching and make its purpose clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-20mmc: emmc and hw partitions partition table id bugfix.Erik Tideman
On bootup the emmc's hw partition is always set to 0 and the partition table is read from it. When switching to another hw partition the partition table's id is not updated but instead the old one from hw partition 0 is used. If there is no partition table on hw partition 0 then the code will terminate and return error even if the desired hw partition contains a perfectly fine partition table. This fix updates the partition table struct to correspond to the specified hw partition before testing if the partition table is valid or not. Signed-off-by: Erik Tideman <erik.tideman@faltcom.se> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Squash the patch that corrected whitespace in the original into this one, wrap with HAVE_BLOCK_DEVICE test] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12gpt: add optional parameter type in gpt commandPatrick Delaunay
code under flag CONFIG_PARTITION_TYPE_GUID add parameter "type" to select partition type guid example of use with gpt command : partitions = uuid_disk=${uuid_gpt_disk}; \ name=boot,size=0x6bc00,uuid=${uuid_gpt_boot}; \ name=root,size=0x7538ba00,uuid=${uuid_gpt_root}, \ type=0fc63daf-8483-4772-8e79-3d69d8477de4; gpt write mmc 0 $partitions Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2015-10-24ubifs: Add generic fs supportHans de Goede
Add generic fs support, so that commands like ls, load and test -e can be used on ubifs. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-24disk/part: Only build hostfs special handling when CONFIG_SANDBOX is setHans de Goede
This is not necessary / useful when not building with CONFIG_SANDBOX and with the addition of ubifs support to the generic fs commands it actually gets in the way, since both operate on a fake / NULL blkdev. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-10-25disk/part.c: make local function staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-24cleanup disk/part.c whitespacePavel Machek
Cleanup disk/part.c Signed-off-by: Pavel Machek <pavel@denx.de>
2014-07-22whitespace cleanupsPavel Machek
Whitespace cleanups. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-06-23sandbox: restore ability to access host fs through standard commandsStephen Warren
Commit 95fac6ab4589 "sandbox: Use os functions to read host device tree" removed the ability for get_device_and_partition() to handle the "host" device type, and redirect accesses to it to the host filesystem. This broke some unit tests that use this feature. So, revert that change. The code added back by this patch is slightly different to pacify checkpatch. However, we're then left with "host" being both: - A pseudo device that accesses the hosts real filesystem. - An emulated block device, which accesses "sectors" inside a file stored on the host. In order to resolve this discrepancy, rename the pseudo device from host to hostfs, and adjust the unit-tests for this change. The "help sb" output is modified to reflect this rename, and state where the host and hostfs devices should be used. Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-06-12disk: default to HW partition 0 if not specifiedStephen Warren
Currently, get_device()/get_dev_hwpart() for MMC devices does not select an explicit HW partition unless the user explicitly requests one, i.e. by requesting device "mmc 0.0" rather than just "mmc 0". I think it makes more sense if the default is to select HW partition 0 (main data area) if the user didn't request a specific partition. Otherwise, the following happens, which feels wrong: Select HW partition 1 (boot0): mmc dev 0 1 Attempts to access SW partition 1 on HW partition 1 (boot0), rather than SW partition 1 on HW partition 0 (main data area): ls mmc 0:1 / With this patch, the second command above re-selects the main data area. Many device types don't support HW partitions at all, so if HW partition 0 is selected (either explicitly or as the default) and there's no select_hwpart function, we simply skip attempting to select a HW partition. Some MMC devices (i.e. SD cards) don't support HW partitions. However, this patch still works, since mmc_start_init() sets the current partition number to 0, and mmc_select_hwpart() succeeds if the requested partition is already selected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-05-23mmc: provide a select_hwpart implementation for get_device()Stephen Warren
This enables specifying which eMMC HW partition to target for any U-Boot command that uses the generic get_partition() function to parse its command-line arguments. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-23disk: support devices with HW partitionsStephen Warren
Some device types (e.g. eMMC) have hardware-level partitions (for eMMC, separate boot and user data partitions). This change allows the user to specify the HW partition they wish to access when passing a device ID to U-Boot Commands such as part, ls, load, ums, etc. The syntax allows an optional ".$hwpartid" to be appended to the device name string for those commands. Existing syntax, for MMC device 0, default HW partition ID, SW partition ID 1: ls mmc 0:1 / New syntax, for MMC device 0, HW partition ID 1 (boot0), SW partition ID 2: ls mmc 0.1:2 / For my purposes, this is most useful for the ums (USB mass storage gadget) command, but there's no reason not to allow the new syntax globally. This patch adds the core support infra-structure. The next patch will provide the implementation for MMC. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-03-17sandbox: Use os functions to read host device treeSimon Glass
At present we use U-Boot's filesystem layer to read the sandbox device tree, but this is problematic since it relies on a temporary feauture added there. Since we plan to implement proper block layer support for sandbox, change this code to use the os layer functions instead. Also use the new fdt_create_empty_tree() instead of our own code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: block driver using host file/device as backing storeHenrik Nordström
Provide a way to use any host file or device as a block device in U-Boot. This can be used to provide filesystem access within U-Boot to an ext2 image file on the host, for example. The support is plumbed into the filesystem and partition interfaces. We don't want to print a message in the driver every time we find a missing device. Pass the information back to the caller where a message can be printed if desired. Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Simon Glass <sjg@chromium.org> - Removed change to part.c get_device_and_partition() Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-07-22fs/ext4: fix log2blksz un-initialized error, by cacaulating its value from blkszLan Yixun (dlan)
The problem here is that uboot can't mount ext4 filesystem with commit "50ce4c07df1" applied. We use hard-coded "SECTOR_SIZE"(512) before this commit, now we introduce (block_dev_desc_t *)->log2blksz to replace this macro. And after we calling do_ls()->fs_set_blk_dev(), the variable log2blksz is not initialized, which it's not correct. And this patch try to solve the problem by caculating the value of log2blksz from variable blksz.
