path: root/disk
2009-05-15IDE: bail out of dev_print() for unknown device typesWolfgang Denk
Commit 574b319512 introduced a subtle bug by mixing a list of tests for "dev_desc->type" and "dev_desc->if_type" into one switch(), which then mostly did not work because "dev_desc->type" cannot take any "IF_*" type values. A later fix in commit 8ec6e332ea changed the switch() into testing "dev_desc->if_type", but at this point the initial test for unknown device types was completely lost, which resulted in output like that for IDE ports without device attached: Device 1: Model: Firm: Ser#: Type: # 1F # Capacity: not available This patch re-introduces the missing test for unknown device types. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Detlev Zundel <dzu@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-03-20vsprintf: pull updates from Linux kernelMike Frysinger
This brings in support for the %p modifier which allows us to easily print out things like ip addresses, mac addresses, and pointers. It also converts the rarely used 'q' length modifier to the common 'L' modifier when dealing with quad types. While this new code is a bit larger (~1k .text), most of it should be made up by converting the existing ip/mac address code to use format modifiers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-18disk: convert part_* files to COBJ-$(CONFIG_XXX) styleMike Frysinger
Move the CONFIG_XXX out of the part_XXX.c file and into Makefile to avoid pointless compiles. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-27part_efi: Fix partition size calculation due to inclusive ending LBA.Richard Retanubun
The ending LBA is inclusive. Hence, the partition size should be ((ending-LBA + 1) - starting-LBA) to get the proper partition size. This is confirmed against the results from the parted tool. (e.g. use parted /dev/sda -s unit S print) and observe the size. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-18Add support for CONFIG_EFI_PARTITION (GUID Partition Table)richardretanubun
The GUID (Globally Unique Identifier) Partition Table (GPT) is a part of EFI. See http://en.wikipedia.org/wiki/GUID_Partition_Table Based on linux/fs/partitions/efi.[ch] Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2008-09-22Add missing device types to dev_print() in part.cRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-09-09Fix dev_print when called from usb_stor_info (usb storage command)NĂ­colas Carneiro Lebedenco
Fix output of the usb storage command. It was printing "Device 0: not available" because IF_TYPE_USB was not included into the switch statement. Signed-off-by: Nicolas Lebedenco <nicolas.lebedenco@tasksistemas.com.br>
2008-06-03Fix incorrect switch for IF_TYPE in part.cTor Krill
Use correct field in block_dev_desc_t when writing interface type in dev_print. Error introduced in 574b3195. Also added fix from Martin Krause Signed-off-by: Tor Krill <tor@excito.com>
2008-05-09cosmetic: Adjust coding style for switch statements to be consistentDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-05-09Fix disk type output in disk/part.cDetlev Zundel
2008-03-26ata: add the support for SATA frameworkDave Liu
- add the SATA framework - add the SATA command line Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09disk/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04disk/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-06-06Coding Style cleanup; generate new CHANGELOG file.Wolfgang Denk
2007-05-18Reduce line lengths to 80 characters max.Peter Pearse
2007-05-09New board SMN42 branchPeter Pearse
2007-04-14Enable partition support with MMCHaavard Skinnemoen
Include implementations of init_part() and get_partition_info() when CONFIG_MMC is set. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-22[PATCH] get_dev() now unconditionally uses manual relocationStefan Roese
Since the relocation fix is not included yet and we're not sure how it will be added, this patch removes code that required relocation to be fixed for now. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] Fix relocation problem with "new" get_dev() functionStefan Roese
This patch enables the "new" get_dev() function for block devices introduced by Grant Likely to be used on systems that still suffer from the relocation problems (manual relocation neede because of problems with linker script). Hopefully we can resolve this relocation issue soon for all platform so we don't need this additional code anymore. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2005-02-24Cleanup USB and partition defineswdenk
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2002-03-08Initial revisionwdenk
2001-07-05Initial revisionwdenk
2001-03-29Initial revisionwdenk
