path: root/doc/README.at91-soc
2013-11-13at91: remove all occourances of CONFIG_AT91_LEGACYAndreas Bießmann
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-08-03README.at91-soc: remove AT91(RM9200) joining noticeAndreas Bießmann
Since all currently supported at91rm9200 boards are migrated to at91 support the joining notice can be removed. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-02-12prepare joining at91rm9200 into at91Jens Scharsig
* prepare joining at91 and at91rm9200 * add modified copy of soc files to cpu/arm920t/at91 to make possible to compile at91rm9200 boards in at91 tree instead of at91rm9200 * add header files with c structure defs for AT91 MC, ST and TC * the new cpu files are using at91 c structure soc access * please read README.soc-at91 for details Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
