path: root/doc/README.fsl-esdhc
2015-05-04mmc: fsl_esdhc: Add adapter card type identification supportYangbo Lu
Add adapter card type identification support by reading FPGA STAT_PRES1 register SDHC Card ID[0:2] bits. To use this function, define CONFIG_FSL_ESDHC_ADAPTER_IDENT. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> [York Sun: resolve conflicts in README.fsl-esdhc] Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-23mmc: fsl_esdhc: Add support to force VSELECT setOtavio Salvador
Some boards cannot do voltage negotiation but need to set the VSELECT bit forcely to ensure it to work at 1.8V. This commit adds CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT flag for this use. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-09-08esdhc: Add CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE macrosWang Huan
For LS102xA, the processor is in little-endian mode, while esdhc IP is in big-endian mode. CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE are added. So accessing ESDHC registers can be determined by ESDHC IP's endian mode. Signed-off-by: Alison Wang <alison.wang@freescale.com>
