path: root/doc/README.generic-board
2016-05-27Remove/update old generic-board documentation and warningSimon Glass
Remove the warning from the Makefile, since boards that do not use generic board will no longer build. Also update documentation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2015-05-27doc/README.generic-board: Trivial spell checkRicardo Ribalda
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-07-07cosmetic: doc: update README.generic-boardMasahiro Yamada
Now MIPS supports 'generic board' feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12doc: README.generic-board: Fix typoFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-04-17Start the deprecation process for generic boardSimon Glass
We should move forward to remove the old board init code. Add a prominent message to encourage maintainers to get started on this work. Signed-off-by: Simon Glass <sjg@chromium.org>
