path: root/doc/README.uniphier
2018-07-25ARM: uniphier: enable distro bootMasahiro Yamada
Switch to the distro boot for UniPhier platform. - Remove the environment vairalbes used to load images from raw block devices. - Keep the command to download images via tftp. This will be useful to boot the kernel when no valid kernel image is ready yet in the file system. - Use root.cpio.gz instead of root.cpio.uboot because we always know the file size of the init ramdisk; it is loaded via either a file system or network. - Rename fit_addr_r to kernel_addr_r, which the distro command checks to get the load address of FIT image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-15doc: fix incorrect usage of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in various documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-10-23doc: uniphier: add simple guide to Verified BootMasahiro Yamada
Add a simple documentation about how to use the Verified Boot on UniPhier boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-18ARM: uniphier: merge two defconfig files into uniphier_v7_defconfigMasahiro Yamada
The main difference between Pro4 and PXs2/LD6b is the Denali NAND IP version. This is now distinguished by DT. Merge the two defconfig files into uniphier_v7_defconfig. Update the README.uniphier too. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-26doc: uniphier: rework README.uniphierMasahiro Yamada
Rework the readme to reflect the latest boot mechanism on ARMv8 SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-26ARM: uniphier: remove SPL support for ARMv8 SoCsMasahiro Yamada
It has been a while since ARM Trusted Firmware supported UniPhier SoC family. U-Boot SPL was intended as a temporary loader that runs in secure world. It is a maintenance headache to support two different boot mechanisms. Secure firmware is realm of ARM Trusted Firmware and now U-Boot only serves as a non-secure boot loader for UniPhier ARMv8 SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: update README.uniphier for latest build instructionMasahiro Yamada
Since commit c0efc3140e75 ("ARM: uniphier: change CONFIG_SPL_PAD_TO to 128KB"), the u-boot.bin should be burned at the offset 0x20000. I missed to update README.uniphier in that commit. Now updating. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-22ARM: uniphier: add PXs3 SoC supportMasahiro Yamada
Initial support for PXs3 SoC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: uniphier: update doc/README.uniphierMasahiro Yamada
- Rephrase the toolchains section. Leave only Linaro toolchains since it is the most tested these days. - Add build instruction for ARMv8 SoC boards - Add information about "ddrmphy" command Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-03-24ARM: uniphier: switch to raw U-Boot imageMasahiro Yamada
Now everything is done to load a raw U-Boot proper image instead of an mkimage-processed one (as far as I tested on NAND, eMMC, NOR). The SPL already knows the load address of the U-Boot proper without parsing its uImage header because the load address is defined by CONFIG_SYS_TEXT_BASE, assuming that the two images are generated from the same build. My main motivation of this switch is to use u-boot-with-spl.bin, a concatenation of u-boot-spl.bin and u-boot.bin. (I wish there were a concatenation of u-boot-spl.bin and u-boot.img...) Anyway, this commit would be useful for one-shot image burn. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-24ARM: uniphier: fix README instruction for updating U-Boot via TFTPMasahiro Yamada
Commit 3cb9abc9c512 ("ARM: uniphier: update U-Boot file names in workflow") missed to update these two sentences. Fix them now. Replace u-boot-spl-dtb.bin and u-boot-dtb.img with u-boot-spl.bin and u-boot.img, respectively. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-09ARM: uniphier: document how-to-build for Ace and Sanji boardsMasahiro Yamada
2016-02-29ARM: uniphier: merge two defconfig filesMasahiro Yamada
PH1-Pro5 support and ProXstream2/PH1-LD6b support can coexist in one image and there is bit more room in SPL to accommodate all of them. Merge uniphier_pro5_defconfig into uniphier_pxs2_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: add emmcupdate commandMasahiro Yamada
The Boot ROM expects the boot image (SPL) in the Boot Partition 1. So, updating images involves the hardware partition switch. It might be a bit advanced for some users. To be user-friendly, this commit adds a useful command to update the images; just put SPL and U-Boot proper into the public directory of the TFTP server and execute "run emmcupdate" from the command line. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29mmc: uniphier: add driver for UniPhier SD/MMC host controllerMasahiro Yamada
Add a driver for the on-chip SD/eMMC host controller used by UniPhier SoC family. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29gpio: uniphier: add driver for UniPhier GPIO controllerMasahiro Yamada
This GPIO controller device is used on UniPhier SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-14ARM: uniphier: update U-Boot file names in workflowMasahiro Yamada
Since commit ad1ecd2063da ("fdt: Build a U-Boot binary without device tree") and commit 03c25bcd263a ("fdt: Build an SPL binary without device tree"), we can use shorter file names for the output images. The default configuration for UniPhier SoCs enables CONFIG_OF_SEPARATE and CONFIG_SPL_OF_CONTROL. In this case, spl/u-boot-spl.bin is the same as spl/u-boot-spl-dtb.bin. Likewise, u-boot.img is the same as as u-boot-dtb.img. So, this change of the flow has no impact. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-13ARM: uniphier: fix recommended board setting in documentMasahiro Yamada
The mem_is_flash() in arch/arm/mach-uniphier/micro-support_card.c writes/reads the tail of each NOR flash bank to check if the device really resides there. If CS1_SPLIT were enabled, the support card would always require two NOR flash devices to be inserted for the correct NOR detection. This is not probably what we want. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: rename rest of defconfig filesMasahiro Yamada
Rename rest of defconfig files of UniPhier SoC family to have the prefix uniphier_. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: support ProXstream2, PH1-LD6b boards in single defconfigMasahiro Yamada
These boards are similar enough to be supported in a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: merge ph1_ld4_defconfig and ph1_sld8_defconfigMasahiro Yamada
These two are similar enough to be merged into a single defconfig file. Distinguish one from another by "DEVICE_TREE" from the command line. The how-to-build in doc/README.uniphier should be also updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-10-15ARM: uniphier: fix address mapping in README.uniphierMasahiro Yamada
2015-09-25ARM: uniphier: add ProXstream2 and PH1-LD6b supportMasahiro Yamada
The DDR SDRAM initialization code has not been mainlined yet, but U-Boot proper should work. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25ARM: uniphier: add PH1-Pro5 supportMasahiro Yamada
2015-08-31ARM: uniphier: enable SPL_OF_CONTROLMasahiro Yamada
Device Tree really improves code maintainability and is now available for SPL too. This is the state-of-the-art implementation in U-boot. The board files (platform data) are no longer needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-07-23ARM: UniPhier: document reference support cardMasahiro Yamada
2015-07-23ARM: UniPhier: add PH1-sLD3 SoC supportMasahiro Yamada
The init code for UMC (Unified Memory Controller) and PLL has not been mainlined yet, but U-boot proper should work. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-01usb: UniPhier: add UniPhier on-chip xHCI host driver supportMasahiro Yamada
Support xHCI host driver used on Panasonic UniPhier platform. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-07ARM: UniPhier: add a simple README file for UniPhier platformMasahiro Yamada
