path: root/doc
2013-01-14Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-14Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-13mx31/mx35/mx51/mx53/mx6: add watchdogTroy Kisky
Use a common watchdog driver for all these cpus. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-08EXYNOS5: FDT: Add SPI device node dataRajeshwari Shinde
Add SPI device node data for exynos. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add sound device node dataRajeshwari Shinde
Add sound device node data for exynos Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-21Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-17usb documentation: fix typoRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
2012-12-13env: Add a silent env handlerJoe Hershberger
The silent variable now updates the global data flag anytime it is changed as well as after the env relocation (in case its value is different from the default env in such cases as NAND env) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13gpt:doc: GPT (GUID Partition Table) documentationLukasz Majewski
Documentation of the GPT format. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-12-06cbfs: Add docbook templateSimon Glass
This adds a docbook template for fs, and makes CBFS use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-26nand: Add torture featureBenoît Thébaudeau
This patch adds a NAND Flash torture feature, which is useful as a block stress test to determine if a block is still good and reliable (or should be marked as bad), e.g. after a write error. This code is ported from mtd-utils' lib/libmtd.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-26spl/85xx: new SPL supportScott Wood
Update CONFIG_RAMBOOT and CONFIG_NAND_SPL references to accept CONFIG_SPL and CONFIG_SPL_BUILD, respectively. CONFIG_NAND_SPL can be removed once the last mpc85xx nand_spl target is gone. CONFIG_RAMBOOT will need to remain for other use cases, but it doesn't seem right to overload it for meaning SPL as well as nand_spl does. Even if it's somewhat appropriate for the main u-boot, the SPL itself isn't (necessarily) ramboot, and we don't have separate configs for SPL and main u-boot. It was also inconsistent, as other platforms such as mpc83xx didn't use CONFIG_RAMBOOT in this way. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2012-11-25Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2012-11-19tegra: fdt: Add LCD definitions for TegraSimon Glass
Add LCD definitions and also a proposed binding for LCD displays. The PWM is as per what will likely be committed to linux-next soon. The displaymode binding comes from a proposal here: http://lists.freedesktop.org/archives/dri-devel/2012-July/024875.html The panel binding is new, and fills a need to specify the panel timings and other tegra-specific information. Should a binding appear that allows the pwm to handle this automatically, we can revisit this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add pwm binding and nodeSimon Glass
This binding will apparently soon be in linux-next. Bring it in now since we need to do something, and may as well try to target what Linux will have. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19mx5: Mark lowlevel_init board-specific codeBenoît Thébaudeau
The mx5 lowlevel_init.S contains board-specific code based on the reference design. Let's keep it since it avoids creating new lowlevel_init files and it may be used by many boards. But add a config to make it optional in order not to cause issues on boards not following this part of the reference design. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Matt Sealey <matt@genesi-usa.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-11-02git-mailrc: Change x86 maintainer to SimonSimon Glass
Grame is still listed since he has agreed to continue with some review. Also add an alias to shorten things. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
2012-10-29fs: separate CONFIG_FS_{FAT, EXT4} from CONFIG_CMD_{FAT, EXT*}Stephen Warren
This makes the FAT and ext4 filesystem implementations build if CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the filesystems to be built separately from the filesystem-specific commands that use them. This paves the way for the creation of filesystem-generic commands that used the filesystems, without requiring the filesystem- specific commands. Minor documentation changes are made for this change. The new config options are automatically selected by the old config options to retain backwards-compatibility. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-26arm: arm925t: remove SX1 boardAlbert ARIBAUD
SX1 does not build properly by itself, is not built as part of MAKEALL arm or MAKEALL -a arm, and is only present in Makefile, not boards.cfg. As it also has no entry in MAINTAINERS, it is orphan and non-functional. Remove it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-26arm: Remove support for lpc2292Marek Vasut
This stuff has been rotting in the tree for a year now. Remove it. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-24ColdFire: Add Freescale MCF54418TWR ColdFire development board supportAlison Wang
Add Freescale MCF54418TWR ColdFire development board support. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-22Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc85xx: Rewrite spin table to comply with ePAPR v1.1York Sun
Move spin table to cached memory to comply with ePAPR v1.1. Load R3 with 64-bit value if CONFIG_SYS_PPC64 is defined. 'M' bit is set for DDR TLB to maintain cache coherence. See details in doc/README.mpc85xx-spin-table. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc8xxx: Add auto select bank interleaving modeYork Sun
Based on populated DIMMs, automatically select from cs0_cs1_cs2_cs3 or cs0_cs1 interleaving, or non-interleaving if not available. Fix the message of interleaving disabled if controller interleaving is enabled but DIMMs don't support it. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22board/freescale/common: VSC3316/VSC3308 initialization codeShaveta Leekha
Add code for configuring VSC3316/3308 crosspoint switches Add README to understand the APIs - VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22kerneldoc: tmpl: Implement template for LG-arraysMarek Vasut
Implement kerneldoc template for linker-generated arrays. This is the first template in U-Boot that is used to generate kerneldoc style documentation. This template is very basic. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: drivers/serial/serial_lh7a40x.c Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17kerneldoc: stdio: tmpl: Add stdio templateMarek Vasut
Add STDIO documentation template. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> [trini: Fix DOCBOOKS line as we don't have linker_lists yet] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-16Remove lh7a40x cpu and serial driverAlbert ARIBAUD
Since commit 957731ed (ARM: remove broken "lpd7a40x" boards), lh7a40x cpu and serial driver have become unused. Remove them. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-15kerneldoc: Add myself to the git-mailrc for kerneldocMarek Vasut
Add entry for kerneldoc into the git-mailrc pointing to the U-Boot ML and myself. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-15kerneldoc: Add nicer CSS stylesheet for HTML docsMarek Vasut
Import basic CSS stylesheet for the HTML documentation. The base for the stylesheet is taken from: http://ds9a.nl/docbook/minimal-page.html I customized the CSS a bit further, for example to add curvy corners to example section and change the tint of gray. The HTML documentation does not look that crude anymore. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-15kerneldoc: Implant DocBook from Linux kernelMarek Vasut
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation. It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts. It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches. Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel. Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build. Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200 Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200 Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400 Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-03ARM : Add support for MINI2440 (s3c2440).Gabriel Huau
Support of the MINI2440 board from FriendlyARM from an old version of u-boot : http://repo.or.cz/r/u-boot-openmoko/mini2440.git Currently, supporting only boot from NOR. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-10-03doc/git-mailrc: Add 'rmobile' aliasNobuhiro Iwamatsu
2012-10-03rmobile: Add READMENobuhiro Iwamatsu
This add README of Renesas RMOBILE. Based doc/README.omap3. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Tom Rini <trini@ti.com>
2012-09-27Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2012-09-27SPL: Add support for loading image from ram in SPL.Pavel Machek
Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27PXE: FDT: Add support for fdt in PXEChander Kashyap
Now DT support is becoming common for all new SoC's. Hence it is better to have option for getting specific FDT from the remote server. This patch adds support for new label i.e. 'fdt'. This will allow to retrieve 'fdt blob' from the remote server. This patch take care for the following scenarios. The usage of fdt is optional. The 'fdt blob' can be retrieved from tftp or can be available locally or can be absent. If 'fdt_addr_r' environment variable is set and 'fdt' label is defined retrieve 'fdt blob' from tftp. 'fdt_addr_r' is then passed along bootm command. If 'fdt_addr' is set and 'fdt blob' is not retrieved from the tftp pass 'fdt_addr' to bootm command. In this case 'fdt blob' will be available at 'fdt_addr'. If 'fdt_addr' is not set and 'fdt blob' is not retrieve from tftp pass NULL to boot command. In this case 'fdt blob' is not required and absent. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
