include/configs/at91sam9261ek.h
This patch adds support for the AT91SAM9G20-EK board. It comes from the patch
u-boot-1.1.5_atmel_1.6.diff, courtesy of linux4sam.org.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add support for Wind River's SBC8641D reference board.
Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Jon Loeliger <jdl@freescale.com>
Update the README for DDR ECC, change the name
to README.mpc83xx.ddrecc.
Signed-off-by: Dave Liu <daveliu@freescale.com>
MPC8323E based board with 64MB fixed SDRAM, 16MB flash,
five 10/100 ethernet ports connected via an ICPlus IP175C
switch, one PCI slot, and serial. Features not supported
in this patch are SD card interface, 2 USB ports, and the
two phone ports.
Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com>
When the rev2.x silicon mount on the MPC8360EMDS baord,
and if you are using the u-boot version after the commit
3fc0bd159103b536e1c54c6f4457a09b3aba66ca.
to make the ethernet interface usable, we have to setup
the jumpers correctly.
As suggested by Eugene O'Brien <Eugene.O'Brien@advantechamt.com>,
here an updated Bamboo README.
- now the Flash ST M29W040B is supported (not tested)
- fix the "led" command
- fix compile error, if BUILD_DIR is used
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
e600 does not have a bootpg restriction.
Move the version string to beginning of image at fff00000.
Resetvec.S is not needed.
Update flash copy instructions.
Add tftpflash env variable
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
Move the 8641HPCN's PIXIS code to the new directory
board/freescale/common/ as it will be shared by
future boards not in the same processor family.
Write a "pixis_reset" command that utilizes the FPGA
reset sequencer to support alternate soft-reset options
such as using the "alternate" flash bank, enabling
the watch dog, or choosing different CPU frequencies.
Add documentation for the pixis_reset to README.mpc8641hpcn.
Signed-off-by: Haiying Wang <haiying.wang@freescale.com>
Added information about usage of NetConsole on systems where the -l and -p
switches are mutually exclusive.
Signed-off-by: Igor Marnat <marny@rambler.ru>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Add support for the MPC8349E-mITX-GP, a stripped-down version of the
MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in
HRCW is 0) for the ITX and a README for the ITX and the ITX-GP.
I've redone the SBC8349 support to match git-current, which
incorporates all the MPC834x updates from Freescale since the 1.1.6
release, including the DDR changes.
I've kept all the SBC8349 files as parallel as possible to the
MPC8349EMDS ones for ease of maintenance and to allow for easy
inspection of what was changed to support this board. Hence the SBC8349
U-Boot has FDT support and everything else that the MPC8349EMDS has.
Fortunately the Freescale updates added support for boards using CS0,
but I had to change spd_sdram.c to allow for board specific settings for
the sdram_clk_cntl (it is/was hard coded to zero, and that remains the
default if the board doesn't specify a value.)
Hopefully this should be mergeable as-is and require no whitespace
cleanups or similar, but if something doesn't measure up then let me
know and I'll fix it.
Thanks,
Paul.
Add the MPC832XEMDS board readme
The conflicts due to a new mpc7448 p3m7448 board is in the main tree.
Merge branch 'master' into hpc2
MAKEALL
cpu/74xx_7xx/cpu.c
cpu/74xx_7xx/cpu_init.c
cpu/74xx_7xx/speed.c
