path: root/doc
2016-11-07Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-11-07dt: net: add DWC EQoS bindingStephen Warren
The Synopsys DWC EQoS is a configurable Ethernet MAC/DMA IP block which supports multiple options for bus type, clocking and reset structure, and feature list. This patch imports the binding from the Linux kernel, including my V3 patch to extend the binding to cover the Tegra186, which is applied for next-20160912. So far, my changes have been acked by Lars Persson, the original author of the binding. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-06mkimage: Allow including a ramdisk in FIT auto modeTomeu Vizoso
Adds -i option that allows specifying a ramdisk file to be added to the FIT image when we are using the automatic FIT mode (no ITS file). This makes adding Depthcharge support to LAVA much more convenient, as no additional configuration files need to be kept around in the machine that dispatches jobs to the boards. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Simon Glass <sjg@chromium.org> Cc: Matt Hart <matthew.hart@linaro.org> Cc: Neil Williams <codehelp@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-05doc: update README.arm64Andre Przywara
This file apparently hasn't seen an update in a while, so just sync it with reality. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2016-10-30rockchip: doc: add GPT partition layoutJacob Chen
A simple introduction. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-29MAINTAINERS: Update Jagan's emailJagan Teki
Signed-off-by: Jagan Teki <jagan@openedev.com>
2016-10-18ARM: uniphier: update doc/README.uniphierMasahiro Yamada
- Rephrase the toolchains section. Leave only Linaro toolchains since it is the most tested these days. - Add build instruction for ARMv8 SoC boards - Add information about "ddrmphy" command Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-18ARM: dts: uniphier: sync DT with latest LinuxMasahiro Yamada
2016-10-12x86: coreboot: Convert to use DM coreboot video driverBin Meng
This converts coreboot to use DM framebuffer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: doc: Correct qfw command exampleBin Meng
The kernel load address for zboot should be 0x1000000. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: doc: Document coreboot framebuffer driver issue on QEMUBin Meng
For some unknown reason, coreboot framebuffer driver never works on QEMU since day 1. It seems the driver only works on real hardware. Document this issue. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-07power: pmic: add Ricoh RN5T567 PMIC supportStefan Agner
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used on Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07dm: imx: serial: support device treeStefan Agner
Support instatiation through device tree. Also parse the fsl,dte-mode property to determine whether DTE mode shall be used. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06doc: typo fix addess -> addressJelle van der Waa
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
2016-10-06README: Fix CONFIG_SYS_NAND_MAX_DEVICE typoSimon Glass
This should be CONFIG_SYS_MAX_NAND_DEVICE. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <oss@buserror.net> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop CONFIG_MPC8349ADSSimon Glass
This option is not used now. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06README: Drop README.imx31Simon Glass
The only content of this file is CONFIG options which are no-longer present in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06atmel: Drop README.at91-socSimon Glass
This issue covered by this doc appears to be fixed, so let's remove the README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com> Acked-by: Andreas Bießmann <andreas@biessmann.org>
2016-10-06README: Drop unused JFFS2 optionsSimon Glass
There appear to be neither implemented nor used. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-04README.imx6: Fix Boundary Devices nameFabio Estevam
Correct name is "Boundary Devices". Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-10-02doc: Update info on using AM33xx secure devices from TIAndrew F. Davis
Add a section describing the additional boot types used on AM33xx secure devices. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-21boston: Introduce support for the MIPS Boston development boardPaul Burton
This patch introduces support for building U-Boot to run on the MIPS Boston development board. This is a board built around an FPGA & an Intel EG20T Platform Controller Hub, used largely as part of the development of new CPUs and their software support. It is essentially the successor to the older MIPS Malta board. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-07pxe: Modify README to add the description about FIT imageWenbin Song
Use environment variable "kernel_addr_r" to indicate the location in RAM where FIT image will be stored. Use label command "kernel" to indicate which <path> the FIT image at. Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
2016-09-06regulator: fixed: obey startup delayJohn Keeping
When enabling a fixed regulator, it may take some time to rise to the correct voltage. If we do not delay here then subsequent operations will fail. Signed-off-by: John Keeping <john@metanate.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-26treewide: fix "followings" to "following"Masahiro Yamada
Most of them are my mistakes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-16x86: Mention running U-Boot in 64-bit mode in the READMESimon Glass
This feature is not supported. Document this, and add some details on how it might be implemented. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Add a reference to README.efiSimon Glass
UEFI is commonly used on x86. Add a reference to U-Boot's support for this in the x86 README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: Mention how to boot a 64-bit kernel from U-BootSimon Glass
The README indicates that this is not supported, but this is no-longer true. Update the text to indicate this and describe the FIT changes required. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: doc: Add note about the debug FSP usage on BayTrailStefan Roese
The debug FSP image is bigger in size than the normal FSP image. This patch adds a small description on how to use this FSP debug version by changing CONFIG_FSP_ADDR. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15atmel: Bring in at91 pio4 device tree file and bindingsWenyou Yang
Bring in required device tree file and bindings from Linux. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15i2c: atmel: DT binding for i2c driverSongjun Wu
DT binding documentation for atmel i2c driver. Signed-off-by: Songjun Wu <songjun.wu@atmel.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2016-08-08gpio: Add driver for TI PCF8575 I2C GPIO expanderVignesh R
TI's PCF8575 is a 16-bit I2C GPIO expander.The device features a 16-bit quasi-bidirectional I/O ports. Each quasi-bidirectional I/O can be used as an input or output without the use of a data-direction control signal. The I/Os should be high before being used as inputs. Read the device documentation for more details[1]. This driver is based on pcf857x driver available in Linux v4.7 kernel. It supports basic reading and writing of gpio pins. [1] http://www.ti.com/lit/ds/symlink/pcf8575.pdf Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-08-06Merge git://git.denx.de/u-boot-rockchipTom Rini
2016-08-05rockchip: add support for rk3288 miniarm boardXu Ziyuan
Miniarm is a rockchip rk3288 based development board, which has lots of interface such as HDMI, USB, micro-SD card, Audio etc. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-04dt-bindings: add Tegra186 BPMP I2C bindingStephen Warren
In Tegra186, the BPMP (Boot and Power Management Processor) owns certain HW devices, such as the I2C controller for the power management I2C bus. Software running on other CPUs must perform IPC to the BPMP in order to execute transactions on that I2C bus. This binding describes an I2C bus that is accessed in such a fashion. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04dt-bindings: allow child nodes inside the Tegra BPMPStephen Warren
The BPMP implements some services which must be represented by separate nodes. For example, it can provide access to certain I2C controllers, and the I2C bindings represent each I2C controller as a device tree node. Update the binding to describe how the BPMP supports this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04ARM: tegra: add BPMP DT bindingsStephen Warren
The Tegra BPMP (Boot and Power Management Processor) is a separate auxiliary CPU embedded into Tegra to perform power management work, and controls related features such as clocks, resets, power domains, PMIC I2C bus, etc. These bindings dictate how to represent the BPMP in device tree. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-04ARM: tegra: adapt to latest HSP DT bindingStephen Warren
The DT binding for the Tegra186 HSP module apparently wasn't quite final when I posted initial U-Boot support for it. Add the final DT binding doc and adapt all code and DT files to match it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-02MAINTAINERS, git-mailrc: Update the mmc maintainerJaehoon Chung
Update the mmc maintainer from Pantelis to me. Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-31Drop references to MAKEALL in the documentationSimon Glass
It is confusing to mention MAKEALL when it is not the normal way of building U-Boot anymore. Update the documentation to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-31rockchip: add support for rk3288 PopMetal boardjk.kernel@gmail.com
PopMetal is a rockchip rk3288 based board made by ChipSpark, which has many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and Gigabit Ethernet. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: add basic support for fennec-rk3288 boardjk.kernel@gmail.com
Fennec is a RK3288-based development board with 2 USB ports, HDMI, micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access to display pins, I2C, SPI, UART and GPIOs. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-07-25rockchip: update fastboot usageXu Ziyuan
Introduce how to use fastboot feature on rk3288. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add basic support for evb-rk3288 boardXu Ziyuan
evb-3288 board RK3288-based development board with 2 USB ports, HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to display pins, I2C, SPI, UART and GPIOs. This add some basic files required to allow the board to output serial messaged and can run command(mmc info etc). evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add option to change method of loading u-bootXu Ziyuan
If we would like to boot from SD card, we have to implement mmc driver in SPL stage, and get a slightly large SPL binary. Rockchip SoC's bootrom code has the ability to load spl and u-boot, then boot. If CONFIG_ROCKCHIP_SPL_BACK_TO_BROM is enabled, the spl will return to bootrom in board_init_f(), then bootrom loads u-boot binary. Loading sequence after rework: bootrom ==> spl ==> bootrom ==> u-boot Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed up spelling of U-Boot, boorom, opinion->option, Rochchip: Signed-off-by: Simon Glass <sjg@chromium.org>
