Update CHANGELOG, fix minor coding stylke issue. Update Makefile.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
This will make CONFIG_NET_MULTI the only net driver configuration and
we'll be able to remove this option.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Also conditionally add ncb.o to OBJ_FILES list
Mflash is fusion memory device mainly targeted consumer eletronic and
mobile phone.
Internally, it have nand flash and other hardware logics and supports
some different operation (ATA, IO, XIP) modes.
IO mode is custom mode for the host that doesn't have IDE interface.
(Many mobile targeted SoC doesn't have IDE bus)
This driver support mflash IO mode.
Followings are brief descriptions about IO mode.
1. IO mode based on ATA protocol and uses some custom command. (read
confirm, write confirm)
2. IO mode uses SRAM bus interface.
Signed-off-by: unsik Kim <donari75@gmail.com>
Legacy NAND is marked for feature removal after April 2009 (i.e. this
upcoming release). There are still several boards that reference it
(though many do so only for disk-on-chip support which has been silently
disabled for a while now). These boards will now fail to build
with #error, though the code is still there if the user removes #error.
The plan is to remove the code outright in the next release, along with
any board code that refers to it (such as board/esd/common/auto_update.c).
Also, remove the legacy NAND API description from README.nand.
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Announce removal of all non-GPL or GPL-incompatible files
after August 2009.
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed.
The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board.
It is essentially the same, with a few minor differences.
Here is the chip page on Atmel website:
http://www.atmel.com/dyn/products/product_card.asp?part_id=4337
Signed-off-by: Justin Waters <justin.waters@timesys.com>
CC: Ben Warren <biggerbadderben@gmail.com>
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
The new environment variable "korat_usbcf" selects the USB
port used by the Korat board's CompactFlash controller.
Signed-off-by: Larry Johnson <lrj@acm.org>
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here:
http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Add Pandora support.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Add EVM board support.
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
Add Overo board support.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
Add BeagleBoard support, common power code and README.
The NMDK8815 board is distributed by ST Microelectornics.
Other (proprietary) code must be run to unlock the CPU before
U-Boot runs. doc/README.nmdk8815 outlines the boot sequence.
This is the initial port, with basic infrastructure and
a working serial port.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
This patch adds support for the kmeter1 board from Keymile,
based on a Freescale MPC8360 CPU.
- serial console on UART 1
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- Ethernet RMII Mode over UCC4
- PHY SMSC LAN8700
Acked-by: Andy Fleming <afleming@freescale.com>
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This
board boots from NAND devices and is configureable for either large or small
page devices. The board supports non-soldered DDR2, one ethernet port, a
Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected
to the eLBC providing glue logic to a TMS320C67xx DSP.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
At91sam9xe is basically an at91sam9260 with embedded flash. We can manage
it as another entry for at91sam9260 in the Makefile.
Check documentation at :
http://www.atmel.com/dyn/products/product_card.asp?part_id=4263
board/atmel/atngw100/atngw100.c
board/atmel/atstk1000/atstk1000.c
cpu/at32ap/at32ap700x/gpio.c
include/asm-avr32/arch-at32ap700x/clk.h
include/configs/atngw100.h
include/configs/atstk1002.h
include/configs/atstk1003.h
include/configs/atstk1004.h
include/configs/atstk1006.h
include/configs/favr-32-ezkit.h
include/configs/hammerhead.h
include/configs/mimc200.h
While the doc/README.NetConsole does have a snippet for people to
create their own netcat script, it's a lot easier to make a simple
dedicated script and tell people to use it.
Also spruce it up a bit to make it user friendly.
Modifications to support console multiplexing. This is controlled using
CONFIG_SYS_CONSOLE_MUX in the board configuration file.
This allows a user to specify multiple console devices in the environment
with a command like this: setenv stdin serial,nc. As a result, the user can
enter text on both the serial and netconsole interfaces.
All devices - stdin, stdout and stderr - can be set in this manner.
1) common/iomux.c and include/iomux.h contain the environment setting
implementation.
2) doc/README.iomux contains a somewhat more detailed description.
3) The implementation in (1) is called from common/cmd_nvedit.c to
handle setenv and from common/console.c to handle initialization of
input/output devices at boot time.
4) common/console.c also contains the code needed to poll multiple console
devices for input and send output to all devices registered for output.
5) include/common.h includes iomux.h and common/Makefile generates iomux.o
when CONFIG_SYS_CONSOLE_MUX is set.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
This patch adds the possiblity to choose the media where the environment will
be located. This allow to choose this fundamental configuration without editing
config files.
Documentation file added.
Acked-by: Stelian Pop <stelian@popies.net>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
I made some updates to the code that didn't make it into the
README - fix this
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- PHY SMSC LAN8700
This patch creates a memory map with all the devices
in 36-bit physical space, in addition to the 32-bit map.
The CCSR relocation is moved (again, sorry) to
allow for the physical address to be 36 bits - this
requires translation to be enabled. With 36-bit physical
addressing enabled, we are no longer running with VA=PA
translations. This means we have to distinguish between
the two in the config file. The existing region name is
used to indicate the virtual address, and a _PHYS variety
is created to represent the physical address.
Large physical addressing is not enabled by default.
Set CONFIG_PHYS_64BIT in the config file to turn this on.
The memory map on the 8641hpcn is modified to look more like
the 85xx boards; this is a step towards a more standardized
layout going forward. As part of this change, we now relocate
the flash.
The regions for some of the mappings were far larger than they
needed to be. I have reduced the mappings to match the
actual sizes supported by the hardware.
In addition I have removed the comments at the head
of the BAT blocks in the config file, rather than updating
them. These get horribly out of date, and it's a simple
matter to look at the defines to see what they are set to
since everything is right here in the same file.
Documentation has been changed to reflect the new map, as this
change is user visible, and affects the OS which runs post-uboot.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
