path: root/doc
2013-03-04kerneldoc: Add Sonic Zhang to alias bfin in git-mailrc.Sonic Zhang
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-01Add README for the "Falcon" modeStefano Babic
Simple howto to add support to a board for booting the kernel from SPL ("Falcon" mode). Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-30README.fsl-ddr typos and update to reflect hotkeyJames Yang
Documentation fix to README.fsl-ddr to fix typos and to reflect use of 'd' hotkey to enter the FSL DDR debugger. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30Add copy command to FSL DDR interactiveJames Yang
Add copy command which allows copying of DIMM/controller settings. This saves tedious retyping of parameters for each identical DIMM or controller. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/mpc8xxx: Enable entering DDR debugging by key pressYork Sun
Using environmental variable "ddr_interactive" to activate interactive DDR debugging seomtiems is not enough. For example, after updating SPD with a valid but wrong image, u-boot won't come up due to wrong DDR configuration. By enabling key press method, we can enter debug mode to have a chance to boot without using other tools to recover the board. CONFIG_FSL_DDR_INTERACTIVE needs to be defined in header file. To enter the debug mode by key press, press key 'd' shortly after reset, like one would do to abort auto booting. It is fixed to lower case 'd' at this moment. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/b4860qds: Added Support for B4860QDSYork Sun
B4860QDS is a high-performance computing evaluation, development and test platform supporting the B4860 QorIQ Power Architecture processor. B4860QDS Overview ------------------ - DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 4 GB of memory in two ranks of 2 GB. - DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 2 GB of memory. Single rank. - SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point 16x16 switch VSC3316 - SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point 8x8 switch VSC3308 - USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode. - B4860 UART port is available over USB-to-UART translator USB2SER or over RS232 flat cable. - A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 copper connectors for Stand-alone mode and to the 1000Base-X over AMC MicroTCA connector ports 0 and 2 for AMC mode. - The B4860 configuration may be loaded from nine bits coded reset configuration reset source. The RCW source is set by appropriate DIP-switches: - 16-bit NOR Flash / PROMJet - QIXIS 8-bit NOR Flash Emulator - 8-bit NAND Flash - 24-bit SPI Flash - Long address I2C EEPROM - Available debug interfaces are: - On-board eCWTAP controller with ETH and USB I/F - JTAG/COP 16-pin header for any external TAP controller - External JTAG source over AMC to support B2B configuration - 70-pin Aurora debug connector - QIXIS (FPGA) logic: - 2 KB internal memory space including - IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK, DDRCLK1, 2 and RTCCLK. - Two 8T49N222A SerDes ref clock devices support two SerDes port clocks - total four refclk, including CPRI clock scheme Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-28doc/README.fec_mxc: add documentationTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-01-16README.mips: update known issues and TODOsDaniel Schwierzeck
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-01-16README.qemu-mips: move README file from board to doc directoryDaniel Schwierzeck
2013-01-14Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-14Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-13mx31/mx35/mx51/mx53/mx6: add watchdogTroy Kisky
Use a common watchdog driver for all these cpus. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-08EXYNOS5: FDT: Add SPI device node dataRajeshwari Shinde
Add SPI device node data for exynos. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add sound device node dataRajeshwari Shinde
Add sound device node data for exynos Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-21Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-17usb documentation: fix typoRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
2012-12-13env: Add a silent env handlerJoe Hershberger
The silent variable now updates the global data flag anytime it is changed as well as after the env relocation (in case its value is different from the default env in such cases as NAND env) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13gpt:doc: GPT (GUID Partition Table) documentationLukasz Majewski
Documentation of the GPT format. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-12-06cbfs: Add docbook templateSimon Glass
This adds a docbook template for fs, and makes CBFS use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-26nand: Add torture featureBenoît Thébaudeau
This patch adds a NAND Flash torture feature, which is useful as a block stress test to determine if a block is still good and reliable (or should be marked as bad), e.g. after a write error. This code is ported from mtd-utils' lib/libmtd.c. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> [scottwood@freescale.com: removed unnec. ifdef and unwrapped error strings] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-26spl/85xx: new SPL supportScott Wood
Update CONFIG_RAMBOOT and CONFIG_NAND_SPL references to accept CONFIG_SPL and CONFIG_SPL_BUILD, respectively. CONFIG_NAND_SPL can be removed once the last mpc85xx nand_spl target is gone. CONFIG_RAMBOOT will need to remain for other use cases, but it doesn't seem right to overload it for meaning SPL as well as nand_spl does. Even if it's somewhat appropriate for the main u-boot, the SPL itself isn't (necessarily) ramboot, and we don't have separate configs for SPL and main u-boot. It was also inconsistent, as other platforms such as mpc83xx didn't use CONFIG_RAMBOOT in this way. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2012-11-25Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2012-11-19tegra: fdt: Add LCD definitions for TegraSimon Glass
Add LCD definitions and also a proposed binding for LCD displays. The PWM is as per what will likely be committed to linux-next soon. The displaymode binding comes from a proposal here: http://lists.freedesktop.org/archives/dri-devel/2012-July/024875.html The panel binding is new, and fills a need to specify the panel timings and other tegra-specific information. Should a binding appear that allows the pwm to handle this automatically, we can revisit this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: fdt: Add pwm binding and nodeSimon Glass
This binding will apparently soon be in linux-next. Bring it in now since we need to do something, and may as well try to target what Linux will have. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19mx5: Mark lowlevel_init board-specific codeBenoît Thébaudeau
The mx5 lowlevel_init.S contains board-specific code based on the reference design. Let's keep it since it avoids creating new lowlevel_init files and it may be used by many boards. But add a config to make it optional in order not to cause issues on boards not following this part of the reference design. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Matt Sealey <matt@genesi-usa.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-11-02git-mailrc: Change x86 maintainer to SimonSimon Glass
Grame is still listed since he has agreed to continue with some review. Also add an alias to shorten things. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
2012-10-29fs: separate CONFIG_FS_{FAT, EXT4} from CONFIG_CMD_{FAT, EXT*}Stephen Warren
This makes the FAT and ext4 filesystem implementations build if CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the filesystems to be built separately from the filesystem-specific commands that use them. This paves the way for the creation of filesystem-generic commands that used the filesystems, without requiring the filesystem- specific commands. Minor documentation changes are made for this change. The new config options are automatically selected by the old config options to retain backwards-compatibility. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-26arm: arm925t: remove SX1 boardAlbert ARIBAUD
SX1 does not build properly by itself, is not built as part of MAKEALL arm or MAKEALL -a arm, and is only present in Makefile, not boards.cfg. As it also has no entry in MAINTAINERS, it is orphan and non-functional. Remove it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-26arm: Remove support for lpc2292Marek Vasut
This stuff has been rotting in the tree for a year now. Remove it. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-24ColdFire: Add Freescale MCF54418TWR ColdFire development board supportAlison Wang
Add Freescale MCF54418TWR ColdFire development board support. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-22Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc85xx: Rewrite spin table to comply with ePAPR v1.1York Sun
Move spin table to cached memory to comply with ePAPR v1.1. Load R3 with 64-bit value if CONFIG_SYS_PPC64 is defined. 'M' bit is set for DDR TLB to maintain cache coherence. See details in doc/README.mpc85xx-spin-table. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc8xxx: Add auto select bank interleaving modeYork Sun
Based on populated DIMMs, automatically select from cs0_cs1_cs2_cs3 or cs0_cs1 interleaving, or non-interleaving if not available. Fix the message of interleaving disabled if controller interleaving is enabled but DIMMs don't support it. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22board/freescale/common: VSC3316/VSC3308 initialization codeShaveta Leekha
Add code for configuring VSC3316/3308 crosspoint switches Add README to understand the APIs - VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22kerneldoc: tmpl: Implement template for LG-arraysMarek Vasut
Implement kerneldoc template for linker-generated arrays. This is the first template in U-Boot that is used to generate kerneldoc style documentation. This template is very basic. Signed-off-by: Marek Vasut <marex@denx.de>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: drivers/serial/serial_lh7a40x.c Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17kerneldoc: stdio: tmpl: Add stdio templateMarek Vasut
Add STDIO documentation template. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> [trini: Fix DOCBOOKS line as we don't have linker_lists yet] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-16Remove lh7a40x cpu and serial driverAlbert ARIBAUD
Since commit 957731ed (ARM: remove broken "lpd7a40x" boards), lh7a40x cpu and serial driver have become unused. Remove them. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-15kerneldoc: Add myself to the git-mailrc for kerneldocMarek Vasut
Add entry for kerneldoc into the git-mailrc pointing to the U-Boot ML and myself. Signed-off-by: Marek Vasut <marex@denx.de>
