path: root/doc
2015-10-19doc/README.scrapyard: Add more entriesTom Rini
- Add deletions from August 30 2015. - A few from Sept 12, one from Oct 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19doc/README.scrapyard: Populate recent removalsTom Rini
Add in the commit IDs / dates for boards removed on Sept 2nd. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-15ARM: uniphier: fix address mapping in README.uniphierMasahiro Yamada
2015-10-11Revert "powerpc: ppc4xx: remove lwmon5 support"Stefan Roese
This reverts commit 8fe11b8901a31d11990488c82bc23612589d57be. I'll add support to lwmon5 in the next patch and will remove support for the broken lcd4_lwmon5 as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25ARM: uniphier: add ProXstream2 and PH1-LD6b supportMasahiro Yamada
The DDR SDRAM initialization code has not been mainlined yet, but U-Boot proper should work. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-25ARM: uniphier: add PH1-Pro5 supportMasahiro Yamada
2015-09-16x86: doc: Add DMI to the TODO listBin Meng
Desktop Management Interface (DMI) is not supported by U-Boot now. Add it to the TODO list. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-16x86: doc: Document some porting hints about Intel QuarkBin Meng
Document porting considerations for Intel Quark based board, including MRC parameters and PCIe initialization. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove vision2 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stefano Babic <sbabic@denx.de>
2015-09-11arm: Remove omap3_mvblx boardSimon Glass
2015-09-11arm: Remove enbw_cmc boardSimon Glass
2015-09-11git-mailrc: add Alexey as ARC maintainerMasahiro Yamada
It's easier to Cc him on ARC-releated patches. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-09x86: doc: Change to use CONFIG_VGA_BIOS_ADDRBin Meng
CONFIG_X86_OPTION_ROM_ADDR has been renamed to CONFIG_VGA_BIOS_ADDR. Update the doc to refer to the new name. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-07doc: dfu: tftp: README entry for TFTP extension of DFULukasz Majewski
Documentation file for DFU extension. With this functionality it is now possible to transfer FIT images with firmware updates via TFTP and use DFU backend for storing them. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-03doc: document the fdtdir PXE commandStefan Brüns
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03doc: Fix inconsistent filename in PXE config exampleStefan Brüns
The default config includes base.menu, not linux.list Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2015-09-03Merge git://git.denx.de/u-boot-rockchipTom Rini
2015-09-02rockchip: Put README image creation commands on one lineSimon Glass
It is easier to paste these into the command line if they are a single common. Use line continuation instead of separate lines. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Update todo in README.rockchipSjoerd Simons
MMC support works now, so it can be dropped from the todo Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Drop first 32kb of zeros from the rkSD image typeSjoerd Simons
Instead of creating a rockchip SPL SD card image with 32KB of zeros which can be written to the start of an SD card, create the images with only the useful data that should be written to an offset of 32KB on the SD card. The first 32 kilobytes aren't needed for bootup and only serve as convenient way of accidentally obliterating your partition table. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02doc: Fix reference to Rock pro when Rock 2 is meantSjoerd Simons
The Radxa Rock pro board is rk3188 based and thus won't work with U-Boot built for RK3288. Change the documentation to refer to the intended board, the Radxa Rock 2, which is an RK3288-based design very similar to the firefly Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add a simple READMESimon Glass
Add a few notes on how to try out the Rockchip support so far. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Bring in RK3288 device tree file includes and bindingsSimon Glass
Bring in required device tree files from Linux. Since mainline Linux is somewhat behind, use the files from the Chromium tree. We can re-sync once further code is acccepted upstream. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02powerpc: mpc85xx: remove stxgp3, stxssa supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Dan Malek <dan@embeddedalley.com>
2015-09-02powerpc: mpc5xx: remove cmi_mpc5xx supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-09-02powerpc: ppc4xx: remove zeus supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove sbc405 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove pcs440ep supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove p3p440 supportMasahiro Yamada
2015-09-02powerpc: ppc4xx: remove lwmon5 supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Remove CONFIG_LWMON5 references. (Also, remove undefined CONFIG_WD_MAX_RATE while I am here.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Stefan Roese <sr@denx.de>
2015-09-02powerpc: ppc4xx: remove csb272, csb472 supportMasahiro Yamada
These have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tolunay Orkun <torkun@nextio.com>
2015-09-02powerpc: ppc4xx: remove alpr supportMasahiro Yamada
2015-09-02imx: fec: add MAC reading from eFuses to READMEOlaf Mandel
Extend the documentation of the fec_mxc configuration by describing its ability to read the ethaddr MAC address from the SoC eFuses. Also add an example how to program the fuses for an imx5 to clarify the byte order. Cc: Stefano Babic <sbabic at denx.de> Cc: Marek Vasut <marex at denx.de> Signed-off-by: Olaf Mandel <o.mandel at menlosystems.com>
2015-08-31ARM: uniphier: enable SPL_OF_CONTROLMasahiro Yamada
Device Tree really improves code maintainability and is now available for SPL too. This is the state-of-the-art implementation in U-boot. The board files (platform data) are no longer needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-28NDS32: Generic Board Support and UnsupportKun-Hua Huang
Remove ag101 and ag102 support Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
Add nds32 ag101p generic board support. Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
2015-08-26dm: pci: Document binding of pci device driversBin Meng
Document how pci devices are bound to device drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: Correct microcode documentationSimon Glass
This is incorrect since we require the -m parameter to the microcode tool. Update the two examples to show this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26efi: Update README.efi to clarify build and test instructionsBin Meng
The doc has a misleading 'make menuconfig' when building the EFI application and payload. Clarify this and also update information on test with QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: doc: Update coreboot payload entry point addressBin Meng
With recent EFI support, the entry point address of coreboot payload was changed. Now we update the address to use _x86boot_start, which is the same one for EFI. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-20ARM: davinci: remove support for cam_enc_4xxMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-08-14Merge git://git.denx.de/u-boot-x86Tom Rini
2015-08-14x86: Add a simple interrupt script to the READMESimon Glass
It is a bit tedious to figure out the interrupt configuration for a new x86 platform. Add a script which can do this, based on the output of 'pci long'. This may be helpful in some cases. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: Add clarifications to the x86 READMEStoppa, Igor
* Explicitly list the targets supported in each section of the instructions from the x86 README. * Drop references to 'raw mode', in favor of 'bare mode'. Signed-off-by: Igor Stoppa <igor.stoppa@intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: baytrail: Configure FSP UPD from device treeAndrew Bradford
Allow for configuration of FSP UPD from the device tree which will override any settings which the FSP was built with itself. Modify the MinnowMax and BayleyBay boards to transfer sensible UPD settings from the Intel FSPv4 Gold release to the respective dts files, with the condition that the memory-down parameters for MinnowMax are also used. Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Removed fsp,mrc-debug-msg and fsp,enable-xhci for minnowmax, bayleybay Fixed lines >80col Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-14sunxi: display: Add overscan correctionHans de Goede
Add support for making the visual area of the framebuffer smaller and drawing a black border around it. This is intended for use with overscanning monitors (esp. with composite video out), to avoid part of the picture being invisible. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-12power: regulator: update comments for regulator-namePeng Fan
We do not need that "regulator-name" property must be provided in dts. If "regulator-name" property is not provided in dts, node name will chosen for settings '.name' field of uc_pdata. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org>
2015-08-08sunxi: display: Add composite video out supportHans de Goede
Add composite video out support. This only gets enabled on the Mele M3 for now, since that is were it was tested. It will be enabled on more boards after testing. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-05dm: video: Add support for the Parade PS8622/625 bridgeSimon Glass
This chip provides an eDP to LVDS bridge which is useful for SoCs that don't support LVDS displays (or it would waste scarce pins). The setup is included in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05i2c: Add a mux for GPIO-based I2C bus arbitrationSimon Glass
While I2C supports multi-master buses this is difficult to get right. The implementation on the master side in software is quite complex. Clock-stretching and the arbitrary time that an I2C transaction can take make it difficult to share the bus fairly in the face of high traffic. When one or more masters can be reset independently part-way through a transaction it is hard to know the state of the bus. This driver provides a scheme based on two 'claim' GPIOs, one driven by the AP (Application Processor, meaning the main CPU) and one driven by the EC (Embedded Controller, a small CPU aimed at handling system tasks). With these they can communicate and reliably share the bus. This scheme has minimal overhead and involves very little code. It is used on snow to permit the EC and the AP to share access to the main system PMIC and battery. The scheme can survive reboots by either side without difficulty. This scheme has been tested in the field with millions of devices. Since U-Boot runs on the AP, the terminology used is 'our' claim GPIO, meaning the AP's, and 'their' claim GPIO, meaning the EC's. This terminology is used by the device tree bindings in Linux also. Signed-off-by: Simon Glass <sjg@chromium.org>
