path: root/drivers/block
2019-01-15blk: Increase cache element sizeMarek Vasut
Cache up to 4 kiB entries. 4 kiB is the default block size on ext4, yet the underlying block layer devices usually report support for 512B . In most cases, the 512B support is emulated (ie. SD cards, SSDs, USB sticks etc.) and the real block size of those devices is much bigger. To avoid performance degradation with such devices and FS setup, bump the maximum cache entry size to 4 kiB. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-12blk: Rework guard around part_init callTom Rini
The function part_init() will only be built when we have both CONFIG_PARTITIONS and CONFIG_HAVE_BLOCK_DEVICE set. Protect the call to this function with both of these tests now. Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Adam Ford <aford173@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Introduce IF_TYPE_VIRTIOTuomas Tynkkynen
This adds a new block interface type for VirtIO block devices. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Make blk_next_free_devnum() publicBin Meng
blk_next_free_devnum() can be helpful in some cases. Make it a public API. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Drop blk_prepare_device()Bin Meng
With the post_probe() changes, this API is no longer needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Call part_init() in the post_probe() methodBin Meng
part_init() is currently called in every DM BLK driver, either in its bind() or probe() method. However we can use the BLK uclass driver's post_probe() method to do it automatically. Update all DM BLK drivers to adopt this change. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14sandbox: blk: Switch to use platdata_auto_alloc_size for the driver dataBin Meng
Currently the sandbox block driver uses priv_auto_alloc_size for the driver data, however that's only available after the device probe phase. In order to make it accessible in an earlier phase, switch to use platdata_auto_alloc_size instead. This patch is the prerequisite for the follow up patch of DM BLK driver changes to work with Sandbox. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-09blk: Support block drivers in TPLSimon Glass
At present it is not possible to enable/disable block drivers in TPL. This is needed to provide sandbox support. Add a Kconfig option and adjust the Makefile. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-28block: Add a function to find block device descriptorTien Fong Chee
Add a function to find the block device descriptor of the parent device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> [trini: Move function declaration to avoid warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-06-18block: Add SPL_BLOCK_CACHE and default nAdam Ford
When enabling BLOCK_CACHE on devices with limited RAM during SPL, some devices may not boot. This creates an option to enable block caching in SPL by defaults off. It is dependent on SPL_BLK Fixes: 46960ad6d09b ("block: Have BLOCK_CACHE default to y in some cases") Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-07block: Have BLOCK_CACHE default to y in some casesTom Rini
When dealing with filesystems that come from block devices we can get a noticeable performance gain in some use cases from having the block cache enabled. The code paths are valid in other cases when we have BLK set and may provide wins in raw reads in some use cases, so have this be default when BLK is enabled. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13SystemACE: RemoveTom Rini
This driver is no longer used on any supported platform in U-Boot and there is no interest in maintaining it further from people that have used it historically. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> c: Alexey Brodkin <alexey.brodkin@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08block: Migrate SystemACE chip to KconfigTom Rini
Migrate the base and sub-options to Kconfig. Note that we only enable this in the base sandbox config now. Cc: Alexey Brodkin <alexey.brodkin@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Is this driver still used anywhere? It's fishy that it's only enabled in sandbox anymore.
2018-01-22efi_driver: EFI block driverHeinrich Schuchardt
This patch provides * a uclass for EFI drivers * a EFI driver for block devices For each EFI driver the uclass * creates a handle * adds the driver binding protocol The uclass provides the bind, start, and stop entry points for the driver binding protocol. In bind() and stop() it checks if the controller implements the protocol supported by the EFI driver. In the start() function it calls the bind() function of the EFI driver. In the stop() function it destroys the child controllers. The EFI block driver binds to controllers implementing the block io protocol. When the bind function of the EFI block driver is called it creates a new U-Boot block device. It installs child handles for all partitions and installs the simple file protocol on these. The read and write functions of the EFI block driver delegate calls to the controller that it is bound to. A usage example is as following: U-Boot loads the iPXE snp.efi executable. iPXE connects an iSCSI drive and exposes a handle with the block IO protocol. It calls ConnectController. Now the EFI block driver installs the partitions with the simple file protocol. iPXE uses the simple file protocol to load Grub or the Linux Kernel. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: add comment on calloc len] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-12dm: blk: Use uclass_find_first/next_device() in blk_first/next_device()Stefan Roese
This patch changes the calls to uclass_first/next_device() in blk_first/ next_device() to use uclass_find_first/next_device() instead. These functions don't prepare the devices, which is correct in this case. With this patch applied, the "usb storage" command now works again as expected: => usb storage Device 0: Vendor: SanDisk Rev: 1.00 Prod: Ultra Type: Removable Hard Disk Capacity: 58656.0 MB = 57.2 GB (120127488 x 512) Without this patch, it used to generate this buggy output: => usb storage Card did not respond to voltage select! mmc_init: -95, time 26 No storage devices, perhaps not 'usb start'ed..? Signed-off-by: Stefan Roese <sr@denx.de> Suggested-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-09-11blk: dm: make blk_create_device() take a number of block instead of a sizeJean-Jacques Hiblot
There is an overflow problem when taking the size instead of the number of blocks in blk_create_device(). This results in a wrong device size: the device apparent size is its real size modulo 4GB. Using the number of blocks instead of the device size fixes the problem and is more coherent with the internals of the block layer. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-10block: ide: Don't bother to create BLK device if no CDROM insertedBin Meng
When there is no CDROM inserted, the block size is zero hence there is no need to create a BLK device for it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-10block: ide: Fix block read/write with driver modelBin Meng
This converts the IDE driver to driver model so that block read and write are fully functional. Fixes: b7c6baef ("x86: Convert MMC to driver model") Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-09-03block: Drop the ftide020 driverBin Meng
This is not used in U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-03block: ide: Drop CONFIG_IDE_LEDBin Meng
This is actually not used. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-03block: ide: Drop CONFIG_IDE_INIT_POSTRESETBin Meng
This is not referenced anywhere. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-17dm: blk: Update return value in blk_create_devicef()Simon Glass
This returns 'ret' but the value is always zero. Update it to simply return 0, for clarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: blk: Add a function to find an interface-type nameSimon Glass
Add a function to find the name of an interface type (e.g. "sata", "scsi") from the interface type enum. This is useful for generic code (not specific to SATA or SCSI, for example) that wants to display the type of interface it is dealing with. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-01Merge git://git.denx.de/u-boot-x86Tom Rini
2017-08-01block: ide: Fix build error when CONFIG_BLK is onBin Meng
Add missing #ifndef CONFIG_BLK to wrap dev_desc->block_read. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01dm: mmc: Allow disabling driver model in SPLSimon Glass
At present if U-Boot proper uses driver model for MMC, then SPL has to also. While this is desirable, it places a significant barrier to moving to driver model in some cases. For example, with a space-constrained SPL it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves adjusting some drivers. Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By default these follow their non-SPL versions, but this can be changed by boards which need it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11scsi: Move drivers into new drivers/scsi directorySimon Glass
At present we have the SCSI drivers in the drivers/block and common/ directories. It is better to split them out into their own place. Use drivers/scsi which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11sata: Move drivers into new drivers/ata directorySimon Glass
At present we have the SATA and PATA drivers mixed up in the drivers/block directory. It is better to split them out into their own place. Use drivers/ata which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11scsi: Drop scsi_print_error()Simon Glass
This function is only defined by one driver and is empty. Move it into the SCSI implementation itself. We could remove it, but it should be useful for debugging. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11scsi: Drop sym53c8xx driverSimon Glass
This driver is for a PowerPC board that will likely be removed soon. Rather than converting it to driver model, drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-03drivers, block: remove sil680 driverHeiko Schocher
driver is not used anymore, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-20block: sata: ceva: drop extraneous netdev.h includePeter Robinson
Drop include of netdev.h as it's a SATA driver not a network driver. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-09dm: blk: Add a way to obtain a block device from its parentSimon Glass
Many devices support a child block device (e.g. MMC, USB). Add a convenient way to get this device given the parent device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: blk: Improve block device claimingSimon Glass
The intention with block devices is that the device number (devnum field in its descriptor) matches the alias of its parent device. For example, with: aliases { mmc0 = "/sdhci@700b0600"; mmc1 = "/sdhci@700b0400"; } we expect that the block devices for mmc0 and mmc1 would have device numbers of 0 and 1 respectively. Unfortunately this does not currently always happen. If there is another MMC device earlier in the driver model data structures its block device will be created first. It will therefore get device number 0 and mmc0 will therefore miss out. In this case the MMC device will have sequence number 0 but its block device will not. To avoid this, allow a device to request a device number and bump any existing device number that is using it. This all happens during the binding phase so it is safe to change these numbers around. This allows device numbers to match the aliases in all circumstances. Add a test to verify the behaviour. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: blk: Add a function to find the next block device numberSimon Glass
At present this code is inline. Move it into a function to allow it to be used elsewhere. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: blk: Allow finding block devices without probingSimon Glass
Sometimes it is useful to be able to find a block device without also probing it. Add a function for this as well as the associated test. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Replace of_offset with accessor (part 2)Simon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09drivers: block: dwc_ahci: Implement a driver for Synopsys DWC sata deviceJean-Jacques Hiblot
Implement a sata driver for Synopsys DWC sata device based on U-boot driver model. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-18fsl/sata: correctly identify failed mallocxypron.glpk@gmx.de
After allocating sata->cmd_hdr_tbl_offset we have to check this variable and not variable sata. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-18drivers: remove Blackfin specific driversMasahiro Yamada
These drivers have no user since commit ea3310e8aafa ("Blackfin: Remove"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-04-04dm: core: Add flags parameter to device_remove()Stefan Roese
This patch adds the flags parameter to device_remove() and changes all calls to this function to provide the default value of DM_REMOVE_NORMAL for "normal" device removal. This is in preparation for the driver specific pre-OS (e.g. DMA cancelling) remove support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
