path: root/drivers/hwmon/ds1775.c
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2008-07-13hwmon: Cleaning hwmon devicesMichal Simek
Clean Makefile Move device specific values to driver for better reading Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2007-12-11Merge commit 'u-boot/master' into for-1.3.1Stefan Roese
Conflicts: drivers/rtc/Makefile
2007-11-25drivers/hwmon : move hardware monitor drviers to drivers/hwmonJean-Christophe PLAGNIOL-VILLARD
