path: root/drivers/i2c/mxc_i2c.c
2019-05-17i2c: mxc_i2c: Fix read and read->write xfers in DM modeTrent Piepho
This is an old driver that supports both device mapped and non-mapped mode, and covers a wide range of hardware. It's hard to change without risking breaking something. I have to tried to be exceedingly detailed in this patch, so please excuse the length of the commit essay that follows. In device mapped mode the I2C xfer function does not handle plain read, and some other, transfers correctly. What it can't handle are transactions that: Start with a read, or, Have a write followed by a read, or, Have more than one read in a row. The common I2C/SMBUS read register and write register transactions always start with a write, followed by a write or a read, and then end. These work, so the bug is not apparent for most I2C slaves that only use these common xfer forms. The existing xfer loop initializes by sending the chip address in write mode after it deals with bus arbitration and master setup. When processing each message, if the next message will be a read, it sends a repeated start followed by the chip address in read mode after the current message. Obviously, this does not work if the first message is a read, as the chip is always addressed in write mode initially by i2c_init_transfer(). A write following a read does not work because the repeated start is only sent when the next message is a read. There is no logic to send it when the current message is a read and next is write. It should be sent every time the bus changes direction. The ability to use a plain read was added to this driver in commit 2feec4eafd40 ("imx: mxc_i2c: tweak the i2c transfer method"), but this applied only the non-DM code path. This patch fixes the DM code path. The xfer function will call i2c_init_transfer() with an alen of -1 to avoid sending the chip address. The same way the non-DM code achieves this. The xfer function's message loop will send the address and mode before each message if the bus changes direction, and on the first message. When reading data, the master hardware is one byte ahead of what we receive. I.e., reading a byte from the data register returns a byte *already received* by the master, and causes the master to start the RX of the *next* byte. Therefor, before we read the final byte of a message, we must tell the master what to do next. I add a "last" flag to i2c_read_data() to tell it if the message is to be followed by a stop or a repeated start. When last == true it acts exactly as before. The non-DM code can only create an xfer where the read, if any, is the final message of the xfer. And so the only callsite of i2c_read_data() in the non-DM code has the "last" parameter as true. Therefore, this change has no effect on the non-DM code. As all other changes are in the DM xfer function, which is not even compiled in non-DM code, I am confident that this patch has no effect on boards not using I2C_DM. This greatly reduces the range of hardware that could be affected. For DM boards, I have verified every transaction the "i2c" command can create on a scope and they are all exactly as they are supposed to be. I also tested write->read->write, which isn't possible with the i2c command, and it works as well. I didn't fix multiple reads in a row, as it's a lot more invasive and obviously no one has every wanted them since they've never worked. It didn't seem like the extra complexity was justified to support something no one uses. Cc: Nandor Han <nandor.han@ge.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Signed-off-by: Trent Piepho <tpiepho@impinj.com>
2019-05-17i2c: mxc_i2c: Document how non-DM functions workTrent Piepho
It is not very clear how these work in relation to the exact I2C xfers they produce. In paticular, the address length is somewhat overloaded in the read method. Clearly document the existing behavior. Maybe this will help the next person who needs to work on this driver and not break non-DM boards. Cc: Nandor Han <nandor.han@ge.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Signed-off-by: Trent Piepho <tpiepho@impinj.com>
2019-04-11DM: I2C: Introduce 'u-boot, i2c-transaction-bytes' propertyLukasz Majewski
The 'u-boot,i2c-transaction-bytes' device tree property provides information regarding number of bytes transferred by a device in a single transaction. This change is necessary to avoid hanging devices after soft reset. One notable example is communication with MC34708 device: 1. Reset when communicating with MC34708 via I2C. 2. The u-boot (after reboot -f) tries to setup the I2C and then calls force_idle_bus. In the same time MC34708 still has some data to be sent (as it transfers data in 24 bits chunks). 3. The force_idle_bus() is not able to make the bus idle as 8 SCL clocks may be not enough to have the full transmission. 4. We end up with I2C inconsistency with MC34708. This PMIC device requires 24+ SCL cycles to make finish any pending I2C transmission. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-03-29drivers: i2c: mxc: Update support to 8 I2C controllersSriram Dash
Existing driver supports upto 4 I2C controllers. But some of future NXPs SoCs like lx2160a has eight I2C controllers. Update MXC driver to support upto 8 I2C controllers Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2018-01-16i2c: mxc_i2c: Use or operationPeng Fan
The operation should be OR, not BIT OR. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2017-11-20imx: mxc_i2c: tweak the i2c transfer methodNandor Han
Tweak the i2c transfer to work for devices that want to read data without addressing a register. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Acked-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2017-10-08dm: gpio: Correct use of -ENODEV in driversSimon Glass
In U-Boot -ENODEV means that there is no device. When there is a problem with the device, drivers should return an error like -ENXIO or -EREMOTEIO. When the device tree properties cannot be read correct , they should return -EINVAL. Update various GPIO drivers to follow this rule, to help with consistency for future driver writers. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Adam Ford <aford173@gmail.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15i2c: mxc_i2c: Drop use of CONFIG_I2C_HARDSimon Glass
Drop use of this long-deprecated option. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-17armv7: ls1021a: Drop macro CONFIG_LS102XAYork Sun
Use CONFIG_ARCH_LS1021A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-16i2c: mxc: Make 'no gpio pinctrl state' print as debugJagan Teki
Some I2C bus devicetree nodes, doesn't require to have gpio pinctrl so replace the dev_info to debug so the print never comes on the console and for bus that uses gpio pinctrl anyway have dev_err. Before: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 0x21a4000, no gpio pinctrl state. After: ------ U-Boot> i2c dev 1 Setting bus to 1 Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Heiko Schocher <hs@denx.de>
2016-12-16i2c: mxc: Print hex instead of decimal for bus addressJagan Teki
Better to print the hex value for bus address instead of decimal, for more readbility on bus addressing. Before: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 35274752, no gpio pinctrl state. After: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 0x21a4000, no gpio pinctrl state. Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Heiko Schocher <hs@denx.de>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-10drivers: i2c: mxc: Add early initYuan Yao
Add early i2c init function with conservative divider when the exact clock rate is not available. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-28dm: i2c: mxc_i2c: implement i2c_idle_busPeng Fan
Implement i2c_idle_bus in driver, then setup_i2c can be dropped for boards which enable DM_I2C/DM_GPIO/PINCTRL. The i2c_idle_bus force bus idle flow follows setup_i2c in arch/arm/imx-common/i2c-mxv7.c This patch is an implementation following linux kernel patch: " commit 1c4b6c3bcf30d0804db0d0647d8ebeb862c6f7e5 Author: Gao Pan <b54642@freescale.com> Date: Fri Oct 23 20:28:54 2015 +0800 i2c: imx: implement bus recovery Implement bus recovery methods for i2c-imx so we can recover from situations where SCL/SDA are stuck low. Once i2c bus SCL/SDA are stuck low during transfer, config the i2c pinctrl to gpio mode by calling pinctrl sleep set function, and then use GPIO to emulate the i2c protocol to send nine dummy clock to recover i2c device. After recovery, set i2c pinctrl to default group setting. " See Documentation/devicetree/bindings/i2c/i2c-imx.txt for detailed description. 1. Introuduce scl_gpio/sda_gpio/bus in mxc_i2c_bus. 2. Discard the __weak attribute for i2c_idle_bus and implement it, since we have pinctrl driver/driver model gpio driver. We can use device tree, but not let board code to do this. 3. gpio state for mxc_i2c is not a must, but it is recommended. If there is no gpio state, driver will give tips, but not fail. 4. The i2c controller was first probed, default pinctrl state will be used, so when need to use gpio function, need to do "pinctrl_select_state(dev, "gpio")" and after force bus idle, need to switch back "pinctrl_select_state(dev, "default")". This is example about how to use the gpio force bus idle function: " &i2c1 { clock-frequency = <100000>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c1>; pinctrl-1 = <&pinctrl_i2c1_gpio>; scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; status = "okay"; [....] }; [.....] pinctrl_i2c1_gpio: i2c1grp_gpio { fsl,pins = < MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0 MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0 >; }; " Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com>
2016-01-03i2c: mxc: add a condition in case the parameter is NULLGong Qianyu
This could avoid executing the code that only applies to i.MX platforms. The bus_i2c_init() is called before relocation and will assgin value to a static variable. If U-Boot is then still running in a flash device, it's theoretically not allowed to write data to flash without an erasing operation. For i.MX platforms, the U-Boot is always running in DDR. Actually it causes asynchronous error when the ARM64 system error report is enabled and the flash write protect is set. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-29armv8/fsl_lsch3: Change arch to fsl-layerscapeMingkai Hu
There are two LS series processors are built on ARMv8 Layersacpe architecture currently, LS2085A and LS1043A. They are based on ARMv8 core although use different chassis, so create fsl-layerscape to refactor the common code for the LS series processors which also paves the way for adding LS1043A platform. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-07-10i2c: fix vf610 supportAlbert ARIBAUD \(3ADEV\)
Add support in mxc_i2c driver, iomux_v3 and vf610 architecture for the four I2C instances available in VF610. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-05-26i2c, mxc: rework i2c base address names for different SoCsHeiko Schocher
rework and unify i2c address names for different SoCs, which use the mxc_i2c driver. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-26arm, imx6, i2c: add I2C4 for MX6DLHeiko Schocher
add I2C4 modul for MX6DL based boards. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-14i2c: mxc: refactor i2c driver and support dmPeng Fan
1. Introduce a new structure `struct mxc_i2c_bus`, this structure will used for non-DM and DM. 2. Remove `struct mxc_i2c_regs` structure, but use register offset to access registers based on `base` entry of `struct mxc_i2c_bus`. 3. Remove most `#ifdef I2C_QUIRK_REG`. Using driver_data to contain platform flags. A new flag is introduced, I2C_QUIRK_FLAG. 4. Most functions use `struct mxc_i2c_bus` as one of the parameters. Make most functions common to DM and non-DM, try to avoid duplicated code. 5. Support DM, but pinctrl is not included. Pinmux setting is still set by setup_i2c, but we do not need bus_i2c_init for DM. 6. struct i2c_parms and struct sram_data are removed. 7. Remove bus_i2c_read bus_i2c_write prototype in header file. The frist paramter of bus_i2c_init is modified to i2c index. Add new prototype i2c_idle_bus and force_bus_idle. Since bus_i2c_init is not good for DM I2C and pinctrl is missed, we use a weak function for i2c_idle_bus. Board file take the responsibility to implement this function, like this: " int i2c_idle_bus(struct mxc_i2c_bus *i2c_bus) { if (i2c_bus->index == 0) force_bus_idle(i2c_pads_info0); else if (i2c_bus->index == 1) force_bus_idle(i2c_pads_info1); else xxxxxx } " 8. Introduce a weak function, enable_i2c_clk 9. Tested on an i.MX7 platform. Log info: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver simple_bus [ ] |-- soc simple_bus [ ] | |-- aips-bus@30000000 simple_bus [ ] | | |-- anatop@30360000 simple_bus [ ] | | `-- snvs@30370000 simple_bus [ ] | |-- aips-bus@30400000 simple_bus [ ] | `-- aips-bus@30800000 i2c [ ] | |-- i2c@30a20000 i2c [ ] | `-- i2c@30a40000 simple_bus [ ] `-- regulators => i2c dev 0 Setting bus to 0 => i2c probe Valid chip addresses: 08 50 => i2c md 8 31 0031: 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-01-08i2c:mxc fix array size of i2c_dataPeng Fan
We should not hardcode array size of i2c_data to 3. To CONFIG_FSL_LSCH3, there are 4 i2c interface, but not 3. So the size of i2c_data array should be calculated using "ARRAY_SIZE(i2c_bases)". To avoid compile error, move i2c_bases before sram_data structure which contains i2c_data array. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2014-09-08ls102xa: i2c: Add i2c support for LS102xAWang Huan
The existing i.MX's I2C driver mxc_i2c.c is compatible with the controller of LS102xA. As I2C's registers are 8-bit on LS102xA, I2C_QUIRK_REG is enabled to use 8-bit driver. This patch is to add I2C 1,2,3 support for LS102xA. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-07-03ARMv8/FSL_LSCH3: Add FSL_LSCH3 SoCYork Sun
Freescale LayerScape with Chassis Generation 3 is a set of SoCs with ARMv8 cores and 3rd generation of Chassis. We use different MMU setup to support memory map and cache attribute for these SoCs. MMU and cache are enabled very early to bootst performance, especially for early development on emulators. After u-boot relocates to DDR, a new MMU table with QBMan cache access is created in DDR. SMMU pagesize is set in SMMU_sACR register. Both DDR3 and DDR4 are supported. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-04-29driver/mxc_i2c: Move static data structure to global_dataYork Sun
This driver needs a data structure in SRAM before SDRAM is available. This is not alway the case using .data section. Moving this data structure to global_data guarantees it is writable. Signed-off-by: York Sun <yorksun@freescale.com> CC: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-17i2c: mxc: move to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23I2C: mxc_i2c: Add support for Vybrid VF610 platformAlison Wang
This patch adds support for Vybrid VF610 platform. There are some differences between i.MX6 and Vybrid for I2C controller. (1) The registers' offset are different. (2) The I2C clock divider values are different. (3) In I2C control register, the enable/disable/reset bit is inverted for Vybrid comparing to i.MX6. (4) In I2C status register, the interrupt flag bit is cleared by writing "1" for Vybrid. For i.MX6, this bit is cleared by writing "0". (5) In I2C status register, the arbitration lost flag bit is cleared by writing "1" for Vybrid. For i.MX6, this bit is cleared by writing "0". Signed-off-by: Alison Wang <b18965@freescale.com>
2012-12-11i2c: Staticize local functions in mxc i2c driverMarek Vasut
Some functions in the MXC i2c driver were not static, fix this by making them so. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15imx: Use MXC_I2C_CLK in imx i2c driverMatthias Weisser
i2c didn't work on imx25 due to missing MXC_IPG_PERCLK. Now using MXC_I2C_CLK on all imx systems using i2c. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-31mxc_i2c: finish adding CONFIG_I2C_MULTI_BUS supportTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-31mxc_i2c: add bus recovery supportTroy Kisky
Add support for calling a function that will toggle the SCL line to return the bus to idle condition. The actual toggling function is added in a later patch. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-31mxc_i2c: prep work for multiple busses supportTroy Kisky
2012-07-31mxc_i2c: add i2c_regs argument to i2c_imx_stopTroy Kisky
This is prep work for CONFIG_I2C_MULTI_BUS. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-31mxc_i2c: add retriesTroy Kisky
Retry unexpected hardware errors. This will not retry a received NAK. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-31mxc_i2c: check for arbitration lostTroy Kisky
No need to continue waiting if arbitration lost. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-31mxc_i2c: change slave addr if conflicts with destination.Troy Kisky
The i2c controller cannot be both master and slave in the same transaction. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-31mxc_i2c: don't disable controller after every transactionTroy Kisky
This helps in a multiple bus master environment which is why I also added a wait for bus idle. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-31mxc_i2c: place i2c_reset code inlineTroy Kisky
imx_reset is only referenced once so move to that location. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-31mxc_i2c: place imx_start code inlineTroy Kisky
imx_start is only referenced once so move to that location. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-31mxc_i2c: remove redundant readTroy Kisky
wait_for_sr_state returns i2sr on success so no need to read again. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-31mxc_i2c: combine i2c_imx_bus_busy and i2c_imx_trx_complete into ↵Troy Kisky
wait_for_sr_state Not using udelay gives a more accurate timeout. The current implementation of udelay in imx-common does not seem to wait at all for a udelay(1). Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de> ---- V2: Added WATCHDOG_RESET as suggested by Marek Vasut add error message when stop fails mxc_i2c: code i2c_probe as a 0 length i2c_write Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
