path: root/drivers/mmc/s5p_sdhci.c
2019-02-09samsung: mmc: Drop old MMC init codeSimon Glass
Now that these boards use driver model we can drop the old code. At present s5p_mmc_init() is still used by goni and smdkv310 so cannot be removed unless we remove those boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-23mmc: sdhci: Distinguish between base clock and maximum peripheral frequencyStefan Herbrechtsmeier
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. The Linux kernel distinguishes between base clock (max_clk) of the host controller and maximum frequency (f_max) of the card interface. Use the same differentiation and allow the platform to constrain the peripheral interface. Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
2017-01-11mmc: sdhci: move the callback function into sdhci_opsJaehoon Chung
callback function should be moved into sdhci_ops struct. Other controller can use these ops for controlling clock or their own specific register. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-01-11mmc: s5p_sdhci: add the s5p_set_clock functionJaehoon Chung
Add the s5p_set_clock function. It's not good that "set_mmc_clk" is assigned directly. In future, it should be changed to use the clock framework. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-01mmc: s5p_sdhci: fix to check proper pinmux idSeung-Woo Kim
At sdhci_get_config(), there was wrong condition to check pimux id, so this patch fixes to check proper pinmux id. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
2016-10-10mmc: sdhci: use the generic error numberJaehoon Chung
Use the generic error number instead of meaningless value. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-10mmc: sdhci: use the host version value in sdhci_setup_cfgJaehoon Chung
"host->version" isn't a SoC specific value. It doesn't need to get in each SoC drivers. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-10-10mmc: s5p_sdhci: support the Driver model for ExynosJaehoon Chung
This patch support the driver model for s5p_sdhci controller. To support the legacy model, maintained the existing code. Note: If use the Driver Model, it needs to modify the device-tree. In future, will update the Device-tree and enable the configuratioin. (CONFIG_BLK, CONFIG_DM_MMC and CONFING_DM_MMC_OPS) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05mmc: s5p_sdhci: unset the SDHCI_QUIRK_BROKEN_R1BJaehoon Chung
Unset the SDHCI_QUIRK_BROKEN_R1B for exynos SoC. (Tested on Exynos4 Boards.) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-11-02s5p sdhci: call pinmux for card's gpio pins before use themPrzemyslaw Marczak
The SD card detection depends on checking one pin state. But the pin was configured after card was detected, which is wrong. This commit fixes this, by moving call to pinmux before use the pin. Tested-on: Odroid U3 and Odroid X2. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-13exynos: more debug and cleanup in do_sdhci_init()Tobias Jakobi
Add more debug printfs in do_sdhci_init() for calls that can potentially fail. Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-13exynos: be more verbose in process_nodes()Tobias Jakobi
In case sdhci_get_config() or do_sdhci_init() fail, show the error code that was returned. Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-13exynos: Fix passing of errors in exynos_mmc_init()Tobias Jakobi
exynos_mmc_init() always returns zero, so for the caller it looks like it never fails. Correct this by returning the error code of process_nodes(). For process_nodes() do something similar and return early when do_sdhci_init() fails. v2: Only fail in process_nodes() if we fail on all available nodes. Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-13exynos: Properly zero initialize host in s5p_sdhci_init()Tobias Jakobi
This makes sure that setting the host_caps in s5p_sdhci_core_init() doesn't operate on potentially uninitialized memory. Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-05exynos: Correct return value in exynos_mmc_init()Simon Glass
This function should return 0 on success, not 1. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05mmc: remove the MMC_MODE_HC flagRob Herring
High capacity support is not a host capability, but a device capability that is queried via the OCR. The flag in the operating conditions request argument can just be set unconditionally. This matches the Linux implementation. [panto] Hand merged and renumbering MMC_MODE_DDR_52MHz. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2015-03-18mmc: s5p: properly mask SELBASECLKMatt Reimer
Properly mask SELBASECLK by using an actual mask rather than the number of bits to shift in order to create the mask. Signed-off-by: Matt Reimer <mreimer@sdgsystems.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2015-01-29dm: mmc: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27mmc: s5p: set SD detection pin as inputPrzemyslaw Marczak
The SD Card slot detection pin should be configured as input. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Make sure that GPIOs are requestedSimon Glass
With driver model GPIOs must be requested before use. Make sure this is done correctly. (Note that the soft SPI part of universal is omitted, since this driver is about to be replaced with a driver-model-aware version) Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08samsung: Enable device tree for s5p_goniSimon Glass
Change this board to add a device tree. This also adds a pinmux header file although it is not used as yet. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-16mmc: s5p_sdhci: add the s5p_sdhci_core_init functionJaehoon Chung
To reuse the code, added the s5p_sdhci_core_init function. Before applied this patch, didn't use the 8-bit mode at exynos baord. Because it didn't set "MMC_MODE_8BIT". Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-12drivers:mmc:sdhci: enable support for DTPiotr Wilczek
This patch enables support for device tree for sdhci driver. Non DT case is still supported. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-17mmc: sdhci: use the SDHCI_QUIRK_USE_WIDE8 for samsung SoCJaehoon Chung
Samsung SoC is supported the WIDE8, even if Controller version is v2.0. So add the SDHCI_QUIRK_USE_WIDE8 for Samsung-SoC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-05-06mmc: sdhci: return error when failed add_sdhci().Jaehoon Chung
If failed the add_host(), it is reasonable that return value of add_sdhci(). Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22mmc: sdhci: Add a quirk to add delay during completion of sdhci_send_cmdTushar Behera
MMC host controller requires a delay between every sdhci_send_cmd() execution. In s5p_mmc driver (s5p_sdhci replaces this driver), a delay of 1000us was provided after every mmc_send_cmd() call. Adding a quirk in current sdhci driver to replicate the behaviour. Without this delay, MMC initialization on Origen board fails with following error messages. Timeout for status update! mmc fail to send stop cmd Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05mmc: s5p_sdhci: add the set_mmc_clk for cmu controlJaehoon Chung
Samsung SoC use the cmu control to set clock. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05mmc: s5p_sdhci: fixed wrong function argumentJaehoon Chung
Useless code is removed, and get buswidth value. buswidth value will be used to choice the 4bit or 8bit. (Now used 4bit mode in sdhci.c by default) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05mmc: s5p_sdhci: set the SDHCI_QUIRK_BROKEN_R1BJaehoon Chung
Samsung SoC is broken busy waiting for R1b type. And clk delay control value is modified the previosuly value. (that value used at the s5p_mmc.c) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-05-08mmc: support the sdhci instead of s5p_mmc for samsung-socJaehoon Chung
In driver mmc, generic s5p_sdhci code is implemented. s5p_mmc file is dupulicated. we are good that use the generic sdhci. This patch supported the sdhci for Samsung-SoC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
