The CONFIG_DEVRES is not a necessary config for pinctrl. We decouple the
dependence from the kconfig. So the DEVRES is not default enabled.
When using USB gadget driver like CDNS3 or DWC3, without enabling gadget DM
driver, the calling to devm_kzalloc will cause crash if CONFIG_DEVRES is set.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit baeed1c2a36c07126e35a3cdb34f4f392e88c939)
(cherry picked from commit 09ca00f7870374658f98ffc1952a2c617e4403e2)
(cherry picked from commit 3a724d7fb23a36dd7ed02701df2cda822bdef075)
Using bias-pull-up would actually cause the pin to have its pull-down
enabled. Fix this.
Original Linux patch by Sean Anderson:
https://lore.kernel.org/linux-gpio/20220209182822.640905-1-seanga2@gmail.com/
Fixes: 7224d5ccf8e1 ("pinctrl: Add support for Kendryte K210 FPIOA")
Signed-off-by: Niklas Cassel <niklas.cassel@wdc.com>
Reviewed-by: Sean Anderson <seanga2@gmail.com>
The loop exited too early so the k210_pc_drive_strength[0] array element
was never used.
Original Linux patch by Dan Carpenter:
https://lore.kernel.org/linux-gpio/20220209180804.GA18385@kili/
Linux kernel fpioa pinctrl driver expects the sysctl phandle and the
power bit offset of the fpioa device to be specified as a single
property "canaan,k210-sysctl-power".
Replace the "canaan,k210-sysctl" and "canaan,k210-power-offset"
properties with "canaan,k210-sysctl-power" to satisfy the Linux kernel
requirements. This new property is parsed using the existing function
dev_read_phandle_with_args().
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
"kendryte" is the marketing name for the K210 RISC-V SoC produced by
Canaan Inc. Rather than "kendryte,k210", use the usual "canaan,k210"
vendor,SoC compatibility string format in the device tree files and
use the SoC name for file names.
With these changes, the device tree files are more in sync with the
Linux kernel DTS and drivers, making uboot device tree usable by the
kernel.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Commit 5534fb4f4833 ("arm64: a37xx: pinctrl: Correct PWM pins
definitions") introduced bogus definitions os PWM pins: all 4 pins have
index 11, instead of having indexes 11, 12, 13, 14.
Fix this.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Pali Rohár <pali@kernel.org>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Changes to the am33xx device (33e9021a) trees have been merged in from
the upstream linux kernel which now means the device tree uses the new
pins format (as of 5.10) where the confinguration can be stores as a
separate configuration value and pin mux mode which are then OR'd
together.
This patch adds support for the new format to u-boot so that
pinctrl-cells is now respected when reading in pinctrl-single,pins
Signed-off-by: Anthony Bagwell <anthony.bagwell@hivehome.com>
Define LOG_CATEGORY to allow filtering with log command.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Prepare v2022.01-rc3
This should use the provided U_BOOT_DRIVER() macro so that the driver gets
added to the appropriate linker list. Fix it.
Fixes: 7c9dcfed50f ("pinctrl: meson: rework gx pmx function")
Reported-by: Tom Rini <trini@konsulko.com>
Tested-by: Tom Rini <trini@konsulko.com> on libretech-cc
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
This driver supports both pin muxing and GPIO support for the
pin control logic found on Apple SoCs.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
This driver uses Pinctrl framework and is compatible with the Linux
driver for AST2600.
Signed-off-by: Ryan Chen <ryan_chen@aspeedtech.com>
Signed-off-by: Dylan Hung <dylan_hung@aspeedtech.com>
https://source.denx.de/u-boot/custodians/u-boot-stm
- DHSOM update:
- Remove nWP GPIO hog
- Increase SF bus frequency to 50Mhz and enable SFDP
- Disable video output for DHSOM
- Disable EFI
- Enable DFU_MTD support
- Create include file for STM32 gpio driver private data
- Split board and SOC STM32MP15 configuration
- Device tree alignement with v5.15-rc6 for STM32MP15
- Add binman support for STM32MP15x
- Normalise newlines for stm32prog
- Update OTP shadow registers in SPL
The stm32 gpio driver private data are not needed in arch include files,
they are not used by code except for stm32 gpio and pincontrol drivers,
using the same IP; the defines for this IP is moved in a new file
"stm32_gpio_priv.h" in driver/gpio.
This patch avoids to have duplicated file gpio.h for each SOC
in MPU directory mach-stm32mp and in each MCU directory arch-stm32*
and allows to remove CONFIG_GPIO_EXTRA_HEADER for all STM32.
to fix following checkpatch warings.
WARNING: struct should normally be const
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Samsung Exynos 7880 \ 7870 - SoC for mainstream smartphones and tablets
introduced on March 2017.
Features:
- 8 Cortex A53 cores
- ARM Mali-T830 MP3 GPU
- LTE Cat. 7 (7880) or 6 (7870) modem
Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com>
Iterate all pin banks to find a pin
Add pinctrl_ops->request api to configure pctrl
pad register in gpio mode.
Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Signed-off-by: Bharat Gooty <bharat.gooty@broadcom.com>
Acked-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Parse different gpio properties from dt as part of probe
function. This detail is required to enable pinctrl pad
later when gpio lines are requested.
Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
Use this new Kconfig to simplify the compilation conditions where
appropriate.
fix typo in pinctrl Kconfig file to avoid git commit failure on
some commit hooks check.
Signed-off-by: Yuan Fang <fangyuanseu@gmail.com>
Add pinctrl driver for i.MX8ULP
Signed-off-by: Peng Fan <peng.fan@nxp.com>
It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
The PWM pins on North Bridge on Armada 37xx can be configured into PWM
or GPIO functions. When in PWM function, each pin can also be configured
to drive low on 0 and tri-state on 1 (LED mode).
The current definitions handle this by declaring two pin groups for each
pin:
- group "pwmN" with functions "pwm" and "gpio"
- group "ledN_od" ("od" for open drain) with functions "led" and "gpio"
This is semantically incorrect. The correct definition for each pin
should be one group with three functions: "pwm", "led" and "gpio".
Change the "pwmN" groups to support "led" function.
Remove "ledN_od" groups. This cannot break backwards compatibility with
older device trees: no device tree uses it since there is no PWM driver
for this SOC yet. Also "ledN_od" groups are not even documented.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
The width is set up in single_of_to_plat() and can only have three values,
all of which result in a non-zero divisor. Add a comment.
Reported-by: Coverity (CID: 331154)
various minor sandbox improvements
With gcc-11 we get a multiple errors here as the declarations for
mscc_pinctrl_ops and mscc_gpio_ops are missing an extern.
CC: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Lars Povlsen <lars.povlsen@microchip.com>
Cc: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Define LOG_CATEGORY for all uclass to allow filtering with
log command.
Import R8A779A0 V3U PFC tables from Linux 5.12, commit 9f4ad9e425a1
("Linux 5.12") . Add parts of PFC table integration from
pinctrl: renesas: Add R8A779A0 V3U PFC tables
by Hai Pham <hai.pham.ud@renesas.com>" .
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Synchronize R-Car Gen2/Gen3 pinctrl tables with Linux 5.12,
commit 9f4ad9e425a1 ("Linux 5.12") . This is a rather large
commit, since the macros in sh-pfc.h also got updated, so
all the PFC tables must be updated in lockstep.
If reg property of pinctrl-single node requires address translation then
probe fails with following message:
single-pinctrl pinctrl@4301c000: failed to get base register size
This is because driver uses dev_read_addr_size() to get size which also
tries to fetch untranslated addr and fails.
Fix this by using dev_read_addr_size_index() which takes care of address
translation and also makes following dev_read_addr() call redundant.
This fixes Ethernet failures on TI's AM654 based EVMs due to lack of
pinmux configuration.
Fixes: 9fd8a430f3 ("pinctrl: single: get register area size by device API")
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
This commit does the same thing as Linux commit 33def8498fdd.
Use a more generic form for __section that requires quotes to avoid
complications with clang and gcc differences.
Remove the quote operator # from compiler_attributes.h __section macro.
Convert all unquoted __section(foo) uses to quoted __section("foo").
Also convert __attribute__((section("foo"))) uses to __section("foo")
even if the __attribute__ has multiple list entry forms.
The V3U SoC has several unlock registers, one per register group. They
reside at offset zero in each 0x200 bytes-sized block.
To avoid adding yet another table to the PFC implementation, this
patch adds the option to specify an address mask instead of the fixed
address in sh_pfc_soc_info::unlock_reg.
This is a direct port of Linux 5.12 commit e127ef2ed0a6
("pinctrl: renesas: Implement unlock register masks") by
Ulrich Hecht <uli+renesas@fpond.eu>
The help text for Gen2 entries had a copy paste error, still containing
the Gen3 string, while the description was correctly listing Gen2. Fix
the help text.
The help text in the Kconfig file was always a copy of the same thing.
Move single copy into the common PFC driver entry instead. Also fix a
copy-paste error in the PFC help text, which identified PFC as clock.
As reported by Coverity Scan for Das U-Boot, the 'less-than-zero'
comparison of an unsigned value is never true.
Signed-off-by: Dario Binacchi <dariobin@libero.it>
Reviewed-by: Pratyush Yadav <p.yadav@ti.com>
Otherwise it can generate a division by zero, which has an undefined
behavior.
https://source.denx.de/u-boot/custodians/u-boot-ti
- Support for pinmux status command on beaglebone
- Updates for MMC speed modes for J721e-evm
- Fix MMC booting on omap35_logic_somlv board
The test adds two pinmux nodes to the device tree, one to test when a
register changes only one pin's mux (pinctrl-single,pins), and the other
to test when more than one pin's mux is changed (pinctrl-single,bits).
This required replacing the controller's register access functions when
the driver is used on sandbox.
It allows to display the muxing of a given pin. Inspired by more recent
versions of the Linux driver, in addition to the address and the value
of the configuration register I added the pin function retrieved from
the DT. In doing so, the information displayed does not depend on the
platform, being a generic type driver, and it can be useful for debug
purposes.
It returns the name of the requested pin.
It returns the number of selectable pins.
The configuration of pinmux registers was implemented with duplicate
code which can be removed by adding two functions for read/write access.
Access to 8-bit registers has also been added.
The patch is inspired by more recent versions of the Linux driver.
Replacing the default value 0xffffffff of the function mask with 0 is
certainly more conservative in case the "pinctrl-single,function-mask"
DT property is missing.
In more recent versions of the Linux kernel the driver's probe function
returns an error if the "pinctrl-single,register-width" DT property is
missing. The lack of this information, in fact, does not allow to know
whether to access the registers of the controller at 8, 16, ... bits.
