path: root/drivers/power
2013-01-14Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingTom Rini
2013-01-14twl4030: fix 'could could' in error messagesPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2013-01-14Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-10PMIC: MAX77686: Add FDT SupportRajeshwari Shinde
This patch adds fdt support to MAX77686. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
This required manual merging drivers/mtd/nand/Makefile and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
2012-12-11POWER: MAX77686: Modified as per the latest ImplementationRajeshwari Shinde
Moved the pmic_max77686.c max77686_pmic.h to drivers/power and made required changes accordingly Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-10power: twl6035: complain on LDO9 errorVincent Stehlé
We handle i2c_write return code and complain in case of error. We propagate the error, too, to allow better handling at the upper level in the future. Signed-off-by: Vincent Stehlé <v-stehle@ti.com>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-11-14power:pmic: Rename CONFIG_DIALOG_PMIC defines to CONFIG_DIALOG_POWERŁukasz Majewski
Rename CONFIG_DIALOG_PMIC to CONFIG_DIALOG_POWER Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14power:pmic: Rename ./drivers/power/pmic_* to ./drivers/power/power_* filesŁukasz Majewski
Rename pmic/power related files at ./drivers/power directory Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Extend PMIC framework to support battery related commandsŁukasz Majewski
Two extra commands: "pmic name bat state" and "pmic name bat charge" has been added to pmic framework. Those provides state display and charge capabilities to named batteries. The pmic_core.c file has been refactored to more consistent name scheme. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:max8997: Support for MAX8997 internal charger controlŁukasz Majewski
Support for MAX8997 built-in charger. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:max8997: Function for calculating LDO internal register valueŁukasz Majewski
Function for calculating LDO internal register value from passed micro Volt. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:fuel-gauge: Support for MAX17042 fuel-gaugeŁukasz Majewski
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997 power management device. Special file - fg_battery_cell_params.h with cells characteristics added. The FG device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:muic: Support for MUIC built into MAX8997 deviceŁukasz Majewski
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997 power management device. The MUIC device will work with redesigned PMIC framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic:battery: Support for Trats Battery at PMIC frameworkŁukasz Majewski
Trats battery is now treated in the same way as other power related devices. This approach allows for more unified handling of all devices responsible for power management. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-14pmic: Move pmic related code to ./drivers/power directoryŁukasz Majewski
The PMIC framework has been moved to its more natural place ./drivers/power from ./drivers/misc directory. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-05-15i2c: Add TPS6586X driverSimon Glass
This power management chip supports battery charging and a large number of power supplies. This initial driver only provides the ability to adjust the two synchronous buck converters SM0 and SM1 in a stepwise manner. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15omap5: pbias ldo9 turn onBalaji T K
Add omap5 pbias configuration for mmc1/sd lines and set voltage for sd data i/o lines Signed-off-by: Balaji T K <balajitk@ti.com>
2012-05-15power: twl6035: add palmas PMIC supportSRICHARAN R
palmas/TWL6035 is power IC for omap5 evm boards Signed-off-by: Balaji T K <balajitk@ti.com>
2012-03-27twl4030: fix potential power supply handling issuesGrazvydas Ignotas
twl4030_pmrecv_vsel_cfg currently first sets up device group (effectively enabling the supply), and only then sets vsel (selects voltage). This could lead to wrong voltage for a short time, or even long time if second i2c write fails. Fix this by writing vsel first and device group after that. Also introduce error checking to not enable the supply if we failed to set the voltage, and start logging errors as power supply problems are usually important. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2011-12-09omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15VAsh Charles
MMC interfaces are specified to be 3.3V compatible with an operating voltage range of 3.1V to 3.5V for SD cards. This change affects hardware using TWL4030 (TPS6595x) PMICs and should improve the reliability when communicating with marginally-spec'd MMC devices. 3.15V is the highest possible level for this chip. This patch has been tested on a Gumstix Overo board. Signed-off-by: Ash Charles <ash@gumstix.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2011-09-30mmc: omap: config VMMC, MMC1_PBIASBalaji T K
Config VMMC voltage to 3V for MMC/SD card slot and PBIAS settings needed for OMAP4 Fixes MMC/SD detection on boot from eMMC. Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ftpmu010: fix relocation and enhance featuresMacpaul Lin
1. ftpmu010.h: fix and add definitions Enhanced for more features and asm related support according to datasheet. Note: - FTPMU010_PDLLCR0_HCLKOUTDIS is "incorrect" in datasheet. - FTPMU010_PDLLCR0_DLLFRANG is only 1 bit at bit #19. (not 20-19) - FTPMU010_PDLLCR0_HCLKOUTDIS is 4 bits at bit #20. (not 24-21) 2. ftpmu010.c: enhance features and fix relocation - The following functions is added for pmu features. ftpmu010_mfpsr_select_dev() ftpmu010_sdramhtc_set() - This patch also fix the declare statement for relocation. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27power: ftpmu010: move drivers/power/ftpmu010.h to include/faradayPo-Yu Chuang
Also add API declarations. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2011-01-25ftpmu010: support faraday ftpmu010 driverMacpaul Lin
Faraday's ftpmu010 is a power managemnet unit which support cpu sleep and frequency scaling. It has been integrated into many SoC. This patch also move ftpmu010 to a proper place for later enhancement. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-12-11ARMV7: OMAP4: twl6030 add battery charging supportBalaji T K
Add battery charging support twl6030 driver. Add support for battery voltage and current measurements. Add command to get battery status and start/stop battery charging from USB. Signed-off-by: Balaji T K <balajitk@ti.com> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-10Prepare v2010.09-rc1v2010.09-rc1Wolfgang Denk
Coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-08ARMV7: OMAP: add convenience function to set TWL4030 regulator voltagesSteve Sakoman
This patch adds a function to allow one to easily set the target voltage for the TWL4030 regulators. It also modifies the existing code to use this new function. Applicable definitions are moved out of the driver file and into the header file so that they are generally accessible Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add support for the TWL6030 I2C power chip used in OMAP4 systemsSteve Sakoman
This patch add the basic infrastructure for the TWL6030 driver and enables support in the two existing OMAP4 boards, Panda and OMAP4430 SDP Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-07-29OMAP3 Move twl4030 mmc functionTom Rix
Because twl4030 now has its own device files, move and rename twl4030_mmc_config. twl4030_mmc_config initializes the twl4030 power setting to the mmc device. Because it is in the twl4030 power domain, move it out of drivers/mmc/omap3_mmc.c and into drivers/power/twl4030.c. The function was renamed to twl4030_power_mmc_init because all the functions in this file are to have the format twl4030_power_<device>_<action> In this case the suffix is mmc_init so device : mmc action : init Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-29OMAP3 Move twl4030 power and led functionsTom Rix
Because twl4030 now has its own device files, move exiting omap3 power_init_r to a new location. power_init_r is the only function in board/omap3/common. It initializes the twl4030 power for the board and enables the led. The power part of the the function is moved to twl4030_power_init in drivers/power/twl4030.c The power compilation is conditional on the existing config variable CONFIG_TWL4030_POWER. The led part is moved to twl4030_led_init in the new file drivers/misc/twl4030_led.c The led compilation is conditional on the new config variable CONFIG_TWL4030_LED The directory board/omap3/common was removed because power_init_r was the only function in it. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-28TWL4030 Add power reset buttonTom Rix
The Zoom2 power reset button is on the top right side of the main board. Press and hold for about to 8 seconds to completely reset the board. Some of the beta boards have a hardware problem that prevents using this feature. If is difficult to further characterize the boards that fail. So disable resetting for all beta boards. The Zoom1 reset button is the red circle on the top right, front of the board. Press and hold the button for 8 seconds to completely reset the board. After analyzing beagle, it was determined that other boards that use the twl4030 for power managment can also make use this function. The resetting is done by the power management part of the twl4030. Since there is no existing drivers/power, add one. The compilation of power/twl4030.h is controlled by the config variable CONFIG_TWL4030_POWER Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
