path: root/drivers/sk98lin/h/ski2c.h
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
