path: root/drivers/ufs/Makefile
2019-10-23ufs: Add glue layer driver for TI J721E devicesFaiz Abbas
Add glue layer driver for the controller present on TI's J721E devices. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-23ufs: Add Support for Cadence platform UFS driverFaiz Abbas
Add Support for the platform driver for the Cadence device present on TI's J721e device. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-23ufs: Add Initial Support for UFS subsystemFaiz Abbas
Add Support for UFS Host Controller Interface (UFSHCI) for communicating with Universal Flash Storage (UFS) devices. The steps to initialize the host controller interface are the following: - Initiate the Host Controller Initialization process by writing to the Host controller enable register. - Configure the Host Controller base address registers by allocating a host memory space and related data structures. - Unipro link startup procedure - Check for connected device - Configure UFS host controller to process requests Also register this host controller as a SCSI host controller. Taken from Linux Kernel v5.2 (drivers/scsi/ufs/ufshcd.c) and ported to U-boot. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
