path: root/drivers/usb
2008-09-09Make usb-stop() safe to call multiple times in a row.Remy Bohmer
A recent commit (936897d4d1365452bbbdf8430db5e7769ef08d38) enabled the usb_stop() command in common/cmd_bootm.c which was not enabled for some time, because no board did actually set the CFG_CMD_USB flag. So, now the usb_stop() is executed before loading the linux kernel. However, the usb_ohci driver hangs up (at least on AT91SAM) if the driver is stopped twice (e.g. the peripheral clock is stopped on AT91). If some other piece of code calls usb_stop() before the bootm command, this command will hangup the system during boot. (usb start and stop is typically used while booting from usb memory stick) But, stopping the usb stack twice is useless anyway, and a flag already existed that kept track on the usb_init()/usb_stop() calls. So, we now check if the usb stack is really started before we stop it. This problem is now fixed in both the upper as low-level layer. Signed-off-by: Remy Bohmer <linux@bohmer.net> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-09-06USB EHCI: reset root hubYuri Tikhonov
Some of multi-function USB controllers (e.g. ISP1562) allow root hub resetting only via EHCI registers. So, this patch adds the corresponding kind of reset to OHCI's hc_reset() if the newly introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates board). Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-08-31USB: Add support for OHCI controller on S3C6400Guennadi Liakhovetski
Notice: USB on S3C6400 currently works _only_ with switched off MMU. One could try to enable the MMU, but map addresses 1-to-1, and disable data cache, then it should work too and we could still profit from instruction cache. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-12Coding style cleanup, update CHANGELOG, prepare releasev1.3.4Wolfgang Denk
2008-08-12Fix compile error related to r8a66597-hcd & usbKumar Gala
When building the 8544DS board we get this error: In file included from r8a66597-hcd.c:22: u-boot/include/usb.h:190:2: error: #error USB Lowlevel not defined make[1]: *** [r8a66597-hcd.o] Error 1 The cleanest fix is to only build r8a66597-hcd.c if CONFIG_USB_R8A66597_HCD is set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-07usb: add support for R8A66597 usb controllerYoshihiro Shimoda
add support for Renesas R8A66597 usb controller. This patch supports USB Host mode. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-08-07Add support for OMAP5912 and OMAP16xx to usbdcore_omap1510.cHunter, Jon
Add support to drivers/usb/usbdcore_omap1510.c for OMAP5912 and OMAP16xx devices. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-07-30Fix more printf() format warningsJean-Christophe PLAGNIOL-VILLARD
2008-07-13Fix some more printf() format problems.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-07-10fix USB devices with multiple configurationsHarald Welte
This patch fixes bugs in usbdcore*.c related to the use of devices with multiple configurations. The original code made mistakes about the meaning of configuration value and configuration index, and the resulting off-by-one errors resulted in: * SET_CONFIGURATION always selected the first configuration, no matter what wValue is being passed. * GET_DESCRIPTOR/CONFIGURATION always returned the descriptor for the first configuration (index 0). Signed-off-by: Harald Welte <laforge@openmoko.org> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-05-22Fix endianess conversion in usb_ohci.cChristian Eggers
Signed-off-by: Christian Eggers <ceggers@gmx.de> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-05-22USB: add support for multiple PCI OHCI controllersSergei Poselenov
Add new configuration variable CONFIG_PCI_OHCI_DEVNO. In case of several PCI USB controllers on a board this variable specifys which controller to use. Also add USB support for sokrates board. See doc/README.generic_usb_ohci for details. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-04-24USB: remove a cpu bug workaround for an unsupported architecture.Markus Klotzbücher
2008-04-24USB: fix those pesky aliasing warnings issued by gcc-4.2Markus Klotzbücher
Signed-off-by: Markus Klotzbuecher <mk@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-04-17Remove duplicate #undef SHOW_INFO in drivers/usb/usb_ohci.cGururaja Hebbar K R
Signed-off-by: gururaja hebbar <gururajakr@sanyo.co.in>
2008-03-15usb: Add CFG_OHCI_USE_NPS to common USB-OHCI driverStefan Roese
This patch adds CFG_OHCI_USE_NPS to the common USB-OHCI driver. This way a board just needs to define this new option to enable the "force NoPowerSwitching mode" instead of adding new CPU/architecture defines to the USB source itself. This new option will be used first with the new AMCC 460EX Canyonlands board port, which will be posted in a few days. This patch also fixes a small compilation problem when DEBUG is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-12USB: Add Philips 1561 PCI-OHCI idsTsiChung Liew
(needed for M5475EVB) Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-11-25drivers/usb : move usb drivers to drivers/usbJean-Christophe PLAGNIOL-VILLARD
