On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
(cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
Add common widescreen modes 800x480 and 1024x600.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Compiling the 'bmp' command with DM and having one of the following macros
enabled:
CONFIG_BMP_16BPP, CONFIG_BMP_24BPP ONFIG_BMP_32BPP
generates this error:
drivers/video/video_bmp.c: In function ‘video_bmp_display’:
drivers/video/video_bmp.c:315:22: error: ‘lcd_line_length’ undeclared (first use in this function)
fb -= width * 2 + lcd_line_length;
This patch moves to using the correct variable instead and enables the
'bmp' command for DM again.
Commit b02e4044ff8e ("libfdt: Bring in upstream stringlist
functions") broke codying style in some places especially
by inserting an extra whitespace before fdt_stringlist_count().
CONFIG_CONSOLE_SCROLL_LINES
This should be defined in a header file so that arguments are checked.
Move it to video.h.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
This is not used in U-Boot.
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This is not used anywhere in U-Boot.
This is not used in U-Boot anymore.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_VIDEO
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
Now that all x86 boards have been converted to DM video, drop the
legacy drivers.
This converts coreboot to use DM framebuffer driver.
With DM VESA driver on x86 boards, plat->base/size/align are all
zeroes and starting address passed to alloc_fb() happens to be 1MB
aligned, so this routine does not trigger any issue. On QEMU with
U-Boot as coreboot payload, the starting address is within 1MB
range (eg: 0x7fb0000), thus causes failure in video_post_bind().
Actually if plat->size is zero, it makes no sense to do anything
in this routine. Add such check there.
This adds a DM driver for coreboot framebuffer device.
At present only chromebook boards are converted to DM video. Other
x86 boards are still using the legacy cfb_console driver. This
switches to use DM version drivers.
This adds a DM driver for VESA-compatible device.
Update the samus driver to avoid the direct call to the video BIOS setup.
At present we use the legacy vesa driver for graphics. Add a driver which
supports driver model. This can be probed only when needed, removing the
need to start up the display if it is not used.
'enabled' should be 'enables'. Fix it.
Fix spelling of debug message from cnnot to cannot.
Acked-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Now, include/linux/errno.h is a wrapper of <asm-generic/errno.h>.
Replace all include directives for <asm-generic/errno.h> with
<linux/errno.h>.
<asm-generic/...> is supposed to be included from <asm/...> when
arch-headers fall back into generic implementation. Generally, they
should not be directly included from .c files.
[trini: Add drivers/usb/host/xhci-rockchip.c]
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
For vidconsole_post_probe(), it is common coding style to let a
probe method return the value of a register function.
The others will become simple wrapper functions.
When the backlight's pwm input is connected to a pwm output of the SoC,
actually use pwm to drive the backlight.
The mean reason for doing this is to fix the backlight turning off
for aprox. 1 second while the kernel is booting. This is caused by
the kernel actually using pwm to drive the backlight, so that it
can dim the backlight. First the pwm driver loads and switches the
pinmux for the pin driving the backlight's pwm input to the pwm
controller. Then about 1s later the actual backlight driver loads
and tells the pwm driver to actually update the pwm settings, which
have a power-on-reset value of "off".
An additional advantage is that this allows us to initatiate the
backlight at 80%, which is the kernel default, avoiding a brightness
change while the kernel loads.
Reviewed by: Peter Korsgaard <peter@korsgaard.com>
The current code picks the first available clock. In U-Boot proper this is
the oscillator device, not the SoC clock device. As a result the HDMI display
does not work.
Fix this by calling rockchip_get_clk() instead.
Fixes: 135aa950 (clk: convert API to match reset/mailbox style)
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
The CONFIG_HIDE_LOGO_VERSION config can be used to disable putting the
U-Boot version string on top of the logo.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
This seems to give the best performance, so let's use it always.
We have standard drivers for panels and backlights which can do most of the
work for us. Move the tegra20 LCD driver over to use those instead of custom
code.
This patch includes device tree changes for the nvidia boards. I have only
been able to test seaboard. If this patch is applied, these boards will
also need to be synced with the kernel, and updated to use display-timings:
- colibri
- medcom-wide
- paz00
- tec
Waiting 30 seconds for the hpd to go high seems a bit much, especially
on headless boots. Lowering the timeout to 300ms.
Sending as RFC because frankly i don't know what a sensible timeout is
here, but 30 seconds is clearly not it :)
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Dropped RFC tag:
The following changes are made to the clock API:
* The concept of "clocks" and "peripheral clocks" are unified; each clock
provider now implements a single set of clocks. This provides a simpler
conceptual interface to clients, and better aligns with device tree
clock bindings.
* Clocks are now identified with a single "struct clk", rather than
requiring clients to store the clock provider device and clock identity
values separately. For simple clock consumers, this isolates clients
from internal details of the clock API.
* clk.h is split so it only contains the client/consumer API, whereas
clk-uclass.h contains the provider API. This aligns with the recently
added reset and mailbox APIs.
* clk_ops .of_xlate(), .request(), and .free() are added so providers
can customize these operations if needed. This also aligns with the
recently added reset and mailbox APIs.
* clk_disable() is added.
* All users of the current clock APIs are updated.
* Sandbox clock tests are updated to exercise clock lookup via DT, and
clock enable/disable.
* rkclk_get_clk() is removed and replaced with standard APIs.
Buildman shows no clock-related errors for any board for which buildman
can download a toolchain.
test/py passes for sandbox (which invokes the dm clk test amongst
others).
Add driver-model support to this driver. Most features can be controlled
from the device tree.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Adjust the driver to use struct display_timing for its display timing.
This is what is used by driver-model and allows the LCD init code to be
common.
configs/peach-pi_defconfig
configs/peach-pit_defconfig
