path: root/drivers/watchdog/at91sam9_wdt.c
2015-02-07arm, at91, wdt: make timeout configurableHeiko Schocher
make the HW WDT timeout configurable through the define CONFIG_AT91_HW_WDT_TIMEOUT. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-05-18AT91: fix at91sam_wdt.c to reworked header filesReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-05-18AT91: fix related at91 driver filesReinhard Meyer
2010-04-03Convert at91 watchdog driver to new SoC accessAchim Ehrlich
This converts the at91 watchdog driver to new c structure type to access registers of the SoC Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2009-04-04at91sam9: add watchdog supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
