path: root/drivers
2019-07-07Merge tag 'video-for-2019.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-video - fix pwm backlight
2019-07-06video: backlight: fix pwm inversionMarc Dietrich
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is not implemented, leaving the backlight dark. Fix this by returning no error if set_invert() is not implemented and no polarity change is requested. Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell") Signed-off-by: Marc Dietrich <marvin24@gmx.de>
2019-07-05usb: dwc3: Use UCLASS_NOP instead of UCLASS_MISC for the DWC3 generic glueJean-Jacques Hiblot
dwc3-generic has been broken since MISC uclass has been modified to scan DT sub-nodes after bind. Fixing it by a using the no-op uclass. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-05dm: Add a No-op uclassJean-Jacques Hiblot
This uclass is intended for devices that do not need any features from the uclass, including binding children. This will typically be used by devices that are used to bind child devices but do not use dm_scan_fdt_dev() to do it. That is for example the case of several USB wrappers that have 2 child devices (1 for device and 1 for host) but bind only one at a any given time. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-07-05usb: dwc3-generic: remove dm_scan_fdt_dev() from the remove() callbackJean-Jacques Hiblot
There is simply no reason to do that here. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-07-05usb: ehci-mx6: Fix bus enumeration for DM caseMarek Vasut
The EHCI iMX6 driver is only partly converted to DT probing and still uses a tremendous amount of hard-coded addresses. Worse, the driver uses hard-coded SoC-model-specific base addresses, which are derived from values protected by SoC-specific macros, hence the driver is also compiled for a specific SoC model. Even worse, the driver depends on specific sequential indexing of the controllers, from which it derives offsets in the PHY and ANATOP register sets. However, when the driver is probed from DT, the indexing is not correct. In fact, each controller has index 0. This patch derives the index for DT probing case from the controller base addresses, which is not the way this should be done, however it is the least intrusive approach, favorable this close to release. The necessary steps to convert this driver fully to DT probing are described inside the patch, however this should be done in the next release and depends on iMX clock driver patches. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Abel Vesa <abel.vesa@nxp.com> Cc: Adam Ford <aford173@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Ludwig Zenz <lzenz@dh-electronics.com> Cc: Lukasz Majewski <lukma@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Vagrant Cascadian <vagrant@debian.org>
2019-06-29pinctrl: uniphier: Add SPI pin-mux settingsKunihiko Hayashi
Add pin-mux settings for SPI controller. Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-06-28Merge tag 'u-boot-imx-20190628' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx Fixes for 2019.07 - menlo board - allow SDB on Sabre - HAB for mx6sl - apalis board
2019-06-27usb: gadget: f_sdp: Allow SPL to load and boot FIT via SDPFrieder Schrempf
Add support for loading u-boot FIT images over the USB SDP protocol in the SPL Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de> [Various build fixes] Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Tested-by: Fabio Estevam <festevam@gmail.com> Tested-by: Lukasz Majewski <lukma@denx.de>
2019-06-22Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86Tom Rini
- boot failure fix for Intel edison - tangier wdt conversion to driver model
2019-06-22watchdog: tangier: Convert to use WDT classAndy Shevchenko
Convert legacy driver to use watchdog class. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-06-22watchdog: tangier: Replace unused constant with a commentAndy Shevchenko
The default timeout value had been left in order to leave some traces about default setup of watchdog done by firmware. For better understanding and compiler burden, replace it with a comment. Suggested-by: Stefan Roese <sr@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-21pci: Avoid assigning PCI resources that are below 0x1000Bin Meng
commit b7598a43f2b4 ("[PATCH] Avoid assigning PCI resources from zero address") only moved the bus lower address to 0x1000 if the given bus start address is zero. The comment said 0x1000 is a reasonable starting value, hence we'd better apply the same adjustment when the given bus start address is below 0x1000. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-06-20Fix watchdog timeout setup for mt7623Shannon Barber
Signed-off-by: Shannon Barber <sbarber@dataspeedinc.com>
2019-06-20aspeed/watchdog: Correct timeout valueJoel Stanley
The driver was using milliseconds and programming it into a register which takes ticks of the watchdog clock, which runs at 1MHz. This meant we were off by 1000 with the desired value. When 06985289d452 ("watchdog: Implement generic watchdog_reset() version") was added the aspeed board would leave the watchdog running, causing it to bite before u-boot was done. Discovered by booting in qemu: $ qemu-system-arm -M ast2500-evb -drive file=test.img,format=raw,if=mtd -nographic -no-reboot -d cpu_reset U-Boot 2019.07-rc3-00091-g2253e40caef5 (Jun 06 2019 - 16:53:23 +0930) Model: Aspeed BMC DRAM: 496 MiB WDT: Started with servicing (60s timeout) MMC: In: serial@1e784000 Out: serial@1e784000 Err: serial@1e784000 Watchdog timer expired. Fixes: 06985289d452 ("watchdog: Implement generic watchdog_reset() version") Signed-off-by: Joel Stanley <joel@jms.id.au>
2019-06-20Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xxTom Rini
- PCIe driver change to support DM model - T2080QDS migrated to use PCIe DM model
2019-06-20Merge tag 'u-boot-stm32-20190619' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-stm - Update STM32MP entry in MAINTAINERS - Handle correctly binding for g-tx-fifo-size for USB DWC2 driver - Fix trusted STM32MP1 defconfig with correct ethernet driver
2019-06-20Merge tag 'mmc-6-19' of https://github.com/MrVan/u-bootTom Rini
- Avoid HS400 mode when accessing boot partitions
2019-06-20dm: pci: add Freescale PowerPC PCIe driverHou Zhiqiang
Add PCIe DM driver for Freescale PowerPC PCIe controllers. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- LS1046AFRWY support - USB errata fix and secure boot defconfig support for LS1028A - Enabled SDHC and SATA for LX2160 - LS1046A serdes fixes - other minor fixes
2019-06-19usb: dwc2: allow peripheral mode for OTG configurationPatrick Delaunay
Allow device mode in DWC2 driver when device tree select the dr_mode "peripheral" or "otg". The device mode is not allowed when dr_mode = "host" in device tree. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Marek Vasut <marex@denx.de>
2019-06-19usb: dwc2: correctly handle binding for g-tx-fifo-sizePatrick Delaunay
Manage g-tx-fifo-size as a array as specify in the binding. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Marek Vasut <marex@denx.de>
2019-06-19mmc: fsl_esdhc: fix probe issue without CONFIG_BLK enabledYangbo Lu
u-boot is trying to make CONFIG_BLK as a hard requirement for DM_MMC. But now it's still not. config BLK bool "Support block devices" depends on DM default y if DM_MMC When fsl_esdhc driver was reworked for DM_MMC support, DM_MMC without CONFIG_BLK enabled wasn't considered. This patch is to fix probe issue without CONFIG_BLK enabled. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19mmc: Avoid HS400 mode when accessing boot partitionsMarek Vasut
U-Boot code currently only applies this restriction to HS200 mode, extend this to HS400 mode as well. Currently U-Boot code not support accessing boot partition in HS200/400 mode. This needs more check. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Peng Fan <peng.fan@nxp.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
- Assorted gadget fixes
2019-06-14fastboot: Check if partition really exist in getvar_has_slot()Igor Opaniuk
Currently getvar_has_slot() invocation for "boot" and "system" partitions always returns affirmative response regardless the fact of existence of these partitions, which leads to impossibility to flash them on old non-A/B AOSP setups, where _a/_b suffixes aren't used: $ fastboot flash boot boot.img Sending 'boot__a' (11301 KB) OKAY [ 0.451s] Writing 'boot__a' FAILED (remote: 'cannot find partition') fastboot: error: Command failed Although partition layout is: -> part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000800 0x000107ff "boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: ea2e2470-db4a-d646-b828-10167f736d63 2 0x00010800 0x000127ff "environment" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 10a819d2-6004-3d48-bd87-114e2a796db9 3 0x00012800 0x0001a7ff "recovery" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 9ea116e4-8a34-0c48-8cf5-2fe9480f56cd 4 0x0001a800 0x0031a7ff "system" attrs: 0x0000000000000000 ...... This patch adds checks of existence for requested partitions on eMMC/NAND. Fixes: f73a7df984a9 ("net: fastboot: Merge AOSP UDP fastboot") Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2019-06-14fastboot: getvar: Refactor fastboot_*_get_part_info() usageSam Protsenko
Extract fastboot_*_get_part_info() usage for MMC and NAND into getvar_get_part_info() function, as it will be needed further in other functions. This way we can avoid code duplication and mess with preprocessor directives across all points of usage. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-14fastboot: Use const qualifier for char *part_nameSam Protsenko
In fastboot_*_get_part_info() functions we can use stronger typing by expecting const strings. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-06-14fastboot: Fix slot names reported by getvarSam Protsenko
In commit [1] fastboot tool was changed w.r.t. new A/B specification [2], and now we should report slot names in "a" format instead of "_a". Latter is now considered legacy and we shouldn't rely on that anymore. Due to this one can observe next error with recent fastboot tool: $ fastboot flash boot boot.img Sending 'boot__a' (11301 KB) OKAY [ 0.451s] Writing 'boot__a' FAILED (remote: 'cannot find partition') fastboot: error: Command failed Let's use new slot format in order to fix double underscores "__" and to be in sync with AOSP master. [1] https://android.googlesource.com/platform/system/core/+/8091947847d5e5130b09d2ac0a4bdc900f3b77c5 [2] https://source.android.com/devices/tech/ota/ab/ab_implement#partitions Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2019-06-13spi: Kconfig: Mark LPC32XX_SSP as DEPRECATEDJagan Teki
Mark LPC32XX_SSP as DEPRECATED, this so the resulting build shows warning for deprecated configuration enabled and associated code will remove in v2019.07 release. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Sylvain Lemieux <slemieux@tycoint.com> [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13spi: Kconfig: Mark SOFT_SPI as DEPRECATEDJagan Teki
Mark SOFT_SPI as DEPRECATED, this so the resulting build shows warning for deprecated configuration enabled and associated code will remove in v2019.07 release. Cc: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13spi: Kconfig: Mark SH_SPI as DEPRECATEDJagan Teki
Mark SH_SPI as DEPRECATED, this so the resulting build shows warning for a deprecated configuration enabled and associated code will remove in v2019.07 release. Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13spi: Kconfig: Mark MXS_SPI has DEPRECATEDJagan Teki
Mark MXS_SPI as DEPRECATED, this so the resulting build shows warning for broken configuration enabled and associated code will remove in v2019.07 release. Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-12Merge tag 'u-boot-amlogic-20190612' of git://git.denx.de/u-boot-amlogicTom Rini
- pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groups - pinctrl: meson-gxbb: add hdmi related pins to fix HDMI on GXBB - pinctrl: meson: add support for getting pinmux status - pinctrl: meson-g12a: add support for drive-strength-microamp property
2019-06-12pinctrl: meson-gxbb: add hdmi related pinsMaxime Jourdan
The GXBB pinctrl is missing pins related to HDMI, namely hot plug detection (hpd) and I2C (sda + scl). This fixes HDMI support for GXBB in u-boot. Reported-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-12pinctrl: meson: g12a: add DS bank valueGuillaume La Roque
add drive-strength bank regiter and bit value for G12A SoC Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Tested-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-12pinctrl: meson: add support of drive-strength-microampGuillaume La Roque
drive-strength-microamp is a new feature needed for G12A SoC. the default DS setting after boot is usually 500uA and it is not enough for many functions. We need to be able to set the drive strength to reliably enable things like MMC, I2C, etc ... Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Tested-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-12pinctrl: meson-axg: add support for getting pinmux statusNeil Armstrong
In order to support the "pinmux status" command, use the common functions to get the pins count and names, and add the AXG specific function to get the current function from registers. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-12pinctrl: meson-gx: add support for getting pinmux statusNeil Armstrong
In order to support the "pinmux status" command, use the common functions to get the pins count and names, and add the GX specific function to get the current function from registers. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Maxime Jourdan <mjourdan@baylibre.com>
2019-06-12pinctrl: meson: add common function to get pins nameNeil Armstrong
In order to support the "pinmux status" command, add common function to get pins count and pin name. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-12pinctrl: meson-gx: fix GPIO_TEST_N and GPIOCLK_ groupsNeil Armstrong
The GPIO_TEST_N was in the wrong pmx group table, move it back with the AO groups, GPIODV_18 was missing, add it back, and finally the GPIOCLK_* group names were missing. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-06-11Merge tag 'u-boot-stm32-20190606' of https://github.com/pchotard/u-bootTom Rini
- Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
2019-06-11Merge tag 'u-boot-imx-20190612' of git://git.denx.de/u-boot-imxTom Rini
u-boot-imx-20190612 -------------------- - Board fixes: - imx6logic - wandboard - mx6sabre boots again - imx8qm_mek - pico-* boards - Toradex apalis / colibri - engicam imx6 (environment) - KP MX53 - opos6ul - Switch to DM: - vining2000 - dh MX6 - Toradex colibri i.MX7 - Novena - Security : fix CSF size for HAB - Other: - imx: fix building for i.mx8 without spl - pcie and switch to DM mx6sabreauto: Enable SPL SDP support
2019-06-11pinctrl: imx: Define imx6_pinctrl_soc_info in .data sectionLukasz Majewski
This commit is necessary to be able to re-use the pinctrl code in early SPL to properly configure pins. The problem is that those "static" structures (without explicit initialization) are placed in the SDRAM area, which corresponds to u-boot proper (not even SPL). Hence, when one wants to configure pins before relocation via DTS/DM, the board hangs (imx6q SoC powered one) as only OCRAM area is available (0x009xxxxx). This commit prevents from this issue by moving the imx6_pinctrl_soc_info structure to data section (from BSS). Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-06-11net: fec_mxc: not access reserved register on i.MX8Peng Fan
We should not access reserved register on i.MX8, otherwise met SERROR Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-06-11serial: mxc: Add iMX6SX compatible stringMarek Vasut
Add compatible string for iMX6SX. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Silvio Fricke <silvio.fricke@softing.com> Cc: Stefano Babic <sbabic@denx.de>
2019-06-11pci: imx: Add DM and DT supportMarek Vasut
Add DM support and support for probing the iMX PCI driver from DT. The legacy non-DM support is retained, however shall be removed once DM PCI is the only option remaining. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-11pci: imx: Pass driver private data aroundMarek Vasut
Pass the driver private data around the driver as much as possible, instead of having it as a static global variable. This is done in preparation for the DM conversion, no functional change. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-11pci: imx: Fix potential 64bit memory access clampingMarek Vasut
The driver limits the config space base to 32bit, however it can be 64bit on 64bit iMX hardware too. Remove that limitation. This patch has no impact on the iMX6, which is the only SoC currently supported by this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
