These two files have patch merge markers in them, within comments or
strings. Remove then, so that a search for merge markers does not show up
matches in these files.
Reviewed-by: Jagan Teki <jteki@openedev.com>
Patch queue for efi - 2016-10-19
Highlights this time around:
- Add run time service (power control) support for PSCI (fixed in v3)
- Add efi gop pointer exposure
- SMBIOS support for EFI (on ARM)
- efi pool memory unmap support (needed for 4.8)
- initial x86 efi payload support (fixed up in v2)
- various bug fixes
include/tables_csum.h
The CPU udevice already has a few callbacks to retreive information
about the currently running CPUs. This patch adds a new get_vendor()
call that returns the vendor of the main CPUs.
The initial design of the UniPhier clk driver for U-Boot was not
very nice. Here is a re-work to sync it with Linux's clk and reset
drivers, maximizing the code reuse from Linux's clk data.
Marek reports warnings in UniPhier pinctrl drivers when compiled by
GCC 6.x, like:
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c:58:18: warning:
'usb3_muxvals' defined but not used [-Wunused-const-variable=]
static const int usb3_muxvals[] = {0, 0};
My intention here is to compile minimum set of pin data for SPL to
save memory footprint, but GCC these days is clever enough to notice
unused data arrays.
We can fix it by sprinkling around __maybe_unused on those arrays,
but I did not do that because they are counterparts of the pinctrl
drivers in Linux. All the pin data were just copy-pasted from Linux
and are kept in sync for maintainability.
I chose a bit tricky way to fix the issue; calculate ARRAY_SIZE of
*_pins and *_muxvals and set their sum to an unused struct member.
This trick will satisfy GCC because the data arrays are used anyway,
but such data arrays will be dropped from the final binary because
the pointers to them are not used.
Reported-by: Marek Vasut <marex@denx.de>
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
eth-uclass.c expects DM-capable Ethernet adapters to implement ops->
read_rom_hwaddr(), or for some other mechanism to set pdata->enetaddr, or
for the user to set environment variable $usbethaddr. Without any of
these, it will refuse to initialize the device since no valid MAC address
is known. Implement this function for the smsc95xx driver.
With this feature implemented, there is no point smsc95xx_init_common()
re-reading the MAC address from ROM, so ifdef out this code when DM_ETH
is enabled.
This allows (at least) the built-in Ethernet on the NVIDIA Harmony board
to operate again.
Fixes: 0990fcb77219 ("net: smsc95xx: Add driver-model support")
The call to flush cache on the transmit buffer was misplaced (for very
short packets) and asked to flush less than a cacheline.
Move the flush cache call to after a short packet has been padded
to minimum length (so the padding is flushed too), and round the size
up to a cacheline.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
On some boards these switches are wired directly into a SERDES
interface on another Ethernet MAC. Add the ability to specify
these kinds of boards using CONFIG_MV88E61XX_FIXED_PORTS which defines
a bit mask of these fixed ports.
The Marvell Link Street mv88e60xx is a series of FastEthernet switch
chips, some of which also support Gigabit ports. It is similar to the
mv88e61xx series which support Gigabit on all ports.
The main difference is the number of ports. Which affects the
PORT_COUNT define and the size of the mask passed to
mv88e61xx_port_set_vlan().
Other than that it's just a matter of adding the appropriate chip
IDs.
Cc: Joshua Scott <joshua.scott@alliedtelesis.co.nz>
source selection
cpsw driver supports only selection of phy mode in control module
but control module has more setting like RGMII ID mode selection,
RMII clock source selection. So ported to cpsw-phy-sel driver
from kernel to u-boot.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
In the current driver implementation, config() callback is common
for AR8035 and AR8031 phy. In config() callback, driver tries to
configure MMD Access Control Register and MMD Access Address Data
Register unconditionally for both phy versions which leads to
auto negotiation failure in AM335x EVMsk second port which uses
AR8031 Giga bit RGMII phy. Fixing this by adding separate config
for AR8031 phy.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
This adds support for internal delay on RX and TX on RGMII interface for the
AR8035 phy.
This is basically the same Linux driver do. Tested on a Zynq Zturn board (for
which u-boot support in is my tree; first patch waiting ML approval)
Signed-off-by: Andrea Merello <andrea.merello@gmail.com>
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Now that all x86 boards have been converted to DM video, drop the
legacy drivers.
This converts coreboot to use DM framebuffer driver.
With DM VESA driver on x86 boards, plat->base/size/align are all
zeroes and starting address passed to alloc_fb() happens to be 1MB
aligned, so this routine does not trigger any issue. On QEMU with
U-Boot as coreboot payload, the starting address is within 1MB
range (eg: 0x7fb0000), thus causes failure in video_post_bind().
Actually if plat->size is zero, it makes no sense to do anything
in this routine. Add such check there.
This adds a DM driver for coreboot framebuffer device.
vbe_setup_video_priv() might be useful to other drivers.
At present only chromebook boards are converted to DM video. Other
x86 boards are still using the legacy cfb_console driver. This
switches to use DM version drivers.
With DM conversion, information like "Video: 1024x768x16" is not
shown anymore. Now add these verbose output back.
This adds a DM driver for VESA-compatible device.
Move crosec commands from drivers/misc/cros_ec.c to
cmd/cros_ec.c
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Miao Yan <yanmiaobest@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: u-boot@lists.denx.de
The driver provides regulator set/get voltage
enable/disable functions for lp873x family of PMICs.
Add support to bind the regulators/child nodes with the pmic.
enable/disable functions for palmas family of PMICs.
Also adds the pmic i2c based read/write funtions to access pmic
registers.
Add support for gpio regulators. As of now this driver caters
to gpio regulators with one gpio. Supports setting voltage values to gpio
regulators and retrieving the values.
These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
This gives a build warning on 64-bit x86. Fix it.
Acked-by: Heiko Schocher <hs@denx.de>
Fix a cast that causes warnings on 64-bit machines.
We should consistently use %z with size_t, and avoid passing a uint32_t as
a size_t value. Fix these issues to avoid warnings on 64-bit machines.
For 64-bit x86, __I386__ should perhaps not be defined. It is not clear from
the definition, but let's use CONFIG_X86 to be sure.
Update the samus driver to avoid the direct call to the video BIOS setup.
At present we use the legacy vesa driver for graphics. Add a driver which
supports driver model. This can be probed only when needed, removing the
need to start up the display if it is not used.
Provide a function to run the Vesa BIOS for a given PCI device and obtain
the resulting configuration (e.g. display size) for use by the video
uclass. This makes it easier to write a video driver that uses vesa and
'enabled' should be 'enables'. Fix it.
It is useful in debug() statements to display the name of the uclass for a
device. Add a simple function to provide this.
This makes the assumption that setting up pinctrl in cpu_init_r() is safe.
On samus we need GPIOs before relocation in order to support power control.
This commit fixes the following message on boot:
initcall sequence ffe5c6f4 failed at call ffe01d3d (err=-1)
### ERROR ### Please RESET the board ###
In any case it seems better to leave init to driver model, so that it can
pick up the GPIO driver when it needs it. Since pinctrl is a dependency of
the GPIO driver, we may as well put the dependency there and avoid these
problems.
This reverts commit 9769e05bcf79939bad23a719982dd1f85a110f3c.
