This fixes have been backported from Linux 4.1 and seem to fix the
PEB leak warnings and alleviate fastmap being corrupted or marked
invalid by U-Boot.
* 2015.04-toradex-next-fastmap-fixes:
UBI: Fastmap: Set used_ebs only for static volumes
UBI: Fastmap: Fix leb_count unbalance
UBI: Fastmap: Switch to ro mode if invalidate_fastmap() fails
UBI: Fastmap: Remove eba_orphans logic
UBI: Fastmap: Remove bogus ubi_assert()
UBI: Fastmap: Fix memory leak while attaching
UBI: Fastmap: Don't allocate new ubi_wl_entry objects
UBI: Fastmap: Care about the protection queue
UBI: Fastmap: Calc fastmap size correctly
UBI: add missing kmem_cache_free() in process_pool_aeb error path
UBI: fastmap: do not miss bit-flips
UBI: fix the volumes tree sorting criteria
UBI: fix rb_tree node comparison in add_map
This resyncs the driver changes with the Linux version of the
driver. The driver received some feedback in the LKML and got
recently acceppted, the latest version can be found here:
https://lkml.org/lkml/2015/9/2/678
Notable changes are:
- On ECC error, reread OOB and count bit flips in OOB too.
If flipped bits are below threshold, also return an empty
OOB buffer.
- Return the amount of bit flips in vf610_nfc_read_page.
- Use endianness aware vf610_nfc_read to read ECC status.
- Do not enable IDLE IRQ (since we do not operate with an
interrupt service routine).
- Use type safe struct for buffer variants (vf610_nfc_alt_buf).
- Renamed variables in struct vf610_nfc (column and page_sz)
to reflect better what they really representing.
The U-Boot version currently does not support RAW NAND write
when using the HW ECC engine.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
If we set it for dynamic ones we might confuse various self checks.
Signed-off-by: Richard Weinberger <richard@nod.at>
If a LEB is unmapped we have to decrement leb_count as well.
We have to switch to ro mode to guarantee that upon next UBI attach
all data is consistent.
This logic is in vain as we treat protected PEBs also as used, so this
case must not happen.
If a PEB is found which is in the EBA table but not known as used
has to be issued as fatal error.
It is legal to have PEBs left in the used list.
This can happen if UBI copies a PEB and a powercut happens
between writing a new fastmap and adding this PEB into the EBA table.
In this case the old PEB will be used.
Currently we leak a few ubi_ainf_pebs while attaching.
There is no need to allocate new ones every time, we can reuse
the existing ones.
This makes the code cleaner and more easy to follow.
Reviewed-by: Tanya Brokhman <tlinder@codeaurora.org>
Reviewed-by: Guido MartÃnez <guido@vanguardiasur.com.ar>
Fastmap can miss a PEB if it is in the protection queue
and not jet in the used tree.
Treat every protected PEB as used.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
We need to add fm_sb too.
I ran into this error after a ubiupdatevol, because I forgot to backport
e9110361a9a4 UBI: fix the volumes tree sorting criteria.
UBI error: process_pool_aeb: orphaned volume in fastmap pool
UBI error: ubi_scan_fastmap: Attach by fastmap failed, doing a full scan!
kmem_cache_destroy ubi_ainf_peb_slab: Slab cache still has objects
CPU: 0 PID: 1 Comm: swapper Not tainted 3.14.18-00053-gf05cac8dbf85 #1
[<c000d298>] (unwind_backtrace) from [<c000baa8>] (show_stack+0x10/0x14)
[<c000baa8>] (show_stack) from [<c01b7a68>] (destroy_ai+0x230/0x244)
[<c01b7a68>] (destroy_ai) from [<c01b8fd4>] (ubi_attach+0x98/0x1ec)
[<c01b8fd4>] (ubi_attach) from [<c01ade90>] (ubi_attach_mtd_dev+0x2b8/0x868)
[<c01ade90>] (ubi_attach_mtd_dev) from [<c038b510>] (ubi_init+0x1dc/0x2ac)
[<c038b510>] (ubi_init) from [<c0008860>] (do_one_initcall+0x94/0x140)
[<c0008860>] (do_one_initcall) from [<c037aadc>] (kernel_init_freeable+0xe8/0x1b0)
[<c037aadc>] (kernel_init_freeable) from [<c02730ac>] (kernel_init+0x8/0xe4)
[<c02730ac>] (kernel_init) from [<c00093f0>] (ret_from_fork+0x14/0x24)
UBI: scanning is finished
Freeing the cache in the error path fixes the Slab error.
Tested on at91sam9g35 (3.14.18+fastmap backports)
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Cc: stable <stable@vger.kernel.org> # 3.10+
The return value from 'ubi_io_read_ec_hdr()' was stored in 'err', not in 'ret'.
This fix makes sure Fastmap-enabled UBI does not miss bit-flip while reading EC
headers, events and scrubs the affected PEBs.
This issue was reported by Coverity Scan.
Artem: improved the commit message.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Acked-by: Richard Weinberger <richard@nod.at>
Commig "604b592 UBI: fix rb_tree node comparison in add_map"
broke fastmap backward compatibility and older fastmap images
cannot be mounted anymore. The reason is that it changes the
volumes RB-tree sorting criteria. This patch fixes the problem.
Artem: re-write the commit message
The comparisons used in add_vol() shouldn't be identical. Pretty sure
the following is correct but it is completely untested.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
These methods should be passed a slave device, not a bus. This matches the
old SPI interface. It is important to know which device is claiming the bus
so passing a bus is not that useful.
Reported-by: Haikun Wang <haikun.wang@freescale.com>
Tested-by: Peng Fan <Peng.Fan@freescale.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Move the Freescale DSPI driver over to driver model.
Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com>
On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
Introduce cache alignment bounce buffer to workaround issues as follows:
Loading file '/boot/zImage' to addr 0x01000000 with size 4499152 (0x0044a6d0)...
ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108
Done
Kernel image @ 0x1000000 [ 0x000000 - 0x44a6d0 ]
Starting kernel ...
undefined instruction
pc : [<005ff03c>] lr : [<0000800c>]
sp : 0144b6e8 ip : 01000188 fp : 0144a6c8
r10: 00000000 r9 : 411fc090 r8 : 00000100
r7 : 00000cfb r6 : 0144a6d0 r5 : 00000000 r4 : 00008000
r3 : 0000000c r2 : 00000100 r1 : 00000cfb r0 : 00000000
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer
alignment into account which led to failures of the following form:
When there is no framebuffer allocated, e.g. no video environment
variable or an error during initialization, the framebuffer location
ends up to be NULL, in which case the fixup function calculates a
bogus memory size. Use the framebuffer size to make sure that memory
size is calculated right in any case.
Add a weak function board_ehci_hcd_init which can be used by the board
file for board specific initialisation.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The serial_mxc UART can use DTE and DCE mode (i.e End device vs. modem).
This adds DTE mode capability to the driver.
In order to switch from the default DCE to DTE mode define CONFIG_MXC_UART_DTE.
Integrate 16-bit BCH ECC handling required e.g. for the latest NAND
parts assembled on Colibri T20.
Fix PIO read_byte() implementation not only used for the legacy READ ID
but also the PARAM command now required for proper ONFI detection.
This fix is inspired by Lucas Stach's Linux Tegra NAND driver of late.
While at it also disable subpage writes.
Align the reported memory size to 1MiB, which is the section size
in the Linux memory managment system. This avoids triggering an
issue which leads to freeze the Linux kernel very early:
http://thread.gmane.org/gmane.linux.ports.arm.kernel/408378
Add common widescreen modes 800x480 and 1024x600.
Add GPIO support to Freescale VF610
Like SPI and I2C few GPIO controllers also have multiple chip instances.
This patch adds the flag 'DM_UC_FLAG_SEQ_ALIAS' in gpio_uclass driver
to control device sequence numbering. By defalut the dev->r_seq for gpio_uclass
will alwalys returns -1, which leads the gpio driver probe failure.
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
When enabling the DCU and pixel clock, the test mode is activated
since this is the reset configuration. The test mode immediately
shows a red screen on a LCD. A moment later, the DCU gets
initialized properly.
This patch enables the pixel clock after initialization of the DCU
control register. This avoids this initial flicker on LCD screens.
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
This patch fixes operation of our on-board AX88772B chip without EEPROM
but with a ethaddr coming from the regular U-Boot environment. This is
a forward port of some remaining parts initially implemented by
Antmicro.
(cherry picked from commit 67c3a4aee6c0af124ce779aed1be70c7a92d0916)
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
Hack driver to avoid the following error for now. This is required for
unprogrammed i210 operation.
e1000: e1000#0: ERROR: Hardware Initialization Failed
(cherry picked from commit 02bf24ad4a7c882e25771f656b973d5458695cf0)
(cherry picked from commit 68cecfdbe342f800a0b1f10a1f8fb019b491f04b)
This changes enable ONFI detection. The Read ID command now allows
one address byte which is needed for ONFI detection. To read the
ONFI parameter page, the NAND_CMD_PARAM need to be supported. The
CMD code enables one command and one address byte along with reading
data from flash using R/B#, as specified by ONFI.
Add option to choose between current 24-error correction and 32-error
correction through Kconfig. 32-error correction allow to use NAND
chips which require up to 8-bit error correction per 512 byte (when
using 2K pages).
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
Use in-band bad block table (NAND_BBT_NO_OOB) which allows to
use the full OOB for hardare ECC purposes. Since there is no
ECC correction on the OOB it is also safer to use in-band area
to store the bad block table marker.
Implement read of OOB area only. When using column and sector size
properties, only parts of the page can be read. However, this works
only when hardware ECC is disabled, otherwise the ECC engine would
ruin the data in the buffer. To allow OOB only reads, three points
had to be addressed:
- Set ECC mode per command.
- Handle NAND_CMD_READOOB seperate. Make sure column and sector
size is correctly set up, while disabling ECC.
- Now, the OOB data end up at the beginning of the buffer. Remove
the special handling of OOB (spareonly).
Especially bad block scans benefit from this change. On a 512MiB
SLC NAND device, the bad block scan took 1.5s less than before.
Allow bit flips in a empty page up to half of the recoverable
bits (strength / 2).
Since we do not support sub-page writes anyway, reading the page
back to the controller on SEQIN command is not required. Remove
the page read on SEQIN.
However, the column/page values relevant to the SEQIN command, hence
set the column/row address on SEQIN command.
To improve performance we remember the current page in the buffer
and avoid reading it twice. This implicit page cache increases
complexity while does not increase performance in real world cases.
This patch removes that feature.
Acked-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
This driver only supports Driver Model, not legacy model.
