path: root/env/common.c
2022-01-19doc: replace @return by Return:Heinrich Schuchardt
Sphinx expects Return: and not @return to indicate a return value. find . -name '*.c' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; find . -name '*.h' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-11-16bootm: Tidy up use of autostart env varSimon Glass
This has different semantics in different places. Go with the bootm method and put it in a common function so that the behaviour is consistent in U-Boot. Update the docs. To be clear, this changes the way that 'bootelf' and standalone boot work. Before, if autostart was set to "fred" or "YES", for example, they would consider that a "yes". This may change behaviour for some boards, but the only in-tree boards which mention autostart use "no" to disable it, which will still work. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Wolfgang Denk <wd@denx.de>
2021-11-13env: Simplify env_get_default()Marek Behún
Instead of pretending that we don't have environment to force searching default environment in env_get_default(), get the data from the default_environment[] buffer directly. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-11-13env: Fix env_get() when returning empty string using env_get_f()Marek Behún
The env_get_f() function returns -1 on failure. Returning 0 means that the variable exists, and is empty string. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-11-13env: Don't set ready flag if import failed in env_set_default()Marek Behún
Do not set GD_FLG_ENV_READY nor GD_FLG_ENV_DEFAULT if failed importing in env_set_default(). Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-10-31env: Use static_assert() to check if default_environment is too largeMarek Behún
Check sizeof(default_environment) against ENV_SIZE in a static_assert() instead of runtime. Only check if !USE_HOSTCC (for in fw_env tool ENV_SIZE expands to a variable, and cannot be checked statically) nad !DEFAULT_ENV_INSTANCE_EMBEDDED, for in that case the default_environment variable is not set. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-10-31env: Always use char for default_environmentMarek Behún
Sometimes we use uchar and sometimes char for the default environment array. By always using char, we can get rid of some explicit casts. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-10-21env: Move non-cli env functions to env/common.cMarek Behún
Move the following functions from cmd/nvedit.c to env/common.c: env_set_ulong() env_set_hex() env_get_hex() eth_env_get_enetaddr() eth_env_set_enetaddr() env_get() from_env() env_get_f() env_get_ulong() since these functions are not specific for U-Boot's CLI. We leave env_set() in cmd/nvedit.c, since it calls _do_env_set(), which is a static function in that file. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-05-04env: allow environment to be amended from control dtbRasmus Villemoes
It can be useful to use the same U-Boot binary for multiple purposes, say the normal one, one for developers that allow breaking into the U-Boot shell, and one for use during bootstrapping which runs a special-purpose bootcmd. Or one can have several board variants that can share almost all boot logic, but just needs a few tweaks in the variables used by the boot script. To that end, allow the control dtb to contain a /config/enviroment node (or whatever one puts in fdt_env_path variable), whose property/value pairs are used to update the run-time environment after it has been loaded from its persistent location. The indirection via fdt_env_path is for maximum flexibility - for example, should the user wish (or board logic dictate) that the values in the DTB should no longer be applied, one simply needs to delete the fdt_env_path variable; that can even be done automatically by including a fdt_env_path = ""; property in the DTB node. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2021-04-16env: increment redund flag on read failBrandon Maier
If one of the reads fails when importing redundant environments (a single read failure), the env_flags wouldn't get initialized in env_import_redund(). If a user then calls saveenv, the new environment will have the wrong flags value. So on the next load the new environment will be ignored. While debugging this, I also noticed that env/sf.c was not correctly handling a single read failure, as it would not check the crc before assigning it to gd->env_addr. Having a special error path for when there is a single read failure seems unnecessary and may lead to future bugs. Instead collapse the 'single read failure' error to be the same as a 'single crc failure'. That way env_check_redund() either passes or fails, and if it passes we are guaranteed to have checked the CRC. Signed-off-by: Brandon Maier <brandon.maier@rockwellcollins.com> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Wolfgang Denk <wd@denx.de> CC: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-10-30env: split env_import_redund() into 2 functionsHeiko Schocher
split from env_import_redund() the part which checks which Environment is valid into a separate function called env_check_redund() and call it from env_import_redund(). So env_check_redund() can be used from places which also need to do this checks. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-31env: Discern environment coming from external storageMarek Vasut
Add another custom environment flag which discerns environment coming from external storage from environment set by U-Boot itself. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-07-31env: Add H_DEFAULT flagMarek Vasut
Add another internal environment flag which indicates that the operation is resetting the environment to the default one. This allows the env code to discern between import of external environment and reset to default. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop bootstage.h from common headerSimon Glass
Move this fairly uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move sorting functions to their own header fileSimon Glass
These don't need to be in common.h so move them out into a new header. Also add some missing comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-04Revert "env: solve compilation error in SPL"Tom Rini
This reverts commit 7d4776545b0f8a8827e5d061206faf61c9ba6ea9. The changes here break environment validation and furthermore do not seem to be required. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop the ENTRY typedefSimon Glass
U-Boot is not supposed to use typedef for structs anymore. Also this name is the same as the ENTRY() macro used in assembler files, and 'entry' itself is widely used in U-Boot (>8k matches). Drop the typedef and rename the struct to env_entry to reduce confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move get/set_default_env() to env.hSimon Glass
Move these functions to the new header file and rename set_default_env() to env_set_default() so that it has a consistent env_ prefix. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move set_default_vars to env.hSimon Glass
Move this function to the new header file and rename it so it has an env_ prefix. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_relocate() to env.hSimon Glass
Move env_relocate() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-05-23env: solve compilation error in SPLPatrick Delaunay
Solve compilation issue when cli_simple.o is used in SPL and CONFIG_SPL_ENV_SUPPORT is not defined. env/built-in.o:(.data.env_htab+0xc): undefined reference to `env_flags_validate' u-boot/scripts/Makefile.spl:384: recipe for target 'spl/u-boot-spl' failed make[2]: *** [spl/u-boot-spl] Error 1 u-boot/Makefile:1649: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 2 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-01-26env: common: Return specific error code on bad CRCSam Protsenko
Callers of env_import*() functions might want to check the case when we have incorrect environment (with bad CRC). For example, when environment location is being defined in env_load(), call chain may look like this: env_load() -> drv->load() = env_mmc_load() -> env_import() Return code will be passed from env_import() all way up to env_load(). Right now both env_mmc_load() and env_import() return -EIO error code, so env_load() can't differentiate between two cases: 1. Driver reports the error, because device is not accessible 2. Device is actually accessible, but environment is broken Let's return -ENOMSG in env_import(), so we can distinguish two cases mentioned above. It will make it possible to continue working with "bad CRC" environment (like doing "env save"), instead of considering it not functional (implemented in subsequent patch). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-01-15common: command: Add support for $ auto-completionBoris Brezillon
Add the dollar_complete() function to auto-complete arguments starting with a '$' and use it in the cmd_auto_complete() path such that all args starting with a $ can be auto-completed based on the available env vars. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Fix some linking problems] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-20env: add the same prefix to error messages to make it detectable by testsQuentin Schulz
The error message should start with `## Error: ` so that it's easily detectable by tests without needing to have a complex regexp for matching all possible error message patterns. Let's add the `## Error: ` prefix to the error messages since it's the one already in use. Suggested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2018-07-19env: common: accept flags on reset to default envYaniv Levinsky
The function set_default_env() sets the hashtable flags for import_r(). Formally set_default_env() doesn't accept flags from its callers. In practice the caller can (un)set the H_INTERACTIVE flag, but it has to be done using the first character of the function's string argument. Other flags like H_FORCE can't be set by the caller. Change the function to accept flags argument. The benefits are: 1. The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string. 2. Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands. 3. Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa. Please note: The propagation of H_FORCE from do_env_default() does not introduce any functional changes, because currently himport_r() is set to destroy the old environment regardless if H_FORCE flag is set or not. More changes are needed to utilize the propagation of H_FORCE. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: set H_INTERACTIVE in do_env_defaultYaniv Levinsky
The function set_default_vars() in common.c adds H_INTERACTIVE to the h_import() flag, but the function has no way of telling if the command actually was user directed like this flag suggest. The flag should be set by the calling function do_env_default() in nvedit.c instead, where the command is certainty user directed. Move the H_INTERACTIVE flag from set_default_vars() to do_env_default(). Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: propagate envflag to set_default_varsYaniv Levinsky
The env_flag in do_env_default() doesn't get propagated and therefore gets ignored by himport_r(). This breaks to ability to "forcibly" reset variables to their default values using the environment command. Scenario example of the problem: # setenv kernel uImage # setenv .flags kernel:so # env default -f kernel ## Error: Can't overwrite "kernel" himport_r: can't insert "kernel=zImage" into hash table Change the call path so it will pass the flag correctly. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-04-16env: Relocate env drivers if manual reloc is requiredSiva Durga Prasad Paladugu
Relocate env drivers if manual relocation is enabled. This patch fixes the issue of u-boot hang incase if env is present in any of the flash devices. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-01env: move more common code to env_import_redundSimon Goldschmidt
There is more common code in mmc, nand and ubi env drivers that can be shared by moving to env_import_redund. For this, a status/error value whether the buffers were loaded are passed as additional parameters to env_import_redund. Ideally, these are already returned to the env driver by the storage driver. This is the case for mmc, nand and ubi, so for this change, code deduplicated. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: common: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make the common code play a little nicer by removing all the extra output in the standard case. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-11-21env: Remove CONFIG_ENV_AES supportTom Rini
This support has been deprecated since v2017.09 due to security issues. We now remove this support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-20env: Replace all open-coded gd->env_valid values with ENV_ flagsSimon Glass
Some of these were missed in the conversion. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop env_relocate_spec() in favour of env_load()Simon Glass
This is a strange name for a function that loads the environment. There is now only one implementation of this function, so use the new env_load() function directly instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop env_get_char_spec()Simon Glass
We only have a single implementation of this function now and it is called env_get_char(). Drop the old function and the weak version. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: common: Drop env_get_char_memory()Simon Glass
This function is the same as env_get_char_spec() apart from dropping the brackets. Drop the brackets from env_get_char_spec() and use that instead of env_get_char_memory(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: common: Drop env_get_char_init()Simon Glass
This function does nothing but call env_get_char_spec(). Drop it and adjust its only caller. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: common: Factor out the common env_valid checkSimon Glass
The check for gd->env_valid is used in both the 'if' and 'else' part of env_get_char(). Move it into that function instead for simplicity. Drop that code from the two leaf functions. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: common: Drop env_get_addr()Simon Glass
This function is not used anywhere other than env_get_char(). Move the code into that function. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: common: Make env_get_addr/get_char_memory() staticSimon Glass
These functions are not used outside this file. Make them static and order them to avoid forward declarations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
