path: root/env/nowhere.c
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_valid to env.hSimon Glass
This enum is somewhat widely used to determine if the environment is valid or not. Move it to the common environment header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-20env: Correct case of no sub-init functionTom Rini
With the change to the environment code to remove the common init stage of pointing to the default environment and setting it as valid, combined with the change to switch gd->env_valid from 0/1/2 to an enum we now must set env_valid to one of the enum values rather than an int. And in this case, not only was setting it to an int wrong, it was now the wrong value. Finally, in the case of ENV_IS_NOWHERE we must still say that our envionrment is invalid after init for things to continue to function. Fixes: 7938822a6b75 ("env: Drop common init() functions") Tested-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Changes in v3: - Actually include changes for env/nowhere.c
2017-08-15env: Drop unused env_ptr variablesSimon Glass
This variable is declared as a global in most environment location drivers. But it is not used outside the drivers and most of the declarations are unnecessary. Also some drivers call free() on env_ptr which seems wrong since it is not in the heap. Drop the variable where possible, and all calls to free(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop the env_name_spec globalSimon Glass
Add a name to the driver and use that instead of the global variable declared by each driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop common init() functionsSimon Glass
Most of the init() implementations just use the default environment. Adjust env_init_new() to do this automatically, and drop the redundant code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Switch over to use environment location driversSimon Glass
Move over to use a the master implementation of the location drivers, with each method calling out to the appropriate driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Create a location driver for each locationSimon Glass
Set up a location driver for each supported environment location. At present this just points to the global functions and is not used. A later patch will switch this over to use private functions in each driver. There are several special cases here in various drivers to handle peculiarities of certain boards: 1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but do not actually load the environment in SPL. The env load code was optimised out before but with the driver, it is not. Therefore a special case is added to env/fat.c. The correct fix (depending on board testing might be to disable CONFIG_SPL_ENV_SUPPORT. 2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards do not actually load the environment in SPL, so to reduce code size we need to drop that code. A similar fix may be possible with these boards, or it may be possible to adjust the environment CONFIG settings. Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not apply when the environment is in flash. Obviously the above has been discovered through painful and time-consuming trial and error. Hopefully board maintainers can take a look and figure out what is actually needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
