path: root/env/sf.c
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-13Revert "env: add spi_flash_read_env function"Heiko Schocher
This reverts commit 9a9d66f5eff0f443de4c2c6ca3e27771ed14b1b4. because it breaks fw_setenv and U-Boot interworking, if U-Boot environment is stored in a SPI-NOR. Reproduce it with: boot linux with empty Environment and store a variable with fw_setenv into it, the Environment is now filled with 0xff: root@ckey5e:10:8e:~# hexdump -C /dev/mtd4 00000000 e9 e8 07 fa 01 62 6f 6f 74 63 6d 64 3d 72 75 6e |.....bootcmd=run| [...] 00000f30 7d 00 75 62 69 62 6f 6f 74 76 6f 6c 3d 32 00 00 |}.ubibootvol=2..| 00000f40 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| Boot now U-Boot prints: Loading Environment from SPI Flash... SF: Detected s25fl128l with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment Reason is the above commit, as it only reads until \0\0 is found, and assumes the rest of the Environment space is filled with 0x00, which is not the case when saving an Environment under linux with fw_setenv. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2019-01-21Revert "env: sf: fix environment in SPI NOR"Tom Rini
Per Heiko the original changes were correct and something is misbehaving on his hardware. This reverts commit 3d5931e5986a49c44cdab845c6751d845812e8d8. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-18env: sf: fix environment in SPI NORHeiko Schocher
commit 9a9d66f5eff0 ("env: add spi_flash_read_env function") breaks Environment functionality, as it reads only until 2 \0 are found, but fills the buffer with 0x0 instead 0xff which leads in an incorrect crc sum. Fix: init the read buffer with 0xff instead 0x00 Signed-off-by: Heiko Schocher <hs@denx.de>
2019-01-16env: add spi_flash_read_env functionHoratiu Vultur
The spi_flash_read_env function is a wrapper over spi_flash_read, which enables the env to read multiple flash page size from flash until '\0\0' is read or the end of env partition is reached. Instead of reading the entire env size. When it reads '\0\0', it stops reading further the env and assumes that the rest of env is '\0'. This is an optimization for large environments that contain few bytes environment variables. In this case it doesn't need to read the entire environment and only few pages. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2018-12-04env: sf: define API to override sf environment addressRajesh Bhagat
Defines env_sf_get_env_addr API to override sf environment address, required to support multiple environment. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-19fix: env: Fix the SPI flash device setup for DM modeKonstantin Porotchkin
For some reason the spi_flash_probe_bus_cs() is called inside the setup_flash_device() with zero values in place of configurated SPI flash mode and maximum flash speed. This code causes HALT error during startup environment relocation on some platforms - namely Armada-38x-GP board. Fix the function call by replacing zeros with the appropriate values - CONFIG_ENV_SPI_MAX_HZ and CONFIG_ENV_SPI_MODE. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-07-19env: common: accept flags on reset to default envYaniv Levinsky
The function set_default_env() sets the hashtable flags for import_r(). Formally set_default_env() doesn't accept flags from its callers. In practice the caller can (un)set the H_INTERACTIVE flag, but it has to be done using the first character of the function's string argument. Other flags like H_FORCE can't be set by the caller. Change the function to accept flags argument. The benefits are: 1. The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string. 2. Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands. 3. Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa. Please note: The propagation of H_FORCE from do_env_default() does not introduce any functional changes, because currently himport_r() is set to destroy the old environment regardless if H_FORCE flag is set or not. More changes are needed to utilize the propagation of H_FORCE. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-02-01env: sf: use env_import_redund to simplify env_sf_loadSimon Goldschmidt
For the redundant environment configuration, env_sf_load still contained duplicate code instead of using env_import_redund(). Simplify the code by only executing the load twice and delegating everything else to env_import_redund. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-17env: sf: Add support for env init for QSPI-NORAshish Kumar
ENV variables can now be used before relocation. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Adjust the load() method to return an errorSimon Glass
The load() methods have inconsistent behaviour on error. Some of them load an empty default environment. Some load an environment containing an error message. Others do nothing. As a step in the right direction, have the method return an error code. Then the caller could handle this itself in a consistent way. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop the env_name_spec globalSimon Glass
Add a name to the driver and use that instead of the global variable declared by each driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop common init() functionsSimon Glass
Most of the init() implementations just use the default environment. Adjust env_init_new() to do this automatically, and drop the redundant code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Switch over to use environment location driversSimon Glass
Move over to use a the master implementation of the location drivers, with each method calling out to the appropriate driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Create a location driver for each locationSimon Glass
Set up a location driver for each supported environment location. At present this just points to the global functions and is not used. A later patch will switch this over to use private functions in each driver. There are several special cases here in various drivers to handle peculiarities of certain boards: 1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but do not actually load the environment in SPL. The env load code was optimised out before but with the driver, it is not. Therefore a special case is added to env/fat.c. The correct fix (depending on board testing might be to disable CONFIG_SPL_ENV_SUPPORT. 2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards do not actually load the environment in SPL, so to reduce code size we need to drop that code. A similar fix may be possible with these boards, or it may be possible to adjust the environment CONFIG settings. Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not apply when the environment is in flash. Obviously the above has been discovered through painful and time-consuming trial and error. Hopefully board maintainers can take a look and figure out what is actually needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Add an enum for environment stateSimon Glass
At present we have three states for the environment, numbered 0, 1 and 2. Add an enum to record this to avoid open-coded values. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
