path: root/include/asm-avr32/arch-at32ap700x/chip-features.h
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-26Add AVR32 LCD supportMark Jackson
This patch adds support for the AVR32 LCD controller. This patch is based off the latest u-boot-video. A quick summary of what's going on:- Enable LCDC pixel clock Enable LCDC port pins Add framebuffer pointer to global_data struct Allocate framebuffer To use the new code, update your board config to include something like this:- #define CONFIG_LCD 1 #if defined(CONFIG_LCD) #define CONFIG_CMD_BMP #define CONFIG_ATMEL_LCD 1 #define LCD_BPP LCD_COLOR16 #define CONFIG_BMP_16BPP 1 #define CONFIG_FB_ADDR 0x10600000 #define CONFIG_WHITE_ON_BLACK 1 #define CONFIG_VIDEO_BMP_GZIP 1 #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE 262144 #define CONFIG_ATMEL_LCD_BGR555 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 #define CONFIG_SPLASH_SCREEN 1 #endif The standard U-Boot BMP and Splash-screen features should just work. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk> [agust@denx.de: fixed some style issues] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-06-03atmel_spi: Driver for the Atmel SPI controllerHans-Christian Egtvedt
This adds a driver for the SPI controller found on most AT91 and AVR32 chips, implementing the new SPI API. Changed in v4: - Update to new API - Handle zero-length transfers appropriately. The user may send a zero-length SPI transfer with SPI_XFER_END set in order to deactivate the chip select after a series of transfers with chip select active. This is useful e.g. when polling the status register of DataFlash. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-12-17AVR32: Make some AT32AP700x peripherals optionalHaavard Skinnemoen
Add a chip-features file providing definitions of the form AT32AP700x_CHIP_HAS_<peripheral> to indicate the availability of the given peripheral on the currently selected chip. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
