path: root/include/config_distro_defaults.h
2016-08-20cmd: booti: move CONFIG_CMD_BOOTI to KconfigMasahiro Yamada
This command is used to boot ARM64 Linux. I made DISTRO_DEFAULTS select this option for ARM64 to respect include/config_distro_defaults.h. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18efi_loader: Fall back to fdtfile naming conventionAlexander Graf
When there is no $fdtfile variable set, we still have a good chance that on 32bit arm the fdtfile really is just called $soc-$board.dtb. Enable the exports for $soc and $board in our distr defaults and make use of them in the efi boot script. Reported-by: Andreas Faerber <afaerber@suse.de> Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-04-18distro: Enable iso partition codeAlexander Graf
Now that we can properly boot EFI payloads from iso el torito images, let's enable support for isos by default in the distro header. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-12PXE: if a board has set its own value for CONFIG_BOOTP_VCI_STRING do not set ↵Dennis Gilmore
the default one. Use the board set value instead Signed-off-by: Dennis Gilmore <dennis@ausil.us>
2015-04-19config: Add default client arch defines for intel architecturesSjoerd Simons
Define default PXE client architecture identifiers for IA32 (0x0 aka Intel x86PC) and Intel x86-64 (0x9 aka EFI x86-64). This prepares for usage for config_distro_defaults in the sandbox architecture Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-03-28config: Define BOOTP client architecture and VCI for ARMv8Thierry Reding
Reuse the 32-bit ARM client architecture and identify ARMv8 specifically by setting the BOOTP VCI string. Cc: Dennis Gilmore <dennis@ausil.us> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2015-03-28config: Use booti instead of bootz on 64-bit ARMThierry Reding
The bootz command doesn't work with Linux kernel images on 64-bit ARM. The replacement command with the same interface and functionality is booti. Cc: Dennis Gilmore <dennis@ausil.us> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-10-27Correct single misspelling of "consitant" in source tree.Robert P. J. Day
2014-02-05config: Fix line lengths in include/config_distro_defaults.hTom Rini
2014-02-04config: add config_distro_defaults.hDennis Gilmore
describe a set of default features that distros can rely on being available. having this common definition means that distros can easily support systems implementing them. Signed-off-by: Dennis Gilmore <dennis@ausil.us>
