path: root/include/configs/M54455EVB.h
2011-09-04ColdFire:Update the env settings for several boards.Jason Jin
Move the environment outside the u-boot for some boards and enlarge the u-boot size in some env settings. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14ColdFire: Add DSPI support for MCF5227x and MCF5445xTsiChung Liew
Remove individual CPU specific DSPI driver. Add required feature for the common DSPI driver in cpu_init and in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-14ColdFire: Update configuration file to use flash buffer writeTsiChung Liew
Update M52277EVB, M53017EVB and M54455EVB platform configuration file to use flash buffer write Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-08-28ColdFire: Multiple fixes for MCF5445x platformsTsiChung Liew
Add FEC pin set and mii reset in __mii_init(). Change legacy flash vendor from 2 to AMD LEGACY (0xFFF0), change cfi_offset to 0, and change CFG_FLASH_CFI to CONFIG_FLASH_CFI_LEGACY. Correct M54451EVB and M54455EVB env settings in configuration file. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-14ColdFire: Add Serial Flash support for M54455EVBTsiChung Liew
2008-08-14ColdFire: Implement SBF feature for M5445EVBTsiChung Liew
2008-08-14ColdFire: Add SSPI feature for MCF5445xTsiChung Liew
2008-08-14ColdFire: Use CFI Flash driver for M54455EVBTsiChung Liew
Remove non-common flash driver in board/freescale/m54455evb/flash.c. The non-cfi flash will use CONFIG_FLASH_CFI_LEGACY to configure the flash attribute. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-31ColdFire: Add dspi and serial flash support for MCF5445xTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-01-17ColdFire: PCI and misc updates for MCF5445xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-09trivial: fix consequences of a bad mergeGuennadi Liakhovetski
Fix what looks like a merge artifact. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-01-09Improve configuration of FPGA subsystemMatthias Fuchs
This patch removes the FPGA subsystem configuration through the CONFIG_FPGA bitmask configuration option. See README for the new options: CONFIG_FPGA, CONFIG_FPGA_<vendor>, CONFIG_FPGA_<family> Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-11-03Cleanup coding style; update CHANGELOGWolfgang Denk
2007-10-25ColdFire 54455: Fix correct boot location for atmel and intelTsiChungLiew
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
