path: root/include/configs/TQM850M.h
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-10-29powerpc: tqm8xx*: convert to generic boardWolfgang Denk
This converts all TQM8xx boards (MPC8xx based) to generic board. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-17split mpc8xx hooks from cmd_ide.cPavel Herrmann
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created ide_init_postreset() (invoked after calling ide_reset after ide_preinit), some cleanup to make checkpatch happy, enable IDE init hooks in configs of affected boards. confusingly, these hooks are used by more than just mpc8xx-based boards, and therefore are placed in arch/ppc/lib/ note: checkpatch still emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-07TQM850M: Add missing CONFIG_BOOTDELAYWolfgang Denk
This also fixes a build warning: main.c: In function 'main_loop': main.c:311:16: warning: variable 'bootlimit' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12TQM8xx: enable device tree support on all TQM8xx based boards.Heiko Schocher
Also enable support for CONFIG_HWCONFIG because we use this for configuring if this hardware has a FEC or not. syntax: hwconfig=fec:on if hardware has an fec hwconfig=fec:off if hardware has no fec Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-28TQM8xx* boards: set larger SMC Rx buffer lenWolfgang Denk
Commit 2b3f12c2 added support for configurable SMC Rx buffer length on 8xx systems. Enable this feature on TQM8xx* based boards. This fixes the problem that pasting text in the middle of a line (i. e. inserting in edit mode) did not work - only the first two characters got inserted, the rest was lost. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-21Enable ext2 support for TQM8xxL/M based boardsWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-12Coding style cleanup, update CHANGELOG, prepare releasev1.3.4Wolfgang Denk
2008-08-09TQM8xx{L,M}: try to normalize config files for TQM8xx? based boardWolfgang Denk
- enable CFI driver where this was forgotten - enable mtdparts support - adjust default environment etc. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-12-27TQM8xx: use the CFI flash driver on all TQM8xx boardsMartin Krause
Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-09-16TQM8xx/FPS8xx: adjust flash partitions for 2.6 ARCH=powerpc kernelsWolfgang Denk
2007-07-09include/configs/[T-Z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
