path: root/include/configs/adp-ae3xx.h
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-30mmc: ftsdc010: Migrate CONFIG_FTSDC010_SDIO to KconfigRick Chen
Convert CONFIG_FTSDC010_SDIO to Kconfig. So CONFIG_FTSDC010_SDIO can also be removed from config_whitelist.txt. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Cc: Greentime Hu <green.hu@gmail.com>
2018-03-30Drop CONFIG_FTSDC010_NUMBERRick Chen
CONFIG_FTSDC010_NUMBER was not used anymore, can be removed now. So CONFIG_FTSDC010_NUMBER can also be removed from config_whitelist.txt. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Cc: Greentime Hu <green.hu@gmail.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-30nds32: board: Support ftsdc010 DM.Rick Chen
AG101P/AE3XX enable ftsdc010 dm flow. Signed-off-by: Rick Chen <rick@andestech.com>
2017-09-21nds32: board: Support SPI driver.rick
Add spi dts node and enable spi dm flash config. Signed-off-by: rick <rick@andestech.com>
2017-09-21nds32: ftmac100 support cache enable.rick
Enable cache and ftmac100 performance can be improved. Signed-off-by: rick <rick@andestech.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-23nds32: eth: Support ftmac100 DM.rick
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform. Verification: Boot linux kernel via dhcp and bootm ok. NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000; NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4899 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'boomimage-310y-ae300-spi.bin'. Load address: 0x600000 Loading: ################################################################# ################################################################# ################################################################# ... ... ################################### 233.4 KiB/s done Bytes transferred = 13872076 (d3abcc hex) NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4592 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'ae300.dtb'. Load address: 0x2000000 Loading: # 82 KiB/s done Bytes transferred = 2378 (94a hex) NDS32 # bootm 0x600000 - 0x2000000 Image Name: Created: 2017-03-22 6:52:03 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13872012 Bytes = 13.2 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Booting using the fdt blob at 0x2000000 Loading Kernel Image ... OK Loading Device Tree to 01efc000, end 01eff949 ... OK Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) ) #293 PREEMPT Wed Mar 22 14:49:28 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159) ... ... Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AE3XX platform.rick
Support Andestech AE3xx platform: serial, timer device tree flow. Signed-off-by: rick <rick@andestech.com>
