path: root/include/configs/am43xx_evm.h
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_USB_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_VCI_STRING to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPL_NET_VCI_STRING Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-07usb: add (move) CONFIG_USB_HOST to KconfigMasahiro Yamada
The meaning of CONFIG_USB in U-Boot is different from that in Linux. As you see in drivers/usb/Kconfig of Linux, CONFIG_USB enables the USB host controller support, while CONFIG_USB_SUPPORT is used to enable the whole of the USB sub-system. When I added CONFIG_USB into Kconfig by commit 6e7e9294d321 ("usb: add basic USB configs in Kconfig"), I planned to follow the Linux's convention, i.e. CONFIG_USB to enable/disable the USB host support. Then, commit 68f7c5db2d1e ("usb: Generic USB Kconfig option, that fits both host and gadget and comments") changed the logic of the CONFIG_USB to point to the whole of the USB sub-system. As a result, currently we do not have an option for USB host. This commit adds CONFIG_USB_HOST, which will be useful to compile in the USB host support code. CONFIG_USB_HOST is not referenced at all, but strangely some boards define it in board headers. I removed them because USB_HOST will be selected in Kconfig going forward. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-27ti: AM43xx: board: Detect AM43xx HS EVMMadan Srinivas
Adds code to detect AM43xx HS EVMS - the string in the I2C EEPROM for HS EVMs differs from GP EVMs. Adds code to for evm detection, regardless of whether the evm is for GP or HS parts, and updates board init to use that. Modifies findfdt command to pick up am437x-gp-evm.dtb for the HS EVMs also, as the boards are similar except for some security specific changes around power supply and enclosure protection. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Daniel Allred <d-allred@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27ti: AM43xx: Use CONFIG options from SOC KconfigMadan Srinivas
Updates configs/am43xx_evm.h to use CONFIG options from SOC specific Kconfig file for various calculations. On AM43x devices, the address of SPL entry point depends on the device type, i.e. whether it is secure or non-secure. Further, for non-secure devices, the SPL entry point is different between USB HOST boot mode, other "memory" boot modes (MMC, NAND) and "peripheral" boot modes (UART, USB) To add to the complexity, on secure devices, in addition to the above differences, the SPL entry point can change because of the space occupied by other components (other than u-boot or spl) that go into a secure boot image. To prevent the user from having to modify source files every time any component of the secure image changes, the value of CONFIG_SPL_TEXT_BASE has been set using a Kconfig option that is supplied in the am43xx_*_defconfig files Using the CONFIG options also enables us to do away with some compile time flags that were used to specify CONFIG_SPL_TEXT_BASE for different boot modes. On QSPI devices, the same problem described above occurs w.r.t. the address of the u-boot entry point in flash, when booting secure devices. To handle this, CONFIG_SYS_TEXT_BASE is also setup via a Kconfig option and the defconfig files. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Daniel Allred <d-allred@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27arm: Kconfig: Add support for AM43xx SoC specific KconfigMadan Srinivas
Adding support for AM43xx secure devices require the addition of some SOC specific config options like the amount of memory used by public ROM and the address of the entry point of u-boot or SPL, as seen by the ROM code, for the image to be built correctly. This mandates the addition of am AM43xx CONFIG option and the ARM Kconfig file has been modified to source this SOC Kconfig file. Moving the TARGET_AM43XX_EVM config option to the SOC KConfig and out of the arch/arm/Kconfig. Updating defconfigs to add the CONFIG_AM43XX=y statement and removing the #define CONFIG_AM43XX from the header file. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Daniel Allred <d-allred@ti.com> Tested-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_PHY_* to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_OMAP to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_GADGET/HOST to KconfigSam Protsenko
Description was borrowed from kernel dwc3 Kconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15ti_armv7_common: env: Consolidate support for loading script and text env filesLokesh Vutla
Support for loading bootscript and text env file is duplicated in all TI platforms. Add this information to DEFAULT_MMC_TI_ARGS so that it can be reused in all TI platforms. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15am43xx: configs: Enable USB commands for non usb boot alsoMugunthan V N
With commit aee119bd70b8 ('am43xx_evm: add usb host boot support') usb commands is removed from U-boot second stage and enbaled only on USB boot config. Fixing this by enable USB commands for both USB boot and in second stage u-boot. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-15am43xx: qspi: Fix config to select SPI modeVignesh R
CONFIG_SF_DEFAULT_MODE is used to select default SPI mode when using sf commands. Therefore fix am43xx to use CONFIG_SF_DEFAULT_MODE instead of CONFIG_DEFAULT_SPI_MODE. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-20am43xx_evm: timer: do not define CONFIG_TIMER for splMugunthan V N
Since OMAP's spl doesn't support DM currently, do not define CONFIG_TIMER for spl build. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13am43xx_evm: qspi: do not define DM_SPI and DM_SPI_FLASH for splMugunthan V N
Since OMAP's spl doesn't support DM currently, do not define DM_SPI and DM_SPI_FLASH for spl build. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-17ARM: am43xx: Enable QUAD read and EDMA support for ti_qspiVignesh R
Enable TI_EDMA3 and QUAD read support for ti_qspi on am43xx, this increases read performance to 4 MB/s. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-12am43xx_evm: Add DFU support for qspi flashVignesh R
This adds support to update firmware on qspi flash present on am437x-sk-evm and am43xx-epos-evm via DFU. On device: => setenv dfu_alt_info ${dfu_alt_info_qspi} => dfu 0 sf 0:0 On host: $ sudo dfu-util -l $ sudo dfu-util -D u-boot.bin -a u-boot.bin Signed-off-by: Vignesh R <vigneshr@ti.com>
2015-10-22am43xx_evm: mmc: do not define DM_MMC for splMugunthan V N
Since spl doesn't support DM currently, do not define DM_MMC for spl build. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22am43xx_evm.h: : switch to CONFIG_OMAP_SERIAL for non-SPL DM_SERIALMugunthan V N
Tested on am437x gp evm and am437x sk evm Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-09-28am437x_evm: increase phy autoneg timeoutSekhar Nori
When AM437x EVM is connected to Gigabit switch, it takes more time to finish auto-negotiation than on a 10/100 switch. The default 4 second limit times-out more often than not. This is observed when testing with a D-Link DGS-1008A desktop switch. Increase the auto-negotiation time-out for AM437x EVM to handle this case. Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2015-09-11ti_armv7_common: env: Consolidate MMC argsLokesh Vutla
Define default mmc args in ti_armv7_common.h so that all TI platforms can reuse. Reported-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-28include: configs: am43xx_evm: add 'usb stop' in usbboot envKishon Vijay Abraham I
The usbboot environment variable has 'usb start' command but doesn't have the corresponding 'usb stop' command. This breaks usb peripheral mode if tried after 'run usbboot' fails to load the images in usb host mode. Fix it here by adding 'usb stop' command in usbboot env. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-07-27configs: split ti_armv7_common into a omap generic headerNishanth Menon
TI armv7 based SoCs are based on two architectures - one based on OMAP generation architecture and others based on Keystone architecture. Many of the options are architecture specific, however a lot are common with v7 architecture. So, step 1 will be to move out OMAP specific stuff from ti_armv7_common into a ti_armv7_omap.h header which is then used by all the relevant architecture headers. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-07-22usb: xhci: omap: Remove common dwc3 drv functions callsRamneek Mehresh
Remove all redundant dwc3 driver function calls that are defined by dwc3 driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
