path: root/include/configs/bmips_bcm6338.h
2019-10-25bmips: configs: switch to size definitionsÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-05-31MIPS: add support for Broadcom MIPS BCM6338 SoC familyÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
