path: root/include/configs/cm_t54.h
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-16Convert CONFIG_SPL_SATA_SUPPORT to KconfigSimon Glass
2016-08-07usb: add (move) CONFIG_USB_HOST to KconfigMasahiro Yamada
The meaning of CONFIG_USB in U-Boot is different from that in Linux. As you see in drivers/usb/Kconfig of Linux, CONFIG_USB enables the USB host controller support, while CONFIG_USB_SUPPORT is used to enable the whole of the USB sub-system. When I added CONFIG_USB into Kconfig by commit 6e7e9294d321 ("usb: add basic USB configs in Kconfig"), I planned to follow the Linux's convention, i.e. CONFIG_USB to enable/disable the USB host support. Then, commit 68f7c5db2d1e ("usb: Generic USB Kconfig option, that fits both host and gadget and comments") changed the logic of the CONFIG_USB to point to the whole of the USB sub-system. As a result, currently we do not have an option for USB host. This commit adds CONFIG_USB_HOST, which will be useful to compile in the USB host support code. CONFIG_USB_HOST is not referenced at all, but strangely some boards define it in board headers. I removed them because USB_HOST will be selected in Kconfig going forward. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-20arm: cm-t54: add support for eeprom layout comandsNikita Kiryanov
Add support for EEPROM and EEPROM layout commands for CM-T54. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-05omap5: cm-t54: add sata supportDmitry Lifshitz
Add configs required for SATA support on CM-T54 board. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: don't enable misc_init_r by defaultFelipe Balbi
Out of all OMAP5-like boards, only one of them needs CONFIG_MISC_INIT_R, so it's best to enable that for that particular board only, instead of enabling for all boards unconditionally. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-09-09compulab: eeprom: add support for defining eeprom i2c busNikita Kiryanov
Create CONFIG_SYS_I2C_EEPROM_BUS #define to tell the EEPROM module what I2C bus the EEPROM is located at. Make cl_eeprom_read() switch to that bus when reading EEPROM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-08-25cm-t54: convert to generic boardDmitry Lifshitz
Use generic board setup functions by defining CONFIG_SYS_GENERIC_BOARD. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-05-23cm-t54: add environment partition runtime detectionDmitry Lifshitz
Add environment partition runtime detection callback. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-05-23cm-t54: add EEPROM support and MAC address handlingDmitry Lifshitz
cm-t54 Eth MAC address is stored in onboard EEPROM. Add EEPROM support and setup stored Eth MAC address. If EEPROM does not contain a valid MAC, then generate it from the processor ID code (reference code is taken from OMAP5 uEvm board file). Modify Device Tree blob MAC address field with retrieved data. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-05-23cm-t54: add cm-t54 board supportDmitry Lifshitz
Add cm-t54 board directory, config file. Enable build. Basic support includes: Serial console SD/MMC eMMC USB Ethernet Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
