Currently Vybrids sdboot variable tries to load the kernel from /boot of
the root partition (typically second partition when using the sdcard
image). However, since we moved to flash the kernel in a separate UBI
volume, we no longer deploy the kernel/device tree to /boot, hence
sdboot does not work in its current state.
Load the kernel and device tree from the first (typically FAT) partition
as customary on all Toradex modules.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Let the kernel print some debug messages when a user program
crashes due to an exception.
The kernel does not know about rw,noatime. The string rw by itself
is valid, and to pass additional arguments rootflags=noatime can
be used. The kernel mounts ext3/ext4 file systems by default ro,
hence so far the kernel mounted the rootfs read-only. The init
manager systemd then remounts the rootfs after file system checking.
This makes sense and does not add measureable boot time. Let the
kernel explicitly mount ro on block device based rootfs.
The root mount flag noatime is only relevant when re-mounting
read-write, hence it needs to be present in /etc/fstab.
UBIFS used on raw NAND devices has no user space file checking,
hence there is no value to mount it in read-only first. Also mount
time for UBIFS is larger, and mounting first read-only and then
read-write has higher boot time (300ms, likely due to missing block
cache). Let the kernel explicitly mount rw on raw NAND based rootfs.
UBIFS has no atime support, hence no root mount flags needed.
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
U-Boot has grown to big with the enablement of FIT image. Since we
boot from a separate UBI volume, U-Boot does not need access to the
UBIFS. Also fix the maximum size, also consider the text base offset
in gfxRAM.
Synchronize environment with current layout, order variables by
name.
Set fdtfile to represent the current board. This allows distribution
to load the correct device tree, which in the module case often
deviates from the common fallback ${soc}-${board}${boardver}.dtb...
Add support for distro boot. This is especially helpful for external
devices. There is a global boot command which scans a predefined
list of boot targets:
run distro_bootcmd
As well as direct boot commands such as:
run bootcmd_mmc0
run bootcmd_usb
run bootcmd_dhcp
Refer to doc/README.distro fo details.
Add environment variables for default framebuffer support using a
default VGA mode. Also remove memargs, since we use memory size to
reserve the framebuffer which does not get overwritten by the
Linux kernel.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Synchronize initramfs related configuration options and improve
memory layout. The memory layout with an offset of 16MiB allows
to boot bigger kernels. With AUTO_ZRELADDR, which is pretty much
the standard nowadays, the kernel relacates itself to PC masked
with 0xf8000000 plus a text offset of 0x8000 (hence 0x80008000 for
Vybrid). With a 16MiB offset from the start of memory and a 16MiB
distance to the device-tree, we allow kernel up to ~16MiB.
u-boot allows modifying a device tree after it is loaded into
memory. Add fdt_fixup hook in u-boot environment which can
facilitate such modifications.
(cherry picked from commit faf1e62bf04b01dc7110a459f558aaf414bfcac0)
Introduce Ethernet update capability via setethupdate which is
automatically tried by setupdate as well should SD and USB update
fail (e.g. neither an SD card nor an USB memory stick with our
flash_blk.img script and accompanying artefacts is inserted.
Our update scripts write the kernel and device tree in seperate
UBI volumes. This allows to use a lot less UBI/UBIFS support in
U-Boot, which should lower the risk of hitting bugs in this area.
Boot times are also slightly faster (measurements showed an
improvement of ~150ms).
Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Stefan Roese <sr@denx.de>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
configs/bcm28155_ap_defconfig
configs/dra72_evm_defconfig
configs/dra74_evm_defconfig
configs/ma5d4evk_defconfig
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. Definitions were added to
defconfig files in a way that "make savedefconfig" generates exactly
the same file as used defconfig.
Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use
2 mA (as minimal allowed by Kconfig).
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
Remove the legacy way of enabling GPIO, SPI and UART on Vybrid
based boards since these driver's now only supports DT mode.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Some armv7 targets are missing a cache line size declaration.
In preparation for "arm: cache: Implement cache range check for v7"
patch, add these declarations with the appropriate value for
the target's SoC or CPU.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices.
Create a Kconfig option and move it to defconfig for all boards
that have this serial driver.
There are already Kconfig options for SPI drivers, but we
have not moved them from config.h to defconfig files. This
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
For most PPC platforms, they will call the first get_clocks() in
init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is
then defined to call the second get_clocks(), which should be
redundant for PPC.
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
get_clocks() should not be limited by ESDHC.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Remove spurious new line in configuration file.
Tested-by: Marek Vasut <marex@denx.de>
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
