path: root/include/configs/db-mv784mp-gp.h
2015-08-17arm: mvebu: db-mv784mp-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-mv784mp-gp AXP eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: Move CONFIG_SYS_TEXT_BASE to an address < 16 MiBStefan Roese
This patch moves CONFIG_SYS_TEXT_BASE to 0x00800000 for all Armada XP / 38x boards in mainline U-Boot. This is done in preparation for the ECC SDRAM scrubbing that needs to be done in the main U-Boot. The SPL (previously bin_hdr) has already scrubbed the area: 0x0000.0000 - 0x0100.0000 In this area this main U-Boot needs to get loaded. The main U-Boot then can scrub the remaining SDRAM area while running from this location. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: add multiple usb-hostcontroller support for AXPAnton Schubert
This patch adds support for multiple hostcontrollers to the ehci-marvell driver and enables all 3 usb-hcs on the db-mv784mp-gp board. It depends on the initial Armada XP usb support patch from Stefan. Signed-off-by: Anton Schubert <anton.schubert@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: db-mv785mp-gp: Add USB/EHCI supportStefan Roese
This patch enabled the USB/EHCI support for the Marvell DB-MV784MP-GP Armada XP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Marek Vasut <marex@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: db-mv784mp-gp.h: Fix image creation - use correct offsetStefan Roese
2015-07-23arm: mvebu: drivers/ddr: Move Armada XP DDR init code into new directoryStefan Roese
With the upcoming addition of the Armada 38x DDR support, which is not compatible to the Armada XP DDR init code, we need to introduce a new directory infrastructure. To support multiple Marvell DDR controller. This will be the new structure: drivers/ddr/marvell/axp Supporting Armada XP (AXP) devices (and perhaps Armada 370) drivers/ddr/marvell/a38x Supporting Armada 38x devices (and perhaps Armada 39x) Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-23arm: mvebu: add Armada XP SATA supportAnton Schubert
This patch initializes the SATA address windows on Armada XP and allows it to work with the existing mvsata_ide driver. It also adds the necessary configuration for the db-mv784mp-gp board. Signed-off-by: Anton Schubert <anton.schubert@gmx.de> Tested-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-05-05arm: mvebu: Change network init code to allow a more flexible setupStefan Roese
With the introduction of the Armada 38x support, its necessary to change the mvneta ethernet driver init call from always 4 times to a configurable value. Lets make this init call more flexible by moving the actually used devices to the config header. Additionally this patch takes care of the slightly different base addresses for the ethernet controllers on A38x. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05arm: mvebu: Move CONFIG_SPL_LDSCRIPT to common headerStefan Roese
This way, new MVEBU boards don't need to specifiy the common location for the SPL linker script. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-05arm: mvebu: Move mvebu-common into mach-mvebuStefan Roese
Now that the mach-mvebu directory exists and is used by Armada XP we can move the mvebu-common files into this directory as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-04-15i2c: mvtwsi: Support for up to 4 different controllersPaul Kocialkowski
Orion5x, Kirkwood and Armada XP platforms come with a single TWSI (I2C) MVTWSI controller. However, other platforms using MVTWSI may come with more: this is the case on Allwinner (sunxi) platforms, where up to 4 controllers can be found on the same chip. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-10-23arm: armada-xp: Add basic support for the Marvell DB-MV784MP-GP boardStefan Roese
This patch adds basic support for the Marvell DB-MV784MP-GP evaulation board. This is the first board that uses the recently created Armada XP 78460 SoC support. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
