path: root/include/configs/imx6dl-mamoj.h
2020-06-04Convert CONFIG_CMD_ASKENV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMD_ASKENV CONFIG_CMD_BMP CONFIG_CMD_BOOTD CONFIG_CMD_CACHE CONFIG_CMD_CRC32 CONFIG_CMD_DHCP CONFIG_CMD_ENV CONFIG_CMD_EXPORTENV CONFIG_CMD_EXT2 CONFIG_CMD_EXT4 CONFIG_CMD_FLASH CONFIG_CMD_FS_GENERIC CONFIG_CMD_FUSE CONFIG_CMD_GPIO CONFIG_CMD_GPT CONFIG_CMD_GREPENV CONFIG_CMD_I2C CONFIG_CMD_IMLS CONFIG_CMD_IMPORTENV CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_CMD_MEMINFO CONFIG_CMD_MII CONFIG_CMD_MTDPARTS CONFIG_CMD_NAND CONFIG_CMD_NAND_TRIMFFS CONFIG_CMD_NFS CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PING CONFIG_CMD_READ CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_SPL CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_TIME CONFIG_CMD_TRACE CONFIG_CMD_UBI CONFIG_CMD_UBIFS CONFIG_CMD_UNZIP CONFIG_FS_EXT4 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2018-05-18Fixup various SPDX tags from the latest mergeTom Rini
2018-05-18configs: imx6dl-mamoj: Add Falcon mode supportJagan Teki
Add Falcon mode support to boot Linux directly after SPL. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-05-18configs: imx6dl-mamoj: Add DFU supportJagan Teki
Add DFU support for BTicino Mamoj board and update the same steps in README. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
2018-05-18i.MX6: board: Add BTicino i.MX6DL Mamoj initial supportJagan Teki
Add initial support for i.MX6DL BTicino Mamoj board. Mamoh board added: - SPL - SPL_DM - SPL_OF_CONTROL - DM for U-Boot proper - OF_CONTROL for U-Boot proper - eMMC - FEC - Boot from eMMC - Boot from USB SDP Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
