path: root/include/configs/imx8qm_rom7720.h
2020-06-04Convert CONFIG_CMD_ASKENV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMD_ASKENV CONFIG_CMD_BMP CONFIG_CMD_BOOTD CONFIG_CMD_CACHE CONFIG_CMD_CRC32 CONFIG_CMD_DHCP CONFIG_CMD_ENV CONFIG_CMD_EXPORTENV CONFIG_CMD_EXT2 CONFIG_CMD_EXT4 CONFIG_CMD_FLASH CONFIG_CMD_FS_GENERIC CONFIG_CMD_FUSE CONFIG_CMD_GPIO CONFIG_CMD_GPT CONFIG_CMD_GREPENV CONFIG_CMD_I2C CONFIG_CMD_IMLS CONFIG_CMD_IMPORTENV CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_CMD_MEMINFO CONFIG_CMD_MII CONFIG_CMD_MTDPARTS CONFIG_CMD_NAND CONFIG_CMD_NAND_TRIMFFS CONFIG_CMD_NFS CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PING CONFIG_CMD_READ CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_SPL CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_TIME CONFIG_CMD_TRACE CONFIG_CMD_UBI CONFIG_CMD_UBIFS CONFIG_CMD_UNZIP CONFIG_FS_EXT4 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop linux/stringify.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-03-10imx: imx8qm: enable relocation of fdt and initrdOliver Graute
Set CONFIG_SYS_BOOTMAPSZ to the amount of memory available which is needed to relocate the kernel, device tree and initrd. Remove 'fdt_high' and 'initrd_high' environment variables from default environment which prevents relocation of FDT and initrd. Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Ye Li <ye.li@nxp.com> Cc: uboot-imx <uboot-imx@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-03-09imx: imx8qm_rom7720: added missing USDHC Base address definesOliver Graute
Added missing USDHC Base address defines Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Ye Li <ye.li@nxp.com> Cc: uboot-imx <uboot-imx@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-11-03imx: support i.MX8QM ROM 7720 a1 boardOliver Graute
Add i.MX8QM ROM 7720a1 board support Boot log as below: U-Boot 2019.10-rc3-00004-gd073e0242f (Sep 20 2019 - 08:24:13 +0200) CPU: NXP i.MX8QM RevB A53 at 1200 MHz Model: Advantech iMX8QM Qseven series Board: ROM-7720-A1 4GB Build: SCFW 65afe5f6 Boot: SD2 DRAM: 4 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: eth0: ethernet@5b040000Could not get PHY for FEC1: addr 1 , eth-1: ethernet@5b050000 Hit any key to stop autoboot: 0 Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Ye Li <ye.li@nxp.com> Cc: uboot-imx <uboot-imx@nxp.com>
